I have problem. I correct the aileron the wrong way at takeoff
Old January 19th 09, 05:38 PM posted to rec.aviation.soaring
Doug Hoffman
Default I have problem. I correct the aileron the wrong way at takeoff
Jack wrote:
Where I would like feedback is if someone has seen such or similar
behaviour, what were the cures, does it go away ?
You might consider a soaring flight simulator such as Condor or SFS-PC
(I have a no longer used SFS-PC that you can have). Then take-off and
land the heck out of it until the proper aileron response is burned
permanently into your brain. You can "damage" the virtual glider all
you want - no worries.
Regards,
-Doug
I have problem. I correct the aileron the wrong way at takeoff bildan Soaring 3 January 19th 09 08:04 PM
Head wind takeoff into rising hills, or crosswind takeoff to open space ?? P S Piloting 7 September 20th 07 07:29 PM
Problem on takeoff AAS Simulators 4 September 30th 04 08:39 AM
Flap/aileron don't line up -- always a problem? Ben Jackson Owning 4 April 13th 04 01:53 AM
Takeoff with a problem? Rocky Piloting 14 January 23rd 04 02:26 PM
