USA PF Brick question
Old August 12th 12, 01:58 AM posted to rec.aviation.soaring
Andy[_1_]
Default USA PF Brick question
I've been getting familiar with my PowerFLARM brick and Butterfly display before installing it.
I created a flarmcfg.txt file and loaded it using a USB stick. The file loads ok as confirmed by the configuration indicating my glider ICAO address. However, after the expected flashing green/red LED sequence, the LED ends up being amber which is supposed to indicate the start-up sequence is still active. The unit operates normally and detects traffic. The LED stays amber whether the stick is removed or not.
On the next power up with memory stick removed, the LED ends up being green and the ICAO address is retained.
Anyone else see this amber LED after loading? If so, do you have an explanation?
thanks,
GY
Powerflarm Brick feedback Ramy Soaring 7 August 10th 12 01:02 AM
Measured current draw, PowerFlarm Brick Evan Ludeman[_4_] Soaring 4 July 16th 12 12:03 AM
PowerFlarm Brick - Can it send GPS sentences to SN10B? WaltWX[_2_] Soaring 11 June 17th 12 05:33 PM
PowerFLARM 'brick' progress? Frank Paynter[_2_] Soaring 5 November 13th 11 07:28 PM
Display for PowerFLARM brick Andy[_1_] Soaring 4 May 10th 11 02:32 PM
