Front Electric Sustainer
Old November 2nd 09, 11:47 PM posted to rec.aviation.soaring
Mike the Strike
Default Front Electric Sustainer
So how does rubber (or modern synthetic varieties thereof) compare on
an energy storage per mass basis with lithium/ion batteries? We use
them for bungee launches - how about powering a sustainer?
I have this vision of a large coil of rubber between my legs powering
a slow-turning single-bladed prop!
Old November 3rd 09, 12:37 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Mon, 02 Nov 2009 15:47:40 -0800, Mike the Strike wrote:
So how does rubber (or modern synthetic varieties thereof) compare on an
energy storage per mass basis with lithium/ion batteries? We use them
Good quality rubber strip stores around 3000 ft/lb per pound of rubber.
Sad to say, I've completely forgotten how to convert that to something we
could compare with a battery, say to kW/kg.
I have this vision of a large coil of rubber between my legs powering a
That sounds potentially as dangerous to valued objects as snapping the
drive shaft of a P.39 Airacobra.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old November 3rd 09, 01:25 AM posted to rec.aviation.soaring
Craig[_2_]
On Nov 2, 4:37*pm, Martin Gregorie
energy storage per mass basis with lithium/ion batteries? *We use them
Good quality rubber strip stores around 3000 *ft/lb per pound of rubber..
martin@ * | Martin Gregorie
org * * * |
If I've calculated correctly (and I may not have) 3000 ft-lb/lb of
rubber = 8,965 joules/kg of rubber. So a 100 kg rubber band would
store 896.5 kilo joules of energy which expended over 60 seconds
provides a stunning power output of (drum roll please) 15 kw. It
would be damn exciting on a FF model, but probably not practical as a
sustainer.
Craig
Old November 3rd 09, 01:59 AM posted to rec.aviation.soaring
Uncle Fuzzy
Would that be 1987 Pirelli?? I've heard that sometimes FAI Tan is
comperable. I seem to recall a man-carrying rubber powered plane
making an attemp in the late 1980's or early '1990's.
Old November 3rd 09, 02:20 PM posted to rec.aviation.soaring
On Mon, 02 Nov 2009 17:25:56 -0800, Craig wrote:
On Nov 2, 4:37Â*pm, Martin Gregorie
an energy storage per mass basis with lithium/ion batteries? Â*We use
Good quality rubber strip stores around 3000 Â*ft/lb per pound of
rubber. Sad to say, I've completely forgotten how to convert that to
something we could compare with a battery, say to kW/kg.
martin@ Â* | Martin Gregorie
org Â* Â* Â* |
rubber = 8,965 joules/kg of rubber. So a 100 kg rubber band would store
896.5 kilo joules of energy which expended over 60 seconds provides a
stunning power output of (drum roll please) 15 kw. It would be damn
exciting on a FF model, but probably not practical as a sustainer.
So that's 0.25 kWh by my reckoning. By contrast the LAK FES installation
carries two 3.6 kWh batteries.
I make that rubber 0, electric 1
org |
Old November 3rd 09, 02:25 PM posted to rec.aviation.soaring
comperable. I seem to recall a man-carrying rubber powered plane making
That value was from a 2008 NFFS Sympo paper for Tan 2. I don't fly
rubber, preferring 50m of towline or a screaming Cyclon 06, but IIRC Tan
2 is now about as good as the best Pirelli and the Tan SuperSport is
coming pretty close too.
org |
The HPH 304S Turbine sustainer glider kd6veb Soaring 2 September 23rd 09 05:10 AM
would an electric sustainer be practical Brad[_2_] Soaring 7 July 24th 09 06:29 PM
Sustainer engine ignition noise (Solo2350) Per Soaring 8 January 4th 07 05:56 AM
DG goes the sustainer option. Paul Soaring 25 June 4th 04 12:16 AM
Chasing the front Paul Tomblin Piloting 7 April 21st 04 01:09 PM
