On 5th September 2008, V1 wrote:-
"I could close it every time I walk away for a minute or two, but sooner or later I tend to forget and leave it open". "I'd like hear from anyone who has come up with a good solution". Thanks, Frank Allen Sure did find a good solution with the "sooner or later forgetting" problem Frank! It's called 'being a club member'! If I am flying a club glider and walk away from the cockpit without closing the canopy I get my "arse kicked all round the field" by a club instructor! This technique does wonders for "the memory problem" and ensures that "the closing while unattended habit" is carried over for when I'm flying a 'private' glider! Regards Tony (aka pilot extraordinaire) |
On Fri, 05 Sep 2008 12:37:40 -0700, V1 wrote:
I have a side-mounted canopy (Ventus 2). I'm concerned that a gust of wind could blow it shut when it's in the open position, breaking or damaging the canopy. Our club operates from an airfield that regularly experiences fresh to strong winds. Club policy is to stage gliders with side hinged canopies at the flight line such that the prevailing wind will blow the canopy open. Ie these gliders are staged on the side of the runway either nose facing the runway, or tail facing the runway, depending on the direction of the prevailing wind (which goes with the end we are launching from). This is so that they don't slam shut, damaging equipment and people, when the pilots are climbing in or out. The rest of the time canopies must be closed and locked. Even when the wind is not blowing. Ian |
Upper Surface Blowing (USB) | Charles Gray | Military Aviation | 1 | August 17th 08 10:21 PM |
Saturn V S-IC (first) stage are placed side by side prior to commencement of the mating of the two stages 6416485.jpg | [email protected] | Aviation Photos | 0 | April 12th 07 01:28 AM |
For Mitchell Holman, if you want them... - F-15 & F-16 on pedestals WPAFB side by side.JPG (1/1) | Blue Oval/Dan Edwards | Aviation Photos | 4 | January 19th 07 01:19 AM |
Fueling from Plastic Containers and Blowing yourself up? | Juaquin Murrieta | Home Built | 23 | April 11th 05 04:27 PM |
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? | jls | Owning | 3 | April 11th 04 04:55 PM |
