Backwash Causes Lift?
Old October 8th 07, 04:26 AM posted to rec.aviation.piloting
Le Chaud Lapin
Default Backwash Causes Lift?
On Oct 7, 10:07 pm, Mxsmanic wrote:
Le Chaud Lapin writes:
If that is the case, what is pushing the air?
You may be able to get past this by considering that the airfoil actually
turns the flow, rather than push or pull it. It turns the flow downwards, and
this acceleration of the air mass engenders an upward force that is lift.
The airfoil turns the flow downward....
What air gets turn downward....the air on top of the wing or the air
on the bottom of wing?
-Le Chaud Lapin-
  #255
Old October 8th 07, 05:58 AM posted to rec.aviation.piloting
Le Chaud Lapin
On Oct 7, 11:02 pm, flightoffancy wrote:
Did you mess with NASA's online simulations of airfoils?
Yes, 15 minutes ago, in fact after taking a break from my very tedious
work.
Those suggest that the air both "on top" and "on the bottom" of an
airfoil get turned as the airfoil's AoA changes. Those have to be put in
quotes since an aircraft (with the proper engine) can be flown upside
down and in other orientations.
I did notice the turning. The article is claiming that the upper
surface of the wing "turns" the upper flow.
Link: http://www.grc.nasa.gov/WWW/K-12/airplane/right2.html
I must admit that I am having problems with this explanation. It is
extremely vague? What is the turning? How, exactly, does the wing
"turn" the flow. The air is made up of molecules. If it is upper
surface of the wing that is turning does air molecules so that they
have a velocity component that is downward, how is this happening?
Since when, could one body, A, of any kind, that does not involve
gravitational or electrostatic fields, induce another body B, to move
in a direction that has a component vector that is aimed directly at
B?
Also NASA does not just explain why the longer length theory, the
Newtonian theory, and Bernoulli theories are incorrect, they also
elaborate what the correct equations to properly calculate observed lift
are, though I didn't see an example calculation. So they do say what is
correct, as well as what is not.- Hide quoted text -
True.
This "turning" theory of NASA makes me suspicious. If anyone else has
any qualtitative explanation of what they mean by the upper surface of
the wing foil turning the air so that it has a downward component in
its velocity, I would like to see it.
Finally, I do agree that the geometry, AoA, etc...interacts with the
atmospher in such a way that the net result of the flow on the top
surface of the wing is back and downward. What I don't see is the how
the wing itself is "turning" that flow.
-Le Chaud Lapin-
  #256
Old October 8th 07, 06:16 AM posted to rec.aviation.piloting
Mxsmanic
Both, but mostly air from above the wing (a great deal of air, in fact).
  #258
Old October 8th 07, 06:18 AM posted to rec.aviation.piloting
Le Chaud Lapin
Link:http://www.grc.nasa.gov/WWW/K-12/airplane/right2.html
B?
I just re-read the link above very carefully, and unless I am
mistaken, there is a *huge* amount of hand-waving going on here too.
Sigh.
"Turning" a flow? What would Newton say. It's magic.
Yes, we all know that F=ma, and "a" is the time derivative of
velocity, a = dv/dt, and that v has a magnitude and a direction, and
that if you change either magnitude or direction, you have a
force...that's all fine...
They do not specify how the wing turns the air. They show a picture
of air flowing backward on top of a sligtly-angled wing. Then they
write:
"For a body immersed in a moving fluid, the fluid remains in contact
with the surface of the body. If the body is shaped, moved, or
inclined in such a way as to produce a net deflection or turning of
the flow, the local velocity is changed in magnitude, direction, or
both. Changing the velocity creates a net force on the body. It is
very important to note that the turning of the fluid occurs because
the molecules of the fluid stay in contact with the solid body since
the molecules are free to move."
"the molecules stay in contact with the solid body"...?????????????
Why?
What incentive do the molecules have to stay in contact with the solid
body? Is there a sign on top of the wing that reads:
**** NOTE: ALL MOLECULES, YOU ARE HEREBY ORDERED TO STAY AS CLOSE TO
ME AS POSSIBLE. ****
Are there little molecule-sized pina coladas on top of the wing
waiting for the molecules to drink?
Even if there is a thin layer of air remaining in contact with the
wing for mysterious, magical reasons, what about the layers above it?
What incentive do those layers have "try and stay in contact with the
wing"?
-Le Chaud Lapin-
How much lift do you need? Dan Luke Piloting 3 April 16th 07 02:46 PM
Theories of lift Avril Poisson General Aviation 3 April 28th 06 07:20 AM
what the heck is lift? buttman Piloting 72 September 16th 05 11:50 PM
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
thermal lift ekantian Soaring 0 October 5th 04 02:55 PM
