#241
On Oct 7, 5:54 pm, flightoffancy wrote:
In article , says... The downwash thing is wrong. Yes, there is some dispacemtn of air that causes lift, but it' only a minor contribution in the bigger scheme of things. I admit to being a relative retard on this issue (not as retarded as a non-pilot probably is, but not as educated as an aeronautical engineer). I thought I had read in numerous books during training that the primary component of lift is the air that gets knocked downward by the wing. I was calling that "downwash". Maybe my concept of downwash is wrong, maybe it's a separate consideration from the air that gets knocked downward by the airfoil. Hell I might not be remembering any of that correctly. Just wanted to reiterate what I said in my OP and each subsequent post for you benefit since you just joined the discussion. If you have an aifoil, and you move it forward, there will be compression beneath the wing. Newton's law will be at play here, and there will be downwash. This downwash results from the induced pressure gradient. That is not what I was talking about. The books that I have been reading are talking about downwash that is _on top of_ the wing. The pictures show air moving at an angle, backward and downward near the trailing edge of the wing. Note that these are two "downwashes". I am saying that downwash on top of the wing does not generate a force on the wing that causes the wing to move upward. Anyway you say downwash is minor. Well okay. But then what are the major contributions that cause lift in the bigger scheme of things? -Le Chaud Lapin- |
#242
On Oct 7, 6:53 pm, Jim Logajan wrote:
flightoffancy wrote: I thought I had read in numerous books during training that the primary component of lift is the air that gets knocked downward by the wing. I was calling that "downwash". Maybe my concept of downwash is wrong, maybe it's a separate consideration from the air that gets knocked downward by the airfoil. Hell I might not be remembering any of that correctly. You appear to have the essential concept right. But aerodynamicists call it "turning" the flow, which is different from what they call "downwash." Here's NASA's explanations: http://www.grc.nasa.gov/WWW/K-12/airplane/lift1.html And if you click on "turning" you can see this explanation of the term (and hopefully why "turning" was chosen): http://www.grc.nasa.gov/WWW/K-12/airplane/right2.html And this is what aerodynamicists call "downwash" : http://www.grc.nasa.gov/WWW/K-12/airplane/downwash.html I wanted to thank you again for these NASA links. IThe more I read, the more it becomes clear that is *not* universal concensus on the basic mechanisms of flight, not even among experts. -Le Chaud Lapin- |
#243
Le Chaud Lapin wrote:
On Oct 7, 6:53 pm, Jim Logajan wrote: You appear to have the essential concept right. But aerodynamicists call it "turning" the flow, which is different from what they call "downwash." Here's NASA's explanations: http://www.grc.nasa.gov/WWW/K-12/airplane/lift1.html And if you click on "turning" you can see this explanation of the term (and hopefully why "turning" was chosen): http://www.grc.nasa.gov/WWW/K-12/airplane/right2.html And this is what aerodynamicists call "downwash" : http://www.grc.nasa.gov/WWW/K-12/airplane/downwash.html I wanted to thank you again for these NASA links. IThe more I read, the more it becomes clear that is *not* universal concensus on the basic mechanisms of flight, not even among experts. I'm sorry but IMHO you continue to come to the same untenable conclusion. There is consensus among the experts. I keep giving the NASA links not because they are in any way unique, but because it is cheaper than giving you a list of more books on the subject that you'll never purchase and read. They seem ideal for this particular discussion and your specific need. There are simplified, and therefore inaccurate, statements about electromagnetics in books aimed at general audiences. Yet would you say that because of these statements there is no universal consensus about electromagnetics? |
#244
On Oct 7, 7:38 pm, Jim Logajan wrote:
I'm sorry but IMHO you continue to come to the same untenable conclusion. There is consensus among the experts. I keep giving the NASA links not because they are in any way unique, but because it is cheaper than giving you a list of more books on the subject that you'll never purchase and read. They seem ideal for this particular discussion and your specific need. From the NASA link you posted earlier: "There are many theories of how lift is generated. Unfortunately, many of the theories found in encyclopedias, on web sites, and even in some textbooks are incorrect, causing unnecessary confusion for students." That sounds to me like there are a lot of sources that are incorrect. My Jeppesen book, for example, says the exact opposite of what NASA is saying. Let's see...whom should I believe, the NASA version or one of the leaders in flight education? There are simplified, and therefore inaccurate, statements about electromagnetics in books aimed at general audiences. Yet would you say that because of these statements there is no universal consensus about electromagnetics?