I wonder, does anyone routinely recalculate limiting V speeds on the
basis of TOW? I assume that limiting Va speeds go with the square root of the fraction MTOW loading so for 75% MTOW Va would drop to 86% Va. But the question is, if Vne is limited by arodynamic issues such as flutter or windshield how would that change with load? Put another way, is Vne ever load dependent and/or does anyone use a rule like that for Va? A second sort of connected question is: is there any wing that can produce more lift at 45 degrees AOA than at the stall point (I know that most airfoils produce about the same lift at 45 AOA as at the stalling point)? What I'm thinking about is wings with washout or drag reducing devices that will reduce maximum lift at the stall point but not the 'flat plate at 45 AOA' lift. Put another way, how much loss of lift do we get from typical washout? Cheers |
In article
, "Flaps_50!" wrote: I wonder, does anyone routinely recalculate limiting V speeds on the basis of TOW? I assume that limiting Va speeds go with the square root of the fraction MTOW loading so for 75% MTOW Va would drop to 86% Va. But the question is, if Vne is limited by arodynamic issues such as flutter or windshield how would that change with load? Put another way, is Vne ever load dependent and/or does anyone use a rule like that for Va? I must admit that I never knew that Va went down, rather than up, with weight. It makes sense now that I've read about the phenomenon, but this is the first time I've heard of it. As for Vne, my understanding of the causes of it (flutter, aerodynamic loads, etc.) would indicate that it's not dependent on weight at all, except for how weight might help you get to that speed, but I could very well be wrong. A second sort of connected question is: is there any wing that can produce more lift at 45 degrees AOA than at the stall point (I know that most airfoils produce about the same lift at 45 AOA as at the stalling point)? What I'm thinking about is wings with washout or drag reducing devices that will reduce maximum lift at the stall point but not the 'flat plate at 45 AOA' lift. Put another way, how much loss of lift do we get from typical washout? The coefficient of lift is at its maximum at the stall angle of attack, by definition. It's not possible for 45 degrees to give the same lift as stall unless the wing actually stalls at 45 degrees AOA, and that would be really unusual. Don't know the answer to the washout question, but I think it would be better framed as how much unnecessary drag is produced, rather than "loss of lift", which is confusing because a wing always produces the same amount of lift for a given weight in steady level flight no matter what the speed, AOA, or wing configuration. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
On Sep 6, 4:49*pm, Mike Ash wrote:
In article , *"Flaps_50!" wrote: I wonder, does anyone routinely recalculate limiting V speeds on the basis of TOW? I assume that limiting Va speeds go with the square root of the fraction MTOW loading so for 75% MTOW *Va would drop to 86% Va.. But the question is, if Vne is limited by arodynamic issues such as flutter or windshield how would that change with load? *Put another way, is Vne ever load dependent and/or does anyone use a rule like that for Va? I must admit that I never knew that Va went down, rather than up, with weight. It makes sense now that I've read about the phenomenon, but this is the first time I've heard of it. As for Vne, my understanding of the causes of it (flutter, aerodynamic loads, etc.) would indicate that it's not dependent on weight at all, except for how weight might help you get to that speed, but I could very well be wrong. A second sort of connected question is: is there any wing that can produce more lift at 45 degrees AOA than at the stall point (I know that most airfoils produce about the same lift at 45 AOA as at the stalling point)? What I'm thinking about is wings with washout or drag reducing devices that will reduce maximum lift at the stall point but not the 'flat plate at 45 AOA' lift. Put another way, how much loss of lift do we get from typical washout? The coefficient of lift is at its maximum at the stall angle of attack, by definition. It's not possible for 45 degrees to give the same lift as stall unless the wing actually stalls at 45 degrees AOA, and that would be really unusual. Don't know the answer to the washout question, but I think it would be better framed as how much unnecessary drag is produced, rather than "loss of lift", which is confusing because a wing always produces the same amount of lift for a given weight in steady level flight no matter what the speed, AOA, or wing configuration. The reason why I riase this is beacuse the variation of Cl with lift is rarely shown at high AOA but I found some test diagrams and they show that for typical foils, Cl at 45 is almost the same as the the stall point. see: http://www.aerospaceweb.org/question...s/q0150b.shtml Now, as I understand/see it, with washout, the overall max lift in a wing must be less than that given by just max Cl at stall and planaform. This would not be the case with the 'flat plate lift'. for a hershey bar wing with say 3 degrees washout, I'd say that flat plate at 45 could generate at least as much lift as at the stalling point. This may be a bit esoteric but I think it's interesting and might indicate an even lower Va if vertical winds are anticipated. Cheers |
