Andy wrote:
On Feb 19, 10:25 am, wrote: Hate external antennas on Composite aircraft. Having worked on a lot of homebuilts, thought someone else might have come up with an alternative mount. I won't help solve your problem but I noted that the Schleicher ASH31Mi will have a transponder antenna mounted inside the fin as standard equipment. Andy This is interesting as it will probably require some large coax to keep the antenna loss to less than 1.5 db which is what was recommended in the microair transponder install manual I have. The RG-58 is limited to 10 ft of coax length and that sure isn't going to get you to the fin from the instrument panel... |
A transponder, such as the Trig Avionics TT21, that has the operating panel
separate from the transmitter/receiver box, will allow the transmitter/receiver to be installed behind the pilot and thus considerably reduce the required cable length (and hence losses) to a tail-fin antenna. At 03:10 20 February 2009, Gary Emerson wrote: Andy wrote: This is interesting as it will probably require some large coax to keep the antenna loss to less than 1.5 db which is what was recommended in the microair transponder install manual I have. The RG-58 is limited to 10 ft of coax length and that sure isn't going to get you to the fin from the instrument panel... |
On Feb 18, 8:06*pm, wrote:
Looking for some suggestions on location of Transponder antenna from people who have them mounted on their Nimbus or DUO. Looking for area for placement of a 3rd Battery. Do you have a location that works well? Thanks in advance for the suggestions. Mark Mahan 2K This is not likely helpful for you Mark, sorry but for the non-carbon types this little gem worked like a charm on my ASW20b, inside the fusalage, out of sight, no drag & very easy to produce and install. http://www.as-segelflugzeuge.de/tm/2...2020%20001.pdf Rick 21 |
Transponder Antenna | Rick Fuller | Soaring | 6 | January 30th 08 06:03 PM |
VHF & Transponder antenna | Steve | Home Built | 1 | December 6th 04 04:29 PM |
Nav Antenna Placement | Jim Pensinger | Home Built | 7 | October 4th 04 09:55 PM |
Oil on transponder antenna | Bob | Owning | 12 | May 9th 04 08:59 PM |
Transponder and antenna | Paolo | Soaring | 1 | March 6th 04 03:32 AM |
