Toxic Depleted Uranium Rounds... for Brooks
Old May 5th 04, 07:24 PM
robert arndt
Default Toxic Depleted Uranium Rounds... for Brooks
http://www.citizen-soldier.org/CS09-uranium.html
It's toxic, moron... and the Germans can do just as much damage with
their tungsten rounds
Believe me, the L55 main gun plus DM-53 ammo will ruin your day.
At least the Germany Army isn't poisoning its own troops by using
"partially-depleted (correct term)uranium"...
Rob
Old May 5th 04, 07:52 PM
Chad Irby
Not really. The sintered-tungsten process just isn't as good.
....because Rheinmetall invented a sintered-tungsten round that, while
not as good as a DU penetrator, is bought by the German armed forces to
prop up their business for exports.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Old May 5th 04, 08:15 PM
Thomas J. Paladino Jr.
"robert arndt" wrote in message
m...
LOL....
How about instead of using a radical leftist anti-war site with a political
agenda as a source, we use a scientific one?
Ok then:
http://www.globalsecurity.org/milita...nitions/du.htm
A few pertinant quotes, in case some people don't want to read the entire
article:
"The Agency for Toxic Substances and Disease Registry (ATSDR) for the
Department of Health and Human Services estimates there are an average of 4
tons of uranium in the top foot of soil in every square mile of land. A
heavy metal similar to tungsten and lead, uranium occurs in soils in typical
concentrations of a few parts per million (equivalent to about half a
teaspoon of uranium in a typical 8-cubic yard dump truck-load of dirt)."
"The Department of Energy (DOE) recently reported that the DU it provided to
DoD for manufacturing armor plates and munitions may contain trace levels (a
few parts per billion ) of contaminants including neptunium, plutonium,
americium, technitium-99 and uranium-236. From a radiological perspective,
these contaminants in DU add less than one percent to the radioactivity of
DU itself."
"The major health concerns about DU relate to its chemical properties as a
heavy metal rather than to its radioactivity, which is very low. As with all
chemicals, the hazard depends mainly upon the amount taken into the body.
Medical science recognizes that uranium at high doses can cause kidney
damage. However, those levels are far above levels soldiers would have
encountered in the Gulf or the Balkans."
"Most soldiers and civilians will not be exposed to dangerous levels of
depleted uranium."
"...in certain circumstances the exposures may be high and there would be a
risk of heavy metal poisoning that could lead to long-term kidney damage for
a few soldiers, as well as the increased risk of lung cancer. A small number
of soldiers and civilians might suffer kidney damage from depleted uranium
if substantial amounts are breathed in, or swallowed in contaminated soil
and water."
"Because depleted uranium emits primarily alpha radiation, it is not
considered a serious external radiation hazard. The depleted uranium in
armor and rounds is covered, further reducing the radiation dose. When
breathed or eaten, small amounts of depleted uranium are carried in the
blood to body tissues and organs; much the same as the more radioactive
natural uranium. Despite this, no radiological health effects are expected
because the radioactivity of uranium and depleted uranium are so low."
Hmmm.... so it seems that the actual danger from DU is not due to it's
'radioactivity' as some hysterical critics would like us to believe, but
rather from it's properties as a heavy metal (which in and of itself is not
much more than any other heavy metal one might encounter on the battlefield,
including tungsten carbide), and then only by directly ingesting an
abnormally large amount of the stuff.
Perhaps we should make our tank rounds out of wood?
And one more quote:
"In military applications, when alloyed, Depleted Uranium is ideal for use
in armor penetrators. These solid metal projectiles have the speed, mass and
physical properties to perform exceptionally well against armored targets.
DU provides a substantial performance advantage, well above other competing
materials. This allows DU penetrators to defeat an armored target at a
significantly greater distance. Also, DU's density and physical properties
make it ideal for use as armor plate. DU has been used in weapon systems for
many years in both applications."
Apparantly, the Germans can do nowhere near the amount of damage with their
tungsten rounds. Oh and here's another good one:
"US forces also use DU to enhance their tanks' armor protection. In one
noteworthy incident, an M1A1 Abrams Main Battle Tank, its thick steel armor
reinforced by a layer of DU sandwiched between two layers of steel, rebuffed
a close-in attack by three of Iraq's T-72 tanks. After deflecting three hits
from Iraq's tanks, the Abrams' crew dispatched the T-72s with a single DU
round to each of the three Iraqi tanks."
Yep, I think that we'll keep our DU right where it is.
Old May 5th 04, 08:24 PM
Kevin Brooks
m...
You are proving yourself more stupid every time you post--a major
accomplishment, being as you already had the stupidity bar set rather
high... The DU I was referring to is used in the *armor composition* (it
improves resistance to KE projectiles) of the later M1 series tanks, not
that which is in the APDS-FS rounds. Idiot.
Brooks
Rob
Old May 5th 04, 10:06 PM
Ragnar
m...
Actually, they can't. DU is more efficient than tungsten at penetrating
modern armor. Even with a velocity advantage using the L55 gun, tungsten
doesn't match up.
Yes, I'm sure it will. Just not as efficiently as DU.
Old May 6th 04, 09:40 AM
Keith Willshaw
m...
Rob
Unless the troops in question are shaving slivers
of the penetrator and eating them its not
poisoning those in the US military either.
Uranium is a heavy metal similar in toxicity
to lead and cadmium and is used in
glassmaking and pottery for colouring.
Keith
Old May 6th 04, 02:42 PM
Matt Wiser
Well done, Thomas. I agree completely. Mention uranium (depleted or otherwise)
to the loony left and they go ballistic. Seems some folks are more concerned
with the casualties inflicted on the enemy than the casualties inflicted
on us....loyalty questions, anyone?
message
om...
will ruin your day.
LOL....
Ok then:
article:
to about half a
DU itself."
depleted uranium."
and water."
wood?
And one more quote:
one:
it is.
Posted via www.My-Newsgroups.com - web to news gateway for usenet access!
Matt Wiser
message
om...
doesn't match up.
will ruin your day.
as DU.
Correct: two or three rounds of tungsten to do the job of one DU round.
Old May 7th 04, 03:30 PM
Tamas Feher
Hello,
Uranium is unique, because it burns at high temperatures and turns into
a smoke-like very fine dust. This dust goes deep into your lungs while
you breathe and causes cancer due to a combination of radiation and
chemical toxicity.
This does not happen with tungsten (wolfram) or lead.
Question: is there any shooting range inside the CONUS with live DU
pratice?
Regards: Tamas Feher.
Old May 7th 04, 04:08 PM
"Tamas Feher" wrote in message
Hello,
chemical toxicity.
That is completely and totally untrue for a number of reasons.
First of all, most of this 'dust' you're talking about self-ignites on
contact with the air.
Second of all, ALL the physiological harm one may experience from DU is
related to it's properties as a heavy metal, NOT it's alleged
'radioactivity'. In reality, it is less radioactive than dirt.
They are heavy metals, so they pose the exact same risk as DU.
pratice?
All shooting ranges in the US (and NATO) have stopped using heavy-metals in
all of their training rounds (including small arms). DU was never used as a
training round to begin with because it is too valuable. The M1 sabot
practice round uses a steel core and behaves exactly as the live round
would.
~ DEPLETED URANIUM - AMERIKA'S 'OK TO USE' WMD ~ B2431 Military Aviation 2 March 27th 04 09:39 AM
Japanese firm sold Libya uranium conversion plant Dav1936531 Military Aviation 2 March 17th 04 03:47 PM
Mk 84 iron bomb version with depleted uranium? MCN Military Aviation 8 October 3rd 03 01:56 AM