In article
, "Flaps_50!" wrote: The reason why I riase this is beacuse the variation of Cl with lift is rarely shown at high AOA but I found some test diagrams and they show that for typical foils, Cl at 45 is almost the same as the the stall point. see: http://www.aerospaceweb.org/question...s/q0150b.shtml Clearly my understanding of this subject was inadequate. Thank you for this link. Now, as I understand/see it, with washout, the overall max lift in a wing must be less than that given by just max Cl at stall and planaform. This would not be the case with the 'flat plate lift'. for a hershey bar wing with say 3 degrees washout, I'd say that flat plate at 45 could generate at least as much lift as at the stalling point. This may be a bit esoteric but I think it's interesting and might indicate an even lower Va if vertical winds are anticipated. Any vertical gust which approaches 45 degrees AoA is likely to destroy your aircraft outright no matter what speed you're flying. We're talking something near a 60kt vertical gust if you're flying at 60kts. That kind of gust is beyond extreme. You're very unlikely to ever encounter such a beast unless you're in a thunderhead or something of that nature. Note that Va is set for a certain maximum vertical gust speed. For gusts beyond that speed, no guarantees are made. My plane's manual explicitly calls this out, saying: "Note: According to the Regulations the term "severe turbulence" means air movements which might be encountered in wave rotors, storm clouds, visible whirlwinds and when overflying mountain ranges and ridges. As we observed in Chapter II.1 this level of turbulence is reached when the variometer indicates about 7m/s (+1378ft/min) momentary peak indication. The experienced flyer knows that he can expect even more severe turbulence in storms and in high mountain ranges." So, yes, if you expect turbulence in excess of the numbers used to set your Va, you should fly even slower yet. However I think this still won't save you if it's as extreme as you describe, but fortunately such extremes are very rare indeed. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
Clearly my understanding of this subject was inadequate. Thank you for this link. Now, as I understand/see it, with washout, the overall max lift in a wing must be less than that given by just max Cl at stall and planaform. This would not be the case with the 'flat plate lift'. for a hershey bar wing with say 3 degrees washout, I'd say that flat plate at 45 could generate at least as much lift as at the stalling point. This may be a bit esoteric but I think it's interesting and might indicate an even lower Va if vertical winds are anticipated. One other point that may add to your understanding, on Hershey Bar wings. It is my understanding that HB wings have little to no need for washout, as their stall characteristics are very controllable with zero washout. It has been a while since I read on that subject, but I recall the distribution of lift tends to make the stalls occur at the root and progress out to the tips as the stall deepens, just like a "nice" wing should do. But then, I could be wrong! g -- Jim in NC |
On Sep 12, 11:45*am, "Morgans" wrote:
Clearly my understanding of this subject was inadequate. Thank you for this link. *Now, as I understand/see it, *with washout, the overall max lift in a wing must be less than that given by just max Cl at stall and planaform. This would not be the case with the 'flat plate lift'. for a hershey bar wing with say 3 degrees washout, I'd say that flat plate at 45 could generate at least as much lift as at the stalling point. This may be a bit esoteric but I think it's interesting and might indicate an even lower Va if vertical winds are anticipated. One other point that may add to your understanding, on Hershey Bar wings. It is my understanding that HB wings have little to no need for washout, as their stall characteristics are very controllable with zero washout. *It has been a while since I read on that subject, but I recall the distribution of lift tends to make the stalls occur at the root and progress out to the tips as the stall deepens, just like a "nice" wing should do. But then, I could be wrong! g -- Yes, quite right. I was using the term to imply constant chord which makes it easier to think about Cl and lift variation along a wing with washout. Some actual Hershey bar wings have very little washout because they start their stall in the center and it may not rapidly propagate, especially if fences or similar devices are added I believe. That said, the constant chord wing with no washout introduces other disadvantages... Cheers |
| Thread Tools | |
| Display Modes | |
| How much lift do you need? | Dan Luke | Piloting | 3 | April 16th 07 03:46 PM |
| Come lift a cup with Joe Rasymas! | Fred | Soaring | 5 | October 24th 06 09:42 PM |
| Theories of lift | Avril Poisson | General Aviation | 3 | April 28th 06 08:20 AM |
| what the heck is lift? | buttman | Piloting | 72 | September 17th 05 12:50 AM |
| thermal lift | ekantian | Soaring | 0 | October 5th 04 03:55 PM |