- Simplification does not necessarily make something in accurate. I have studied electronics most of my life to some degree. With the exception of maybe 5-10 incidents on esoteric, I do not recall reading anything that is inaccurate, and in one of the cases, it was simply a gross error made by author of book, not fundamental difference of opinion of the underlying physics. http://www.grc.nasa.gov/WWW/K-12/airplane/wrong1.html NASA is not simplifying, digesting, or even offering an alternate model that is mathematically and functionally equivalent from abstract point of view. They are saying that the other theories are simply wrong. That they think that the theories are wrong should be evident from the last word in the URL above. -Le Chaud Lapin- |
#245
On Oct 7, 9:26 pm, flightoffancy wrote:
He has barely begun flight training, claims his instructors are wrong about what makes airplanes fly, claims that because instructional materials at the beginner's level are incosistent therefore there is no agreement about aerodynamic theory at all, and then essentially dismisses NASA's explanations as "just another theory of many" and so he has no reason to believe them either. I did not dismiss NASA's explanations. For the Nth time... ....I said that I agree with NASA's explanation that the other explantions are wrong. http://www.grc.nasa.gov/WWW/K-12/airplane/wrong1.html -Le Chaud Lapin- |
#246
Le Chaud Lapin writes:
http://www.grc.nasa.gov/WWW/K-12/airplane/wrong1.html NASA is not simplifying, digesting, or even offering an alternate model that is mathematically and functionally equivalent from abstract point of view. They are saying that the other theories are simply wrong. That they think that the theories are wrong should be evident from the last word in the URL above. Look also at the "K-12" in the URL. |
#247
Jim, let me say about LCL (in cliche fashion) that you can lead a horse to water but cannot make it drink. He has barely begun flight training, claims his instructors are wrong about what makes airplanes fly, claims that because instructional materials at the beginner's level are incosistent therefore there is no agreement about aerodynamic theory at all, and then essentially dismisses NASA's explanations as "just another theory of many" and so he has no reason to believe them either. Hmmm. This puts me in a quandry because I actually understand the source of LCL's frustration and don't fault him for that feeling - just some of his approach. On one hand he is correct that many sources give incomplete or inaccurate explanations for lift. So he's attempting to work out why lift works on his own - which IMHO is a fantastic learning exercise. From my own experience tackling a complex problem clarifies in a person's mind many of the fine points of the problem (but for complex problems not normally the correct solution). Once that is done, one has (IMHO) a better appreciation for the sources and explanations that are more comprehensive and exact. He'll understand at a base level the statement "It's a complex subject." :-) A complete neophyte stands up and claims he has no reason to believe that what NASA publishes about flight is correct. I think he's already addressed that in another post. What can one say about someone who is willing to make such big claims with so little knowledge? A typical Usenet poster? ;-) "Don't feed the trolls." Not everything under the bridge is a troll. Some of them are pillars holding it up. :-) |
#248
flightoffancy writes:
But airfoils aren't planar, they are curved. Why do varying curvatures of airfoils significantly affect wing lift / stall speed? They don't affect lift, they just affect drag and stall speed. I don't know the theory well enough to comment on why this is so. From a piloting perspective, it is only necessary to know that AOA determines lift, and the shape of the airfoil is irrelevant. |
#249
Bertie the Bunyip writes:
Actually, yes it is. Show me an aircraft that does this. |
#250
If that is the case, what is pushing the air? You may be able to get past this by considering that the airfoil actually turns the flow, rather than push or pull it. It turns the flow downwards, and this acceleration of the air mass engenders an upward force that is lift. |
How much lift do you need? | Dan Luke | Piloting | 3 | April 16th 07 02:46 PM |
Theories of lift | Avril Poisson | General Aviation | 3 | April 28th 06 07:20 AM |
what the heck is lift? | buttman | Piloting | 72 | September 16th 05 11:50 PM |
Lift Query | Avril Poisson | General Aviation | 8 | April 21st 05 07:50 PM |
thermal lift | ekantian | Soaring | 0 | October 5th 04 02:55 PM |
