Co-pilot gets sick, stewardess helps land airplane
Old June 24th 10, 01:00 PM posted to rec.aviation.piloting
Default Co-pilot gets sick, stewardess helps land airplane
On Jun 23, 5:10*pm, Mxsmanic wrote:
I never reach a point where the controls get mushy except for occasional
academic experiments. I'd never allow that to happen in normal flight. I want
fat safety margins around my flight regime.
YOU GET MUSHY CONTROLS IN MSFS???????????? YOU DON"T HAVE CONTROLS IN
MSFS, YOU USE A JOYSTICK OR A KEYBOARD.
I don't do photography or S&R. All you really need to see visually is traffic,
and you don't need to fly by the seat of your pants at all (and you cannot,
under IFR).
THEN YOU DON'T FLY A REAL PLANE IF YOU THINK PHOTOGRAPHY ANSD S&R IS
THE ONLY TIME YOU DO SLOW FLIGHT.. YOU LAND A PLANE UNDER VFR, NOT
IFR.
SO, NO I AM NOT BEHIND THE PLANE.
Well, certainly if you scream it out, it must be so, eh?
NO, YOU CAN"T SEEM TO COMPREHEND THAT MSFS IS NOT FLYING A PLANE. IT
SIMULATES FLYING.
  #212
Old June 24th 10, 01:03 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
On Jun 23, 5:11*pm, Mxsmanic wrote:
writes:
DEFINE LOW TIME PILOT????????????????????????
Oo-wee-oo!
SO, WHAT IS THE ANSWER???????? TO YOUR DEFINITION OF LOW TIME PILOT
SINCE YOU CLAIM YOU CAN SPOT THEM???????
CLASSIC OF YOU NOT TO ANSWER A DIRECT QUESTION EH??????
  #213
Old June 24th 10, 01:12 PM posted to rec.aviation.piloting
On Jun 23, 6:47*pm, "Peter Dohm" wrote:
Well, it IS pretty hard to get killed at a desktop sim...
DUH, good point!
  #214
Old June 24th 10, 01:36 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
On 23 jun, 23:55, Mxsmanic wrote:
Hatunen writes:
Again you display your actual lack of knowledge and willingness
to display it in public. First, there is no FAR prohibiting the
demonstration or practice of doing spins.
Spins must be permitted for the aircraft, and regulations permit them (and
other aerobatic maneuvers) only under certain conditions. In this case, the
Cessna 150 may be spun only after certain modifications are made (since 2009),
in part to prevent maximum rudder travel from interfering with the elevators.
Yes, I have the AD in front of me.
Better start reading that AD.
a. Not all Cessna 150's are affected by this AD, just the ones with a
swept tail.
b. It has nothing to do with the rudder interfering with the elevator
but the head of rudder stop bolts got hooked.
  #215
Old June 24th 10, 02:57 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
JohnT[_3_]
On Jun 23, 5:11 pm, Mxsmanic wrote:
writes:
Oo-wee-oo!
Please don't shout.
JohnT
  #216
Old June 24th 10, 03:38 PM posted to rec.aviation.piloting
On Jun 24, 7:00*am, " wrote:
THE ONLY TIME YOU DO SLOW FLIGHT.. *YOU LAND A PLANE UNDER VFR, NOT
IFR.
CORRECTION to my post above - You land a plane under VMC conditions
(VISUAL)
  #218
Old June 24th 10, 10:09 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
george
On Jun 24, 10:05*pm, Mxsmanic wrote:
None that I found alarming. Downdrafts are harmless as long as you're well
above terrain.
Rotor ???????
  #219
Old June 24th 10, 10:23 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Mxsmanic
george writes:
above terrain.
Rotor ???????
Thunderstorm? Hurricane? Tornado? Nuclear explosion?
I don't recall losing 15,000 feet in a rotor on a commercial flight, but I
suppose anything is possible. A handful of exceptions does not disprove the
rule.
Pilot nearly crashes in IMC, Controller helps pimenthal Piloting 32 September 27th 05 01:06 PM
Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather Bill Mulcahy General Aviation 24 August 19th 05 10:48 PM
2 pilot/small airplane CRM Mitty Instrument Flight Rules 35 September 1st 04 11:19 PM
non-pilot lands airplane Cub Driver Piloting 3 August 14th 04 12:08 AM
Home Builders are Sick Sick Puppies pacplyer Home Built 11 March 26th 04 12:39 AM
