Mogas: what happens to EGTs?
Old March 10th 04, 01:42 PM
jls
"Jim Weir" wrote in message
" jls"
-Now that I have done some homework, I find your statement here to be in
-error. Please look up the alloy formula for stellite, which is the
exotic
-alloy coating on expensive 100-octane aircraft engine exhaust valves.
I know well the formula for stellite. If you are nuts enough to buy
stellite
faced valves, I know there are people willing to take your money. If you
want a
plain-jane 100 octane valve, there are those, too. I can tell you that
I've
done enough work inside Continental engines to understand the difference.
Have
you?
Yes, several Continentals, Lycomings, and even worked on a Franklin. I'm
overhauling an O-300 at the time. The 629404 exhaust valves were about $60
last time I checked. And when I bought stellite valves for an A-65 which
I'm also rebuilding, there were 2 diffrent kinds of 100-octane valves and
the stellites were cheaper.
Old March 10th 04, 03:21 PM
Gene Kearns wrote:
: Having actually done this...... 1967 C172H w/ Lycoming O-360-A2A
I do this all the time. Takeoff tank has some (or all) 100LL, other tanks
100% autofuel... '69 PA-28-180 with Lycoming O-360-A4A
:-Ok... little MOGAS quiz for you.
:-You run the Left tank dry and fill it up with premium unleaded car
:-gas.
: Used Amoco Premium
Wilco/Hess 93 A.K.I. (R+M/2)
:-Right tank has 100LL.
:-Takeoff on the RH tank and climb, level off, and set up the mixture
:-for
:-cruise flight. Either ROP or LOP. Your choice.
: ROP by 75 degrees.
More or less peak EGT at 65% power
:-THEN, you switch to the LEFT tank. You change nothing else.
:-Later you download your JPI and plot the data.
:-1 What is it going to show happened to the EGTs when you switched
:-tanks?
: Increase of about 9 degrees.
Roughly the same... analog gauges so difficult to get too accurate
:-2 What is it going to show happened to the CHTS when you switched
:-tanks?
: Nothing observable.
Ditto
:-3 (not in the JPI, but: ) What is the airspeed going to do? Increase?
:-Decrease? Stay the same?
: No observable change.
Ditto
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Mogas for an O-320 with 160 HP? jls Home Built 3 December 31st 04 07:48 PM
