Transponder Problem
Old September 4th 03, 04:28 AM
Jay Honeck
Default Transponder Problem
The third digit on my formerly bullet-proof Narco AT-50 transponder has
suddenly started displaying incorrectly for ATC. Specifically, it seems to
be showing as a "4" on their screens, regardless of what we dial it to in
the plane. Thus, instead of squawking "1200" when we're VFR, we're
squawking "1240"...
What could cause this? Any recommendations on repair versus replacement?
Thanks!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old September 4th 03, 06:16 AM
Craig Prouse
I can no longer imagine having a transponder with four knobs.
If you get one with sequential digital entry, you can leisurely scoff at all
the Usenet arguments about the dangers of flipping through 7XXX codes...
It's really a minor thing, but I also like the fact that my transponder
displays pressure altitude. When I need to know pressure altitude, it saves
me the trouble of futzing with the Kollsman knob.
Jay, you fly one of the greatest GA airplanes ever designed (except for its
notable lack of a pilot-side door), and it deserves nothing less than the
best.
http://www.garmin.com/products/gtx327/
http://www.bendixking.com/static/cat...ls.jsp?pid=142
Old September 4th 03, 12:41 PM
Dan Luke
scoff at all the Usenet arguments about the dangers of
transponder displays pressure altitude. When I need
nothing less than the best.
Amen. Next to the autopilot, the Garmin 327 is the best thing I've put
in my airplane.
Dan
C172RG at BFM
Old September 4th 03, 04:17 PM
Dick Meade
"Jay Honeck" wrote in message
news:Tjy5b.345829$o%2.158911@sccrnsc02...
to
squawking "1240"...
Thanks!
What a coincidence. My AT 150 pulled this stunt at the beginning of a trip
from Texas to Las Vegas about a week ago. In my case, the third digit
flipped back and forth between 5 and 1. The bad news is that it will likely
get worse, to the point where ATC can only see you part of the time. That
caused me to rethink flying into the very busy Las Vegas area, opting
instead to park it at Kingman, AZ. At least we got to see the Hoover Dam
again.
Anyway, the good news is that mine was fixed locally for $65.00. It was
described as being an "adjustment", but I forget what was adjusted. I could
look at the invoice to refresh my memory. While I'd love a pushbutton
Garmin, I'm too cheap to toss a fixable unit.
To save you a phone call, Narco factory service is $95.00 per hour plus
parts. 2 to 3 week turnaround. They have a factory reconditioned exchange
program for $595.00. Also a 2 to 3 week turnaround. I think there are
issues with replacing an AT 50 with a 150. Something about needing a 150R.
Let me know if you want details about where I got mine done.
Dick Meade
Old September 4th 03, 05:05 PM
Ray Andraka
Narco also has a 10% off web coupon for service if the radio is sent by the
owner.
In the case of a Nav radio, you could get away with flying without the radio for
a few weeks. A transponder in busy airspace is another thing altogether. Ask
around at the local shops to see if you can find one that will look at it. Here
in the Northeast, I've had good luck with The Radio Shop, which is located at
Worcester Mass, for repairing Narco stuff. Like I said before, the shops will
generally only fix what is wrong; they won't bring the unit up to the latest mod
level, do a complete check on the unit, or warranty the entire unit.
If I was looking at a repair that cost near the value of the transponder, I'd
seriously consider getting a new mode S with plans to eventually connect it to a
MFD for traffic. I don't think I'd spring for a new mode C only at this point,
as I suspect we'll be getting gently nudged to go with mode S in the not to
distant future. Fortunately, yours does not sound like an expensive problem
(the tube is fine, it is the digital encoding that is the problem), just an
inconvenient one. If you are on good terms with a local shop, you might be able
to get a loaner while you send it in to Narco if your local shop can't fix it.
to
squawking "1240"...
Thanks!
again.
Dick Meade
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old September 4th 03, 05:49 PM
G.R. Patterson III
This happened with my Bendix-King unit. My avionics tech fixed it as part of
my 91.413 check - no additional charge. It was a bench repair and took him
only a few minutes.
George Patterson
A friend will help you move. A really good friend will help you move
the body.
VHF & Transponder antenna Steve Home Built 1 December 6th 04 04:29 PM
A problem in the Military ? Nick Jade Military Aviation 54 March 15th 04 07:59 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
Garmin fixes moving waypoint problem -- almost Jon Woellhaf Instrument Flight Rules 6 November 28th 03 05:29 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
