Magnetic reversal
Old April 1st 05, 06:27 PM
Everett M. Greene
Default Magnetic reversal
[The following is for idle speculation and mental recreation.]
A recent issue of Scientific American had an article about the
Earth's magnetic field reversals. The article presents some
plausible explanations of the reversals that have occurred
repeatedly throughout geologic times. It also presents some
indications that another reversal is like to happen soon (in
terms of geological time-scale "soon").
It was interesting to contemplate the consequences of a reversal
on our daily lives.
What is ATC going to use for headings?
You may be going geographically northward but the compass is
reading around 180. Which number do you use to describe
what's actually happening?
Airways are prescribed on magnetic courses.
VOR orientations are aligned to magnetic directions.
I imagine that magnetic reversals don't occur overnight, so the
transition would be even more chaotic. We'd get a magnetic
deviation setting along with the local altimeter setting in
clearances?
Since the scenario may be a thousand years or more in the
future ("tomorrow" on the geologic time-scale), none of us
has to worry about it in the next few days.
Old April 1st 05, 10:09 PM
Andrew Gideon
You didn't read the article clearly. It can take from 4,000 years to 9,000
years for the reversal to be completed. But magnetic headings could become
unreliable much more quickly than that.
I've started looking into some form of inertial platform for our club
aircraft. I figure that we may have as little as 1,000 or 2,000 years, so
I'm trying to get this fast-tracked.
- Andrew
Old April 1st 05, 10:23 PM
Icebound
"Everett M. Greene" wrote in message
on our daily lives.
Degrees TRUE.
You throw away the compass and buy a cheap GPS.
But they don't have to be. The radials can be realigned to degrees TRUE.
clearances?
Maybe a little chaotic for VFR types without a GPS for a short while until
they get one.
Magnetic navigation would cease to exist. All nav would be done by GPS.
All directions will be stated in degrees TRUE. Some repainting of runway
numbers required, to match.
Complete changeover in one month, tops.
Old April 1st 05, 11:47 PM
Andrew Gideon
I've trouble believing that KCDW could get through the bidding process to
hire the contractors to choose the artists to recommend paint colors for
the runways in less than a millenium.
- Andrew
Old April 2nd 05, 03:33 AM
J Haggerty
I'm still trying to figure out what the runway numbers would be if you
built crossing runways with the intersection point at the magnetic North
Pole. I guess the runway numbers (magnetic inbound) would be 36, 36, 36,
and 36. Now you're telling me that I should plan on naming them 18, 18,
18, and 18?
Yikes!
Seriously, though, check out the following approach plate and magnetic
variation notes at Barrow, AK. They already have magnetic problems up there.
http://www.naco.faa.gov/d-tpp/0503/05463I6.PDF
JPH
on our daily lives.
clearances?
Old April 2nd 05, 06:25 AM
Icebound
"J Haggerty" wrote in message
news:8wn3e.38$KI6.5@okepread07...
there.
Nothing new. All of Canadian airspace marked on this map
http://webhosts.nunanet.com/~pnagle/ndairspacelg.jpg
as "Northern Domestic Airspace" uses TRUE north headings only and no
magnetic nav due to unreliability.
When operating in this airspace the rules call for the aircraft to be
equipped with
"a means of establishing direction that is not dependent on a magnetic
source"
Old April 2nd 05, 06:50 PM
Everett M. Greene
"Icebound" writes:
equipped with "a means of establishing direction that is not dependent
on a magnetic source"
What does one use for such a means?
Everett M. Greene
Andrew Gideon writes:
Good idea. Mother Nature can be as unpredictable governments.
It's never a bad idea to be prepared for the worst-case scenario.
[Anybody want to make a wild guess as to when the FCC is going to
order termination of all analog TV broadcasting and what the
effective date will be? The earliest effective date is 1/1/07
by law but...]
Old April 3rd 05, 05:42 AM
Icebound
"Icebound" writes:
GPS, Inertial-Gyro systems, and celestial nav.
You take a course such as this:
http://people.aero.und.edu/~deremer/courses.html
and pay particular attention to Level 3, number 2 :-) :
a.. Navigation without magnetic compass: gyro errors, finding & using the
sun's true bearing, and finding true north without celestial reference
Old April 3rd 05, 10:02 PM
David Cartwright
"Icebound" wrote in message
The nice side-effect being that after this change, you'll never have to
rename your runways and repaint the numbers due to changes in magnetic
variation (as I believe Bourn in Cambridgeshire did a little while ago).
D.
Dynon EFIS D-10 Magnetic heading Paul Lee Home Built 3 November 15th 04 08:41 PM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 12:08 PM
Reasoning behind course reversal Michael 182 Instrument Flight Rules 26 February 27th 04 03:27 PM
Complete Reversal or Not? Greg Esres Instrument Flight Rules 10 February 12th 04 10:05 AM
magnetic variation Angus Lepper Simulators 1 September 23rd 03 06:58 AM
