Upper Surface Blowing (USB)
Old January 3rd 04, 08:53 AM
Charles Gray
Default Upper Surface Blowing (USB)
I recall that USB was mentioned in several books of the 1980's, not
simply for transport, but as a method of producing STOL close air
support and bombing aircraft.
While the russians had a transport, and I believe we also did, I
haven't seen much more about USB, and nothign about applying it to
tactical attack aircraft.
Is this just a case of it never happened because the money wasn't
there, or was there somethign in the concept that proved less aimiable
to general use than first thought?
Old August 17th 08, 10:21 PM
Terry day Terry day is offline
Junior Member
First recorded activity by AviationBanter: Aug 2008
Smile
You will be able to see most of the answer by viewing the PDF "Lift and the Coanda Effect" which is the story of Upper Surface Blowing up to today on our website www.newfluidtechnology.com regards, Terry.
Surface to Air Missile threat PlanetJ Instrument Flight Rules 1 August 14th 03 02:13 PM
seeking info from NW Ontario/ Upper Midwest Pilots flying intoAtikokan David Megginson Instrument Flight Rules 0 July 9th 03 03:04 PM
