Preflighting my plane - Video
Old September 20th 08, 02:05 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default Preflighting my plane - Video
" wrote in
On Sep 19, 5:00*pm, Bertie the Bunyip wrote:
" wrote in news:7b0f558c-
epends on the type, but tin tanks are no kind of insurance against it.
Try
it sometime. Drain some fuel, if there's some water, drain it all out
and then shake the airplane. Pretty sure you;ll get some more.
BTW, you're tanks are more than likely aluminum. I could be wrong,
but I'
ve
never seen stainless tanks in any airplane.
Bertie
Surprisingly, I can count on one hand getting water in the fuel and my
bet how it got in there is my carelessness on taking the caps off
after a rain and the residual rain underneath the lever sneaks into
the tank. But I will give what you say above a try, nothing gain,
nothing loss but the adventure.
Yeah, it's rare enough. depends on the airplane and where you live.
We had an accident near where I live with an engine failure on takeoff
after some very heavy rain. The guys were OK, but the airplane was
destroyed ( Cherokee). There was no problem found with the engine. I think
thye might have had this problem.
Bertie
Old September 20th 08, 03:11 PM posted to rec.aviation.piloting
Mick[_2_]
Not quite sure I understand the above??
Obviously has something to do with the sump jiggies, and mine are
"spring loaded" and pressed in using the outer edge of the fuel sump
diddy rather then a center piece like a Cessna.
Does the style of sump make any difference?
It's hard to imagine were every divot, rib, baffle, fitting or fastener
might be in a tank. Although the drain is in the designed low point,
droplets of water can cling to imperfections elsewhere. Condensation also
collects in the tanks unwetted areas, and doesn't join the mix until
splashed.
Carefully rocking the wings, from the wing tip, sloshes the fuel around and
helps rinse trapped droplets to the drain area.
Old September 20th 08, 03:24 PM posted to rec.aviation.piloting
Mick[_2_]
| " wrote in news:7b0f558c-1f70-462f-
| On Sep 19, 3:47 pm, Bertie the Bunyip wrote:
| No, nothing to do with the sump drains themselves. The sump area is a
| small depession at the bottom of the tank. All water in the tank should
| go there by design. However most tanks have small imperfections in them
| where water can get into and stick there. You do a nice calm walkaround
| and drain your fuel and then when you start taxying, the water becomes
| dislodged and gets into a feed port. With some designs, this can add up
| to a lot of water...
| Gotchya, gotchya and gotchya, never thought of what you say, and makes
| perfect sense.
| Tanks I have are "stainless steel" and not bladders, so I **think**I
| have a lesser risk of water settling where it shouldn't be but like
| you say, a good shake would be prudent to better assure the water
| indeed does settle down to the sumps so it gets sumped out.
| Depends on the type, but tin tanks are no kind of insurance against it.
Try
| it sometime. Drain some fuel, if there's some water, drain it all out and
| BTW, you're tanks are more than likely aluminum. I could be wrong, but
I've
| Bertie
Mick[_2_]
|a wrote in
| On Sep 19, 6:00 pm, Bertie the Bunyip wrote:
| " wrote in
| is a small depession at the bottom of the tank. All water in the
| tank shoul
| d
| the
| m
| walkaroun
| d
| becomes dislodged and gets into a feed port. With some designs,
| this can add u
| p
| makes perfect sense.
| **think**I have a lesser risk of water settling where it shouldn't
| be but like you say, a good shake would be prudent to better assure
| the water indeed does settle down to the sumps so it gets sumped
| out.
| it. T
| ry
| but I'
| ve
| Bertie
| Big design flaw on the early M20J (Mooney 201) was the fuel tanks were
| wet wing, and the seam sealant failed. If one smells gas in flight it
| is NOT good, and we did. Huge pain in the ass to reseal. The other
| thing about those tanks is the fuel caps were a little tricky to put
| back right (this was back in the old days when the fuel truck would
| come to the airplane) and if they were not put on right rain got in
| big time. Nothing like draining a tank in a rain storm while wearing a
| suit!
| Yeah, I know the caps you're talking about. They were a bitch to get on.
| I sem to remember a lot of Mooneys having bladders, though. Earlier ones
| maybe? Maybe wood wing airplanes?
| Bertie
Mick[_2_]
| " wrote in
| Try
| but I'
| ve
| Bertie
| Bertie
Old September 20th 08, 03:45 PM posted to rec.aviation.piloting
On Sep 20, 1:11*am, Gezellig wrote:
I look and feel for these. What about places you can't either touch or
see?
Heh heh, you do more then I did regarding looking for the wrinkling of
the skin as I never thought about it until Bertie brought it up,
soooo, you probably will have to "trust" what you don't see, don't
hurt.
Getting some good stuff out of this latest video to add to my "tool
kit" of being a safer pilot from here and a couple other forums I
shared the video with.
Old September 20th 08, 06:38 PM posted to rec.aviation.piloting,alt.usenet.kooks,alt.bass.alt.alien.vampire.flonk.flonk.flonk,rec.arts.poetry
Bertie the Bunyip[_28_]
"Mick" @_#`~#@.^net wrote in :
| " wrote in
| news:62dfd245-3863-4a15-90c1-a645f988c237
@y38g2000hsy.googlegroups.com
| it. Try
| out and then shake the airplane. Pretty sure you;ll get some more.
| but I'
| ve
| Bertie
| my bet how it got in there is my carelessness on taking the caps
| off after a rain and the residual rain underneath the lever sneaks
| into the tank. But I will give what you say above a try, nothing
| gain, nothing loss but the adventure.
| takeoff after some very heavy rain. The guys were OK, but the
| airplane was destroyed ( Cherokee). There was no problem found with
| the engine. I think thye might have had this problem.
| Bertie
Thanks, Wasn't sure if this propogated fully.
You're performing a public service afer all by ensuring my wisdom
reaches around the globe.
Bertie
Plane 172 fun video [email protected] Piloting 23 February 2nd 08 01:59 AM
Video of building a plane in the air Jim Logajan Home Built 1 November 20th 06 10:43 PM
Video from the plane Jacob Olsen Soaring 6 December 16th 05 05:23 PM
A Plane is Born Video FLYWITHJAY Home Built 0 July 17th 04 02:27 PM
Preflighting has changed for ever! Robert M. Gary Piloting 9 March 31st 04 08:20 PM
