Magnetic shielding
Old July 20th 09, 12:56 PM posted to rec.aviation.soaring
Leroy Tire
Default Magnetic shielding
Search the Web on Mu-Metal. It can provide some improvement. Won't
necessarily remove all interference, but may be enough to swing the
compass. We had to do this in one of our powered aircraft.
Leroy
Steve Freeman wrote:
I need to mount a compass on the instrument panel glare shield. There
is magnetic interference in most all of the areas that are best for
viewing the compass. Anyone know anything about the various forms of
magnetic shielding available now. On one site alone they sell over 5
different types of material. A compass manufacturer once recommended
this as an easy solution to interference in a power plane but it was a
few years ago and I do not remember the material we used.
Old July 20th 09, 03:22 PM posted to rec.aviation.soaring
Steve Koerner
And Leroy, where are you suggesting that Mr Freeman put this mu-
metal? If you put it anywhere near the compass you will significantly
alter the compass readings. If it happens that he has a speaker on
his panel (or an instrument that has a speaker built-in) then it is
concievable that encompassing the speaker in mu-metal could be helpful
but that is the only scenario I could see for mu-metal. If he does
have a loudspeaker on the panel, a better solution would be to remote
it.
Brian W is correct that if he happens to have power wiring running
near the compass, then get it away from the compass and twist it with
the return.
Alas, why bother? Compasses are relics with all sorts of annoying
foibles.
Steve
Old July 20th 09, 06:30 PM posted to rec.aviation.soaring
Wayne Aspland
it.
the return.
foibles.
Steve
Most pure gliders don't require a compass under EASA, (look in the
equipment list in the type certificate) If you feel you need one just in
case all the GPS kit gives up at the same time, buy one from halfords,
keep it it the pocket and stick it on the canopy when required, well away
from all those nasty (none working) sources of magnetism. More than good
enough to get you home.
Old July 20th 09, 06:31 PM posted to rec.aviation.soaring
Brian Whatcott
it.
the return.
foibles.
Steve
For powered aircraft in particular (including all civil aircraft) a
magnetic compass is mandatory equipment.
Brian W
Magnetic attraction Jim Beckman Soaring 0 June 29th 07 02:29 PM
Why are headings still magnetic? Mxsmanic Piloting 87 September 11th 06 05:34 PM
Magnetic reversal Everett M. Greene Instrument Flight Rules 12 April 9th 05 09:40 AM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 12:08 PM
DIY ignition shielding? Michael Horowitz Home Built 3 September 11th 03 04:28 AM
