Suppose your tow plane has a placard that says "Max Glider or Banner
Weight: 1000 lbs." You are going to tow a glider with a max gross weight of 1000 pounds. Are you supposed to limit the tensile strength of the tow rope used to 1000 lbs? The regulation specifies that the tow rope should be no less than 80 percent and no greater than 200 percent of the max towed weight. This would allow you to use a rope that has a strength of 2000 pounds but wouldn't that endanger the towing aircraft which has the placarded 1000 pound limit? Would you use a weaker tow rope or a weak link or would you just tow the 1000 pound glider with the rated 2000 pound rope? |
| Thread Tools | |
| Display Modes | |
| Fiberglass cloth weight vs 'finished' weight | Fred the Red Shirt | Home Built | 12 | April 5th 08 05:24 PM |
| Glider Weight/Wing Loading and determing speed for best L/D for a given weight | 65E | Soaring | 3 | January 26th 06 10:26 PM |
| ILS DME strength? | Jim Burns | Instrument Flight Rules | 10 | November 3rd 05 12:10 AM |
| Tubing strength | Ernest Christley | Home Built | 0 | January 17th 04 12:43 AM |
| Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 05:20 AM |
