#21
John Smith wrote:
tstock wrote: Also helps stabilize the glider in a spin. Could you explain this statement for us newbies... Just don't worry. All moderately current regulations ask that a glider is recoverable from a fully developed spin with any possible ballast distribution. How old is "currently"? Are they really certified to recover with one wing full of ballast and the other wing empty? Best to check the manual! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly |
Andy wrote:
N7LW has it right. It has to do with bending moments developed in the spar. At any given flight condition the wing supports a given amount of lift that can be expressed in lbs/ft of span (or N/m if you prefer). The fuselage doesn't produce any lift and has to be supported by the lift produced on these long cantilever beams on each side. Weight toward the middle of the aircraft increases the wing bending. If the weight can be moved toward the outer portions of the wing the bending loads are decreased. The paper airplane is a good way to visualize this. Craig Yup. Ballast towards the wings tips increases the g-limit at any given weight versus ballast towards the wing root. It may or may not affect the flutter limits - but my initial hypothesis would be that it reduces the natural frequency of the wing in bending which would probably help on flutter. This sounds backwards to me. Won't that move the flutter speed to a lower speed? I seem to recall one concern with adding winglets to older gliders is the potential lowering of the speed for flutter onset. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * Sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Eric Greenwell wrote:
Are they really certified to recover with one wing full of ballast and the other wing empty? JAR 22.221 General (a) [...] the demonstrations of sub-paragraphs (b) through (g) must also be made for the most critical water-ballast loadings. (b) The sailplane must be able to recover from spins of at least five turns [...] by applying the controls in a manner normal for recovery [...] |
Wow - thanks to all who answered, especially Craig and Andy. I
understand now why weighted wing tips are good. I’m puzzled about Andreas’ comments on the ASW-22, though: Even with completely filled outer wing bags (about 120 lbs per wing) the roll rate doesn't suffer at all. But filling the inner wing tanks (about 100 lbs per wing) instead of having a co-pilot on board reduces the roll rate significantly. This behavior seems to defy physics! -John |
On Fri, 11 Dec 2009 06:00:23 -0800 (PST), jcarlyle
wrote: This behavior seems to defy physics! You got it. ![]() I have the feeling that the cause might be some minor dihedral change due to the water ballast, but I can't nail it down. Bye Andreas |
On Dec 10, 7:08*pm, Eric Greenwell wrote:
Ballast towards the wings tips increases the g-limit at any given weight versus ballast towards the wing root. It may or may not affect the flutter limits - but my initial hypothesis would be that it reduces the natural frequency of the wing in bending which would probably help on flutter. This sounds backwards to me. Won't that move the flutter speed to a lower speed? I seem to recall one concern with adding winglets to older gliders is the potential lowering of the speed for flutter onset. Hmmm...maybe you're right. I'm not an expert on aeroelastics. My thinking was that flutter at its core is like a mass-spring-damper system. Given that the input aerodynamic forces don't change with mass loading, adding mass to the wing ought to make it respond less in bending to the input force because it has more inertia. I would expect most of the bending resistance would be structural (spring) resistance rather than inertial (mass) resistance, so the effect could be small. The lower natural frequency of the wing would correspond to a lower speed for flutter onset, but the aerodynamic forces would be lower as a function of the square of the speed, so what's the net effect? With enough mass might you not get any flutter at all? May there also be harmonic effects related to how many bending "waves" you get along the span? In any event, I think the main effect is the increase in g-limit due to the reduced bending loads from the change in spanwise weight distribution. 9B |
John Smith wrote:
