TE probe up or down?
Old September 28th 10, 02:00 AM posted to rec.aviation.soaring
Dave Nadler
Default TE probe up or down?
On Sep 27, 11:46*am, "Tim Mara" wrote:
Pete Russel (former SAGE Variometer maker) tested TE probes in all
directions..Pete reported it worked equally as well off to the left or right
as it did up or down....
Its completely dependent on the glider and the length of the probe...
In general, UP is much preferred.
See ya, Dave
Old September 28th 10, 02:55 AM posted to rec.aviation.soaring
HL Falbaum[_2_]
"Rolf" wrote in message
On Sep 27, 5:13 am, "kirk.stant" wrote:
It's raining at the field today so here is a serious soaring question
to ponder:
Should the end of the TE probe on the fin point up or down?
Informal surveys at recent contests seem to show a slight preference
for up (not counting those "swingers" that go both ways).
I've heard all sorts of reasons why each orientation is best - angle
of attack during pull-ups, airflow in front of the tail, G-effects on
the air column, blah blah blah...
I point mine up so I don't snag it when taking off the tail dolly!
Comments?
Kirk
Wet in IL
Well, your very own Oran W. Nicks describes the development of the
probe in your "Soaring" magazine of September 1976. He definitely has
the probe pointing up. As he is the inventor and arrived at the
configuration in extensive wind tunnel tests that settles it for me.
Rolf
And Professor Irving, who developed two different designs, shows his pointed
down, and 20 degrees forward. Professor Irving also used wind tunnel
testing. So there!
Hartley Falbaum
"KF" USA
Old September 28th 10, 10:45 AM posted to rec.aviation.soaring
Chris Nicholas[_2_]
This is pure speculation, but I wonder if Prof Frank Irving’s
preference for the probe pointing downwards is because in his day, and
particularly in the UK, cloud flying was commonplace.
It follows that accumulation of water droplets on the probe was also,
common. After only a few minutes in cloud, it is usual to find that
the vario starts misbehaving. (I find that typically, it suddenly
stops displaying rate of climb accurately, and then flicks to a
different reading, then settles back to something sensible for a few
seconds, and then repeats the cycle. I put this down to water droplets
accumulating, to the point that they block the tiny holes in the
probe, then suddenly get freed, then repeat the cycle. I have no means
of knowing whether my speculation in this respect is accurate.)
Anything that can delay that, or at least get rid of surplus water
droplets so that the vario returns to functionality for a few seconds
at a time, is probably worth doing.
If you're not flying where water droplets are likely to accumulate on
the probe, other things being equal it seems to me that keeping it as
far from disturbed air over the wings as possible is a good thing,
hence up.
Just my two cents worth.
Chris N
Old September 28th 10, 03:21 PM posted to rec.aviation.soaring
Derek C
common. *After only a few minutes in cloud, it is usual to find that
*Anything that can delay that, or at least get rid of surplus water
hence up.
Chris N
Gliders with short rear fuselage mounted TE probes often suffer from a
flickering and false vario reading when flown at high angles of
attack, as in a thermalling turn. I assume that this is because of
interference from turbulent air coming off the wings. I have also
experienced this effect with some fin mounted probes. I would point
the probe upwards to keep it as clear as possible from any wing
turbulence.
Derek C
Old September 29th 10, 08:42 AM posted to rec.aviation.soaring
Jonathon May[_2_]
At 14:21 28 September 2010, Derek C wrote:
On Sep 28, 10:45=A0am, Chris Nicholas wrote:
This is pure speculation, but I wonder if Prof Frank Irving=92s
common. =A0After only a few minutes in cloud, it is usual to find that
=A0Anything that can delay that, or at least get rid of surplus water
hence up.
Chris N
turbulence.
Derek C
We use to use a nose mounted probe on a K18 I flew,not sure how good it
was, but the yaw string mounted on it was much better as it didn't over
react as much.
Jon
Old September 29th 10, 07:48 PM posted to rec.aviation.soaring
Nyal Williams[_2_]
You probably had the string tied around the holes that make the thing work.
The yarn sucked away the moisture from the holes so that they could
continue to work and that moisture in the yaw string caused it to be
heavier and thus not fluctuate so much. That is good theory!
and
that
droplets
means
on
hence up.
Chris N
turbulence.
Derek C
react as much.
Jon
Ka-6 TE Probe vontresc Soaring 14 August 30th 08 03:17 AM
Probe problem smf Home Built 3 July 8th 07 01:29 PM
TE Probe on ASW-15 [email protected] Soaring 4 April 29th 07 01:43 AM
Multi - probe KP Soaring 1 March 7th 05 06:03 PM
TE-Probe for 1-26D Heinz Gehlhaar Soaring 6 January 17th 05 10:52 PM
