#11
"Tamas Feher" wrote in message ... Hello, Uranium is a heavy metal similar in toxicity to lead and cadmium and is used in glassmaking and pottery for colouring. Uranium is unique, because it burns at high temperatures and turns into a smoke-like very fine dust. This is not unique This dust goes deep into your lungs while you breathe and causes cancer due to a combination of radiation and chemical toxicity. In fact cancer due to Uranium ingestion requires heavy exposures the IDLH of Uranium is 10 mg /m3 , about the same as Cadmium and Nickel. This does not happen with tungsten (wolfram) or lead. Cadmium with similar toxicity to uranium is also pyrophoric when finely divided as are many metals. Cadmium is a known carcinogen Question: is there any shooting range inside the CONUS with live DU pratice? Regards: Tamas Feher. Yes, Aberdeen proving grounds and Yuma at a minimum. Keith |
On Fri, 7 May 2004 16:30:54 +0200, "Tamas Feher" wrote:
Hello, Uranium is a heavy metal similar in toxicity to lead and cadmium and is used in glassmaking and pottery for colouring. Uranium is unique, because it burns at high temperatures and turns into a smoke-like very fine dust. This dust goes deep into your lungs while you breathe and causes cancer due to a combination of radiation and chemical toxicity. This does not happen with tungsten (wolfram) or lead. Question: is there any shooting range inside the CONUS with live DU pratice? Regards: Tamas Feher. Do some research. All metals can burn, most at very high temps. There is no, rpt no, research that finds that DU causes cancer. Al Minyard |
"Thomas J. Paladino Jr." wrote in message ... snip All shooting ranges in the US (and NATO) have stopped using heavy-metals in all of their training rounds (including small arms). DU was never used as a training round to begin with because it is too valuable. The M1 sabot practice round uses a steel core and behaves exactly as the live round would. Not quite. As you noted, lead is also a "heavy metal", and it is still used in small arms rounds that are fired during training, albeit in fully jacketed form. Brooks |
"Kevin Brooks" wrote in message ... "Thomas J. Paladino Jr." wrote in message ... snip All shooting ranges in the US (and NATO) have stopped using heavy-metals in all of their training rounds (including small arms). DU was never used as a training round to begin with because it is too valuable. The M1 sabot practice round uses a steel core and behaves exactly as the live round would. Not quite. As you noted, lead is also a "heavy metal", and it is still used in small arms rounds that are fired during training, albeit in fully jacketed form. I actually read recently that all NATO small arms rounds will no longer be using lead in training, and eventually active service; or at least that it was being phased out. The so-called 'green bullet'; it uses recycled tungsten tin or nylon jacketed in copper rather than lead. This isn't the original artcle that I read, but it came up on a search I just did and has some good info: http://www.firearmsid.com/Feature%20...eenBullets.htm |
"Thomas J. Paladino Jr." wrote in message ... "Kevin Brooks" wrote in message ... "Thomas J. Paladino Jr." wrote in message ... snip All shooting ranges in the US (and NATO) have stopped using heavy-metals in all of their training rounds (including small arms). DU was never used as a training round to begin with because it is too valuable. The M1 sabot practice round uses a steel core and behaves exactly as the live round would. Not quite. As you noted, lead is also a "heavy metal", and it is still used in small arms rounds that are fired during training, albeit in fully jacketed form. I actually read recently that all NATO small arms rounds will no longer be using lead in training, and eventually active service; or at least that it was being phased out. The so-called 'green bullet'; it uses recycled tungsten tin or nylon jacketed in copper rather than lead. Yep, they have been leaning that way--but last I knew the older rounds are still being fired. Note that most of the ranges mentioned as being closed were the indoor variety (just about every reserve/Guard armory had an indoor range, the vast majority of which were closed and underwent remediation to handle the lead threat). I believe they already have the tungsten penetrator in service for the 5.56mm (IIRC it is supposed to have better penetration capability than the regular FMJ), but the 9mm are still firing FMJ's, as are I believe most of the 7.62mm and .50 cal (that is a LOT of ammo to replace...). I'd also be surprised if the military double-ought buckshot loads for the 12 ga shotguns are anything other than lead... Brooks This isn't the original artcle that I read, but it came up on a search I just did and has some good info: http://www.firearmsid.com/Feature%20...eenBullets.htm |
In article , "Thomas J. Paladino
Jr." wrote: snipped (Knew most of this) All shooting ranges in the US (and NATO) have stopped using heavy-metals in all of their training rounds (including small arms). DU was never used as a training round to begin with because it is too valuable. The M1 sabot practice round uses a steel core and behaves exactly as the live round would. Interesting. As a re-loader, I'm curious how a steel core replicates the sectional density and ballistic coefficient of DU and therefore the ballistics of the round? After all, DU is about 2.33 times the density of steel (I used values for Maraging steel, but 300 series is the same, and higher than alloy steels), so to keep the same mass the round must be bigger, but that would degrade it's areodynamics. Can you elucidate? I don't understand. -- Harry Andreas Engineering raconteur |
"Harry Andreas" wrote in message ... In article , "Thomas J. Paladino Jr." wrote: snipped (Knew most of this) All shooting ranges in the US (and NATO) have stopped using heavy-metals in all of their training rounds (including small arms). DU was never used as a training round to begin with because it is too valuable. The M1 sabot practice round uses a steel core and behaves exactly as the live round would. Interesting. As a re-loader, I'm curious how a steel core replicates the sectional density and ballistic coefficient of DU and therefore the ballistics of the round? After all, DU is about 2.33 times the density of steel (I used values for Maraging steel, but 300 series is the same, and higher than alloy steels), so to keep the same mass the round must be bigger, but that would degrade it's areodynamics. Can you elucidate? I don't understand. It does not have to. When firing the training rounds from the M1A1, the ballistic computer is set for the APDS training round, just as it is set differently for the HEAT round vice the DU APDS-FS--the computer adjusts the aim point accordingly. Brooks -- Harry Andreas Engineering raconteur |
| Thread Tools | |
| Display Modes | |
| ~ DEPLETED URANIUM - AMERIKA'S 'OK TO USE' WMD ~ | B2431 | Military Aviation | 2 | March 27th 04 10:39 AM |
| Japanese firm sold Libya uranium conversion plant | Dav1936531 | Military Aviation | 2 | March 17th 04 04:47 PM |
| Mk 84 iron bomb version with depleted uranium? | MCN | Military Aviation | 8 | October 3rd 03 02:56 AM |
