yes, but this is already linked into the software provided with the
flyWithCE recorder and without saving files and opening any other program the Logger software can go directly to Google earth or you can simply select the flight log and open in SeeYou Strepla or whatever your PC has installed..it's very seamless and simple... tim "Wayne Paul" wrote in message m... You can easily convert any IGC file to GoogleEarth format by using the facility on http://www.gpsvisualizer.com/map_input?form=googleearth Wayne http://www.soaridaho.com/ "uros" wrote in message ... On May 4, 4:57 pm, ContestID67 wrote: On May 3, 3:02 pm, Michael wrote: On May 2, 6:38 am, uros wrote: |
On May 3, 10:02*pm, Michael wrote:
On May 2, 6:38*am, uros wrote: This spring I have released two new products – flyWithCE Flight Recorder and flyWithCE Logbook. That's a cool little device. *Am I reading it right that it has just one button for on/off? *I'm assuming that the way you tell it that you're ending one flight and starting another is by cycling the power? * Is there any LED to indicate when it has a good GPS lock? --Michael Yes there is one led with simple status: - blinking green - searching for satellite fix - green - normal operation - logging - blinking red - low power When you power on the device it will start searching for satellites and after satellite position is determined it will start logging. To finish one flight and start new one you just turn off the device for 30 seconds. I am also updating the software so that it will detect the landing. But still - it is much easier if you cycle the power. Best regards Uros |
yes, when you initially turn it on it blinks red, when it is searching for
GPS it flashes green, once locked on to GPS it goes to solid green and stays there...(I mean it STAYS there !...I've been playing with these for quite a while and they do lock on and stay locked on)....it really is a pretty neat little device.. The new software is also pretty neat, very well planned out and very user friendly...if I have any complaint it would be that it is so small.....not so sure that's a problem! tim "Michael" wrote in message ... On May 2, 6:38 am, uros wrote: This spring I have released two new products – flyWithCE Flight Recorder and flyWithCE Logbook. That's a cool little device. Am I reading it right that it has just one button for on/off? I'm assuming that the way you tell it that you're ending one flight and starting another is by cycling the power? Is there any LED to indicate when it has a good GPS lock? --Michael |
SN-10b EW flight recorder/PDA combination | Jim Archer | Soaring | 5 | November 18th 08 12:30 PM |
In flight recorder | Lou | Piloting | 23 | March 24th 07 12:45 AM |
EW B-Model flight recorder | BDS | Soaring | 12 | August 19th 06 04:39 PM |
US: Flight Recorder Alert | Judy Ruprecht | Soaring | 8 | July 19th 04 09:04 PM |
who does Flight Recorder calibration... | ken ward | Soaring | 4 | March 5th 04 02:28 AM |
