I have problem. I correct the aileron the wrong way at takeoff
Old January 24th 09, 05:59 PM posted to rec.aviation.soaring
Ian
Default I have problem. I correct the aileron the wrong way at takeoff
On 20 Jan, 13:43, "vaughn" wrote:
* *This is getting rather far afield and has little or nothing to do with
flying, but turning a motorcycle is not as simple a process as you may
think. *Those who have any time on heavy motorcycles instinctivly apply
pressure to the handlebars OPPOSITE to the direction of the intended turn..
Because of the gyroscoptic precession of that big, heavy front wheel, this
tilts the bike, and it is the tilt that does the actual turning.
Humm. Bike going forward. Rotation vector of front wheel goes right to
left (using right-handed axis system). Push left handlebar forwards.
Front of rotation vector moves forwards. Precession vector is change
in rotation vector: front to back. Which is a roll to the right.
In other words, the affect of precession would roll in the direction
of steer.
Ian
Old January 24th 09, 06:04 PM posted to rec.aviation.soaring
Ian
On 20 Jan, 14:39, bildan wrote:
A useful rethink is to consider that the wing runners job is to
BALANCE the glider laterally not to just "level the wings". *That way
the wing won't instantly fall when it's released. * The runner should
find the 'zero force' point where the glider is perfectly balanced
into any crosswind and run the wing at that angle.
The pilot should let the wing runner do his job by holding the
ailerons exactly neutral until it's clear the runner is no longer
holding the wing - usually at "three Mississippi" and only then take
over roll control.
I think these two points are in contradiction. If the wing would fall
when released unless the pilot did something, it wasn't balanced.
As a wing runner I respond to any wing tip forces. Pre-take off, if my
tip is pushing down, I will let it go down, to the ground of
necessary, till the pilot uses aileron to cancel the forces, at which
point I will keep the wings (a) level and (b) balanced.
I expect the same when I'm the pilot.
This is particularly important when winch launching, as the pilot will
experience any unbalanced roll forces within a second or three of the
all out, and have very little time to correct.
Ian
I have problem. I correct the aileron the wrong way at takeoff Todd Soaring 18 January 21st 09 12:19 AM
I have problem. I correct the aileron the wrong way at takeoff bildan Soaring 3 January 19th 09 08:04 PM
I have problem. I correct the aileron the wrong way at takeoff Doug Hoffman Soaring 0 January 19th 09 05:38 PM
Problem on takeoff AAS Simulators 4 September 30th 04 08:39 AM
Flap/aileron don't line up -- always a problem? Ben Jackson Owning 4 April 13th 04 01:53 AM
