instrument panel material
Old September 18th 08, 08:22 PM posted to rec.aviation.homebuilt
rpellicciotti[_2_]
Default instrument panel material
On Sep 12, 11:38*am, jan olieslagers
schreef:
On Sep 12, 4:36 am, jan olieslagers
What is the typical material for an instrument panel?
Soft steel sheet, I should think? What thickness?
Have I understood some designs have the panel as
an integral part of the fuselage, contributing
to its strength/stiffness?
But that would be fibre (epoxy/carbon) planes, no?
TIA,
* * * Steel is heavy and will totally screw up your compass. Also a
pain to cut instrument holes into. As another has recommended, 6061T6
is probably the best, but maybe .050" thick. Too thin and you'll have
to start riveting angles to the back to stiffen it. Too hard (2024)
and it'll crack. Too soft (5052) and it's gummy to work with and bends
far too easily.
* * * * * What do the drawings call for? In many airplanes the panel
is a part of the primary structure, and making substitutions isn't
wise.
Perhaps I ought to have explained: I am not (yet)
building an aircraft panel. I consider building an electrical
control panel for a project totally separate from aviation;
but I fancied making it more or less like an aircraft panel.
A poor man must learn to be happy with small pleasures!
So ok, I'll go for 1,5 mm aluminium but am not sure
what grades might be available here in Belgium,
not even sure we have the same codification.
But the application isn't really critical so I don't care too much.
Allow me the next question: how to finish the panel?
I suppose it is cut to size, then drill/cut for instruments
and fuses and switches and whatever else, deburr,
perhaps sand or polish? then paint, then assemble, then install?
What paints to use? I'd love the clear blue/turquoise
one sees on cockpit snaps of USSR military planes...
Thanks to all who responded!- Hide quoted text -
- Show quoted text -
..090 6061T6 aluminum for me. Here's my web page on my panel build.
Should give you a "step by step" guide:
http://www.rocket-boys.com/panel.htm
Old September 18th 08, 09:26 PM posted to rec.aviation.homebuilt
oilsardine[_2_]
== in Europe take AlMgSi1.5, comes close
== make an Autocad drawing and take it to the waterjet cutter
Old September 13th 08, 05:34 AM posted to rec.aviation.homebuilt
Jim Chandler
Most people use aluminum. It's lighter even though thicker. .030 should do.
"jan olieslagers" wrote in message
TIA,
Instrument Panel ccwillwerth Home Built 7 February 9th 06 02:15 PM
DG-300 instrument panel [email protected] Soaring 14 January 29th 06 02:48 PM
LS 6 b instrument panel John Brenann Soaring 4 November 19th 05 04:37 AM
Instrument Panel Paint [email protected] Owning 0 May 1st 05 02:54 PM
ASW20A instrument panel available goneill Soaring 1 November 2nd 04 08:32 AM
