Preflighting my plane - Video
Old September 19th 08, 09:00 PM posted to rec.aviation.piloting
Default Preflighting my plane - Video
Today's flight, figured to video how I preflight my plane. Comments
here or on the video most welcomed. Always nice to hear input to make
me a safer pilot!
Preflighting an airplane Part 1
Walking to the airplane - Preflight inside the cockpit
http://www.youtube.com/watch?v=7Jnz8ikkAlA
Preflighting an airplane Part 2
Preflighting the airplane walk around.
http://www.youtube.com/watch?v=SAhF-x1kvpQ
Preflighting an airplane Part 3
Inside the plane after preflight.
http://www.youtube.com/watch?v=a4mkhUFHWa0
Old September 19th 08, 09:43 PM posted to rec.aviation.piloting
On Sep 19, 3:28*pm, Bertie the Bunyip wrote:
One, as you walk around, stand back every so often and look at the
airframe. You're looking for wrinkles in the skin or anything else that
might look strange.
Definately good one for the checklist. Never thought of this and
while I always step back after doing the entire check list for a last
once over (long video - part 2, you will see me do this at the very
end) I never thought about skin wrinkles.
mounting holes and such, and perhaps more importantly, it will get any fuel
that might be hiding in the fuel tank away from the sump out of it's
depression and into the sump.
Not quite sure I understand the above??
Obviously has something to do with the sump jiggies, and mine are
"spring loaded" and pressed in using the outer edge of the fuel sump
diddy rather then a center piece like a Cessna.
Does the style of sump make any difference?
Old September 19th 08, 09:47 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
" wrote in
that might look strange.
any fu
el
No, nothing to do with the sump drains themselves. The sump area is a
small depession at the bottom of the tank. All water in the tank should
go there by design. However most tanks have small imperfections in them
where water can get into and stick there. You do a nice calm walkaround
and drain your fuel and then when you start taxying, the water becomes
dislodged and gets into a feed port. With some designs, this can add up
to a lot of water...
Bertie
Old September 19th 08, 10:31 PM posted to rec.aviation.piloting
Gotchya, gotchya and gotchya, never thought of what you say, and makes
perfect sense.
Tanks I have are "stainless steel" and not bladders, so I **think**I
have a lesser risk of water settling where it shouldn't be but like
you say, a good shake would be prudent to better assure the water
indeed does settle down to the sumps so it gets sumped out.
Old September 19th 08, 11:00 PM posted to rec.aviation.piloting
" wrote in news:7b0f558c-1f70-462f-
perfect sense.
Depends on the type, but tin tanks are no kind of insurance against it. Try
it sometime. Drain some fuel, if there's some water, drain it all out and
then shake the airplane. Pretty sure you;ll get some more.
BTW, you're tanks are more than likely aluminum. I could be wrong, but I've
never seen stainless tanks in any airplane.
Bertie
Old September 20th 08, 03:45 PM posted to rec.aviation.piloting
On Sep 20, 1:11*am, Gezellig wrote:
I look and feel for these. What about places you can't either touch or
see?
Heh heh, you do more then I did regarding looking for the wrinkling of
the skin as I never thought about it until Bertie brought it up,
soooo, you probably will have to "trust" what you don't see, don't
hurt.
Getting some good stuff out of this latest video to add to my "tool
kit" of being a safer pilot from here and a couple other forums I
shared the video with.
Plane 172 fun video [email protected] Piloting 23 February 2nd 08 01:59 AM
Video of building a plane in the air Jim Logajan Home Built 1 November 20th 06 10:43 PM
Video from the plane Jacob Olsen Soaring 6 December 16th 05 05:23 PM
A Plane is Born Video FLYWITHJAY Home Built 0 July 17th 04 02:27 PM
Preflighting has changed for ever! Robert M. Gary Piloting 9 March 31st 04 08:20 PM
