On Dec 6, 9:39*pm, Tuno wrote:
To answer my original question more accurately ... the manual indicates the routing of the pressures, but does not describe the implementation. As it happens, my 29 has small (maybe 2.5 or 3mm OD) tubing from behind the instrument panel to under the seatpan, where they step up to the larger size using the same kind of insert adapter found on my O2 system controller. The tubes going aft from there do not hold a vacuum (with the multi- probe thoroughly sealed and inserted). I'm wondering (after talking to CH) if the O-rings in the multi-probe's receiver were damaged ... 2NO What is it the engineers say? One test is worth a thousand theories. I'd put the probe in place then apply pressure with a syringe as you watch the airspeed indicator. No indication = massive leak or pinched line. Open the canopy and see what it reads.........keep checking till you find the problem. I'd leak test all lines while I was at it. I use a separate ASI that is T'ed to the syringe then hooked to the line I'm checking. All should hold 100 knots on the ASI for 60 seconds. JJ |
JJ's suggestion (from bucket loads of experience) mirrors the
instructions Reichmann put in the back of "Streckensegelflug". And always a good idea to test thoroughly before altering. Ted, in your first post you mention repair. If that repair was a broken tail boom, there's a chance of a splice inside the fuselage to keep you entertained. Last leak like this I had turned out to be an almost hidden coupling in the area where the tubing enters the instrument panel. Possibly a failed fix of a previous problem! Jim On Dec 7, 5:57 am, JJ Sinclair wrote: What is it the engineers say? One test is worth a thousand theories. I'd put the probe in place then apply pressure with a syringe as you watch the airspeed indicator. No indication = massive leak or pinched line. Open the canopy and see what it reads.........keep checking till you find the problem. I'd leak test all lines while I was at it. I use a separate ASI that is T'ed to the syringe then hooked to the line I'm checking. All should hold 100 knots on the ASI for 60 seconds. JJ |
To answer my original question more accurately ... the manual indicates the routing of the pressures, but does not describe the implementation. As it happens, my 29 has small (maybe 2.5 or 3mm OD) tubing from behind the instrument panel to under the seatpan, where they step up to the larger size using the same kind of insert adapter found on my O2 system controller. The tubes going aft from there do not hold a vacuum (with the multi- probe thoroughly sealed and inserted). I'm wondering (after talking to CH) if the O-rings in the multi-probe's receiver were damaged ... 2NO Thank goodness it's December Ted. If the multi-probe got tweaked in the accident then it's possible that the fittings are AFU, but I'd be surprised if it actually happened. You might try just plugging the entire fitting with the probe removed to at least eliminate the possibility of a tubing leak inside the fin/tailboom. You'll need to clamp the other lines too. I am curious about the procedure for replacing the O-rings as it seems nearly impossible from casual inspection. Any experts out there on how to do it? I too have had the infamous Schliecher canopy hinge tubing kink problem on a hot day in Arizona. The symptom was a zero indication on climb and a wildly inaccurate airspeed. I think that means a kinked static line. I used GY's cure - a 4" piece of 1" OD tubing split down the side and wrapped around all the pneumatic tubes where they bend as the canopy closes. I secured the tube with tie-wraps. It's still there and working today. Turns out the desert temperatures make the tubes just enough softer that they fold under the pressure when you shut the hatch. Fixing it in 112 degrees and full sun may have been the sweatiest experience of my life. I am perplexed but the change in tubing size you describe Ted. Do you have to up-gauge the tubes at the panel to fit the barb connectors on your instruments? Best of luck - glad 2NO's back home. 9B |
9B,
I assume by now you've read my post describing the problem. My 29 has 3mm OD (polyethylene?) tubing going from the fore end of the area under the glare shield to under the seatpan. After reading yours and GY's accounts, my guess is that the factory addressed the problem my using the smaller polyethylene tubing for this part of the glider, which does much better under heat and stress than the larger tubing. It came from the factory with adapters that step the smaller tubing up to the larger size, both under the seatpan and behind the instr panel. They're just like the connections on my MH EDS controller, where you depress a flat ring to disengage the inserted tubing. I'd like to know the proper nomenclature for that tubing and adapter. Glider is back home and flies great! 2NO |
On Dec 8, 11:46*am, Tuno wrote:
9B, I assume by now you've read my post describing the problem. My 29 has 3mm OD (polyethylene?) tubing going from the fore end of the area under the glare shield to under the seatpan. After reading yours and GY's accounts, my guess is that the factory addressed the problem my using the smaller polyethylene tubing for this part of the glider, which does much better under heat and stress than the larger tubing. Interesting. I check in a few times a year to see what new tech notes are out but didn't see one on this. Anyone have a new 28 with this configuration? Andy |
On Dec 8, 11:19*am, Andy wrote:
