Nose Wheel Steering for Retracts
Old June 25th 09, 05:28 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Default Nose Wheel Steering for Retracts
Dan wrote:
Drew Dalgleish wrote:
On Wed, 24 Jun 2009 08:13:28 -0500, Dan wrote:
I'm looking for a simple design for nose wheel steering for
retractable gear. Any ideas?
Dan, U.S. Air Force, retired
Have you considered just having a castering nosewheel? That's what I
have on my floats and it works pretty well steering with the brakes.
Yes, differential braking is probably the simplest method. I'm not
discarding it, just poking around at options.
Thisis an interesting pic.
http://www.infinityaerospace.com/Oriion_TS_gear.jpg
Not a lot of detail there, but the steerable strut seems to poke thru the top
and would meet with a steering link (tiller/thingie) there.
Old June 30th 09, 03:19 AM posted to rec.aviation.homebuilt
bildan
* I'm looking for a simple design for nose wheel steering for
* Yes, differential braking is probably the simplest method. I'm not
I keep thinking about the "T-Bar" idea. If the rudder pedals had
control horns extending below the pedals hinge line with push rods
attached that extended forward to ball bearing rollers that pushed on
the right and left of the "T-Bar", that would provide the reverse
action to make the steering work right.
A push on the right pedal would pull back the push rod and roller
attached to it and the left pedal would push it's pushrod and roller
forward to turn the "T-Bar" to the right. When the gear was
retracted, the pushrods wouldn't have anything to push on.
If the nose gear strut was directly below the pedals, the pedals could
just have "spurs" with rollers on them.
Old June 30th 09, 12:01 PM posted to rec.aviation.homebuilt
Brian Whatcott
Here's my fantasy design. Two tiny motorbike master cylinders, one on
each rudder pedal, and one slave cylinder on a horn each side of the
nose wheel.
Then the wheel could rotate and retract, and the hose pipes from brake
flexibles, would just flex. (Difficult to make this light enough, I
imagine.)
Brian W
Old June 30th 09, 12:52 PM posted to rec.aviation.homebuilt
Dan[_12_]
the top
nose wheel.
imagine.)
Brian W
I had considered that as I mentioned elsewhere in this thread. The
problems I can't get past is how to cut it out when retracted to reduce
rudder pedal effort and how to not interfere with differential braking.
I would think a castering nose wheel would be best with differential
braking, but one that's being steered could make for some interesting
effects.
Old June 30th 09, 02:53 PM posted to rec.aviation.homebuilt
bildan
have on my floats and it works pretty well steering with the brakes..
the top
I keep thinking about the "T-Bar" idea. *If the rudder pedals had
forward to turn the "T-Bar" to the right. *When the gear was
nose wheel.
*Then the wheel could rotate and retract, and the hose pipes from brake
imagine.)
Brian W
* *I had considered that as I mentioned elsewhere in this thread. The
effects.
Old June 30th 09, 03:02 PM posted to rec.aviation.homebuilt
bildan
the top
nose wheel.
imagine.)
Brian W
effects.
I'm not sure I understand your concern. If the nose gear steering "T-
Bar" is above the nose strut pivot point, it will swing forward away
from the rollers as the nose gear retracts aft. There 'shouldn't' be
any residual extra effort from the pushrods since they wouldn't be
pushing against anything with the gear retracted.
I used to fly a Grumman Tiger with a castering nose wheel. It worked
OK but a long taxi in a crosswind would really heat up the downwind
brake - so much so that maneuvering in the runup area could be
problematic. Brake pads didn't last very long.
Old June 30th 09, 03:04 PM posted to rec.aviation.homebuilt
[email protected][_2_]
A rotating valve. Similar to the one on a single handle kitchen
faucet, or as used to change the control arrangement on some back/
track hoes from Cat to JD?
Leon McAtee
Old July 1st 09, 05:43 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
nose wheel.
imagine.)
Brian W
I kinda suspect it would take a LOT more fluid flow than a brake master
could deliver - and a lot of pressure too.
Old July 1st 09, 12:55 PM posted to rec.aviation.homebuilt
Brian Whatcott
nose wheel.
brake flexibles, would just flex. (Difficult to make this light
enough, I imagine.)
Brian W
There's one FAA design requirement that I can remember: rudder pedals
shall withstand 150 lbs force each, without fail or stretch.
Brian W
F-111 Nose wheel Glenn[_2_] Aviation Photos 0 April 13th 08 09:30 AM
A320 nose wheel steering cam lowes Simulators 0 July 19th 06 12:03 AM
Looking for Cessna 206 or 310 nose wheel fork mikem Aviation Marketplace 0 October 27th 03 04:33 PM
Looking for Cessna 206 or 310 nose wheel fork mikem Owning 0 October 27th 03 04:33 PM
Nose wheel shimmy JFLEISC Owning 2 August 27th 03 03:28 PM