Eric Greenwell wrote: Are they really certified to recover with one wing full of ballast and the other wing empty? JAR 22.221 General (a) [...] the demonstrations of sub-paragraphs (b) through (g) must also be made for the most critical water-ballast loadings. (b) The sailplane must be able to recover from spins of at least five turns [...] by applying the controls in a manner normal for recovery [...] The paragraph (a) for the Aug 2001 Jar copy I found includes: (a) ... *Unless it can be shown that asymmetric water-ballast is unlikely to occur by malfunction or with lateral accelerations during a spin,* the demonstrations of sub-paragraphs (b) through (g) must also be made for the most critical water-ballast loadings. Are exemptions for asymmetric water-ballast used for any of our gliders, and how would a pilot know? Is it something in the flight manual, perhaps? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly |
Andreas Maurer wrote:
Even with completely filled outer wing bags (about 120 lbs per wing) the roll rate doesn't suffer at all. But filling the inner wing tanks (about 100 lbs per wing) instead of having a co-pilot on board reduces the roll rate significantly. Don't ask me why. Adverse aeroelastic wing twist due to aileron action anti-servoing the wing?? Brian W |
#29
On Fri, 11 Dec 2009 07:07:43 -0800, Andy wrote:
Hmmm...maybe you're right. I'm not an expert on aeroelastics. My thinking was that flutter at its core is like a mass-spring-damper system. Given that the input aerodynamic forces don't change with mass loading, adding mass to the wing ought to make it respond less in bending to the input force because it has more inertia. I would expect most of the bending resistance would be structural (spring) resistance rather than inertial (mass) resistance, so the effect could be small. The lower natural frequency of the wing would correspond to a lower speed for flutter onset, but the aerodynamic forces would be lower as a function of the square of the speed, so what's the net effect? With enough mass might you not get any flutter at all? May there also be harmonic effects related to how many bending "waves" you get along the span? I remember hearing a talk about this a few years ago. Anything that moves the wing section CG forward relative to the effective CP will reduce the tendency of the surface to flutter - hence lead in control surface leading edges and the recommended lead in the tip LE of the modified ASW-22. All modern gliders carry water in front of the spar. As a result the CG moves forward and you'd expect some increase on the speed at which flutter starts. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#30
On Dec 11, 12:57*pm, Martin Gregorie
wrote: On Fri, 11 Dec 2009 07:07:43 -0800, Andy wrote: Hmmm...maybe you're right. *I'm not an expert on aeroelastics. My thinking was that flutter at its core is like a mass-spring-damper system. Given that the input aerodynamic forces don't change with mass loading, adding mass to the wing ought to make it respond less in bending to the input force because it has more inertia. I would expect most of the bending resistance would be structural (spring) resistance rather than inertial (mass) resistance, so the effect could be small. The lower natural frequency of the wing would correspond to a lower speed for flutter onset, but the aerodynamic forces would be lower as a function of the square of the speed, so what's the net effect? With enough mass might you not get any flutter at all? May there also be harmonic effects related to how many bending "waves" you get along the span? I remember hearing a talk about this a few years ago. Anything that moves the wing section CG forward relative to the effective CP will reduce the tendency of the surface to flutter - hence lead in control surface leading edges and the recommended lead in the tip LE of the modified ASW-22. All modern gliders carry water in front of the spar. As a result the CG moves forward and you'd expect some increase on the speed at which flutter starts. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | The only glider wing flutter I've seen is that DG-100 video that shows asymmetric flutter with a fair amount of aileron involvement. Aileron flutter is driven by the lack of mass balance because the aileron is hinged at the leading edge. The wing itself is "hinged" more about the spar I think (not really a hinge I know). This would seem to be more "mass balanced" so adding weight in the D-tube may or may not produce the same effect. 9B |
visualisation of the lift distribution over a wing | Stealth Pilot[_2_] | Home Built | 195 | December 16th 09 03:17 AM |
Wanted: Schempp Hirth Wing Ballast Cap | Paul Cordell | Soaring | 7 | August 17th 07 08:30 PM |
Fin/wing water ballast ratio? DG-300 | [email protected] | Soaring | 0 | May 2nd 06 06:52 PM |
747 weight distribution | Robin | General Aviation | 25 | June 22nd 05 03:53 AM |
Distribution of armor on a B-52 | B2431 | Military Aviation | 12 | August 16th 04 09:07 PM |