On Dec 8, 11:46*am, Tuno wrote: 9B, I assume by now you've read my post describing the problem. My 29 has 3mm OD (polyethylene?) tubing going from the fore end of the area under the glare shield to under the seatpan. After reading yours and GY's accounts, my guess is that the factory addressed the problem my using the smaller polyethylene tubing for this part of the glider, which does much better under heat and stress than the larger tubing. Interesting. *I check in a few times a year to see what new tech notes are out but didn't see one on this. Anyone have a new 28 with this configuration? Andy Jeez Ted - clearly the problem is that probe2 is bent at a 45-degree angle. No way you will get good TE that way. I'd recommend you straighten it out. ;-) Glad you're back in the air. 9B |
Tuno wrote:
9B, I assume by now you've read my post describing the problem. My 29 has 3mm OD (polyethylene?) tubing going from the fore end of the area under the glare shield to under the seatpan. After reading yours and GY's accounts, my guess is that the factory addressed the problem my using the smaller polyethylene tubing for this part of the glider, which does much better under heat and stress than the larger tubing. It came from the factory with adapters that step the smaller tubing up to the larger size, both under the seatpan and behind the instr panel. They're just like the connections on my MH EDS controller, where you depress a flat ring to disengage the inserted tubing. I'd like to know the proper nomenclature for that tubing and adapter. Glider is back home and flies great! 2NO I think the fitting may be referred to as a "push fitting". Perhaps because all you have to do is "push" the tubing into the fitting. |
This morning's trouble-shooting began by testing the tubes from the
seatpan back to the fin. With the multi-probe inserted and all holes sealed, each tube (tested individually) held positive and negative pressures. That was good news -- no problems hiding in the tail boom. Next I tested each of the four tubes from the panel to the seatpan. (Two are static -- one from the multi-probe (for the vario(s)) and one from the tailboom (for the ASI and ALT).) Again, each tube tested with positive results. This was encouraging because it demonstrated no problems with any plumbing. It was disconcerting because of the big question mark it left. Next I reconnected the tubes under the seatpan and began testing each tube from the instrument to the multi-probe. The first test or two went well but I soon discovered that when the probe inlet was sealed off without the probe, all tubes held pressure as a group, but if I inserted the probe (with all inlets taped up), air blown into one tube would exit the others. This pointed, of course, to a problem with the probe or its receptacle. The answer to the mystery can be found in the photographs at www.justsoar.com/public/2NO/. (I will resume typing in two minutes so you can examine the evidence and see if you can figure it out yourself.) .... DING welcome back. The original multi-probe, an ESA-Systems model (http://www.esa- systems.com/data/multis/mni-un.html), was badly mangled in the (ahem) hard landing (as you can see in the photo with both probes). But if you look closely at the photos, you'll see that the decal (with the insertion "STOP" line) in the new probe is a full 3cm closer to the aft end than the same decal on the original probe. Both probes have the same ESA model number on the decals. Except for locations of the decals and the gently used condition of the original, the two probes are absolutely identical. The fit is snug enough that just the decal is enough to firmly arrest the insertion of the probe. I carefully measured the distance on the original probe, removed the decal on the new one, and marked the correct stop point with a wrap of gap tape. Inserting the probe, I encountered some resistence with a cm to go, but that was just the last O-ring, a gentle push and all was right with the world. Dang this eggnog is good. Big, big thanks to Cliff "CH" Hilty for driving down from Prescott to assist me with the plumbing, that guy can take a cinder block and fence post and make them fly. ~ted/2NO |
I'm sure youve already checked it but low ASI readings are often
caused by the triple probe being 1/4 inch short of fully home in the socket. On Sat, 6 Dec 2008 16:48:26 -0800 (PST), Tuno wrote: I've dispatched this question to the dealer and factory, but need to troule-shoot quick so trolling here. I have a 2008 Schleicher ASG29 with confused instruments following some repair work. My question is, in its factory configuration, are the three lines from the multi-probe free of joints, splices or connectors all the way to the instrument panel? (I'm sure this is the case for the TE and Ptot lines, it's the static I'm curious about.) I'm a little unclear about the total Pstatic implementation, with both an E-Systems multi-probe and what appear to be static ports on the fuselage a meter north of the rudder. Are the two combined? ~ted/2NO ps the symptoms a varios appear to operate without TE compensation and the ASI is not correct, mostly floating around 40-50% of what it should be reading. Altitude readings correct on altimeter, 302 and LX7007. The LX's vario's average always read 0.0, even when climbing it what felt like very strong wave. |
PANEL PLUMBING | Travis Beach | Soaring | 3 | December 5th 07 10:00 PM |
PANEL PLUMBING | Travis Beach | Soaring | 0 | December 5th 07 02:16 PM |
Pitot tube question | Doc Font | Home Built | 2 | January 24th 05 04:28 AM |
Plumbing for a CAI 302 + Schuemann B-Box | Mark Grubb | Soaring | 1 | June 12th 04 03:39 PM |
Tube Cluster Weld Question | Dick | Home Built | 6 | January 17th 04 12:10 AM |
