#21
I use my Westbend clock which I fastened with velcro. I start when departing
and stop after I have cleared the active. I may be shorting my logbook, but who cares as long as I do not inflate my time. Of course I can always substantiate my time since I log every fuel purchase with tach and hobs time. Hank |
I log what ever my transponder says I flew.
Jay Honeck wrote: With built-in flight timers becoming the norm in virtually all new avionics (heck, even the new transponder I'm getting has one), just wondering if folks are migrating away from using hobbs/tach time to record their flight time? And if you *are* using the flight timer, have you stopped using the old archaic "1.3 hours" method of recording flight time? Anyone using actual hours and minutes in their logbook instead? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Tony Cox" writes:
"Teacherjh" wrote in message ... It's been an hour and eighteen minutes. Do you log it as 1.3? Do you log it if you actually managed to get three feet in the air for twelve seconds before aborting the takeoff and landing again on the mile of runway remaining? If your intent was flight (even if you didn't get off the ground), then my understanding is that you can indeed log it. And why not? In the hypothetical (it *is*, right?), he got the engine started, talked to Departure, Ground, and Tower, dodged big iron and got to the starting point of the runway at a huge, confusing airport...that's lots more work than I do to go around the patch at my non-towered field. |
With built-in flight timers becoming the norm . . .
Here in Canada we are required to record flight time and air time. Flight time for any leg is taken straight from the Hobbs. Air time is Hobbs minus .2 hour per leg (for runup/taxi etc.) That is the way that I record all of my flights. Air time is the time that we record as TBO. Therefore the more legs we squeeze in, the more .2 hour deductions and the longer to TBO. I know one pilot who doesn't have a Hobbs, and who only records about half his actual time. Having witnessed this I personally would prefer, in the interests of safety, to see Hobbs time as a legal requirement - rather like an oddometer reading is required for a used car sale. It scares me to think that there may be aircraft out there with over 2000 TBO which are being sold as less than 1000 TBO. -- Tony Roberts PP-ASEL VFR OTT Night Almost Instrument ![]() Cessna 172H C-GICE |
The hobbs seems like a perfect, simple
device. True, except most aircraft (outside of trainers) don't seem to have them. Mine doesn't, and never did. That, and you're stuck using the ridiculous (to me) "1.4 hours" nonsense. Why don't we just use "1:24", like the rest of the civilized world? When I get this new transponder, I'm going to try using its internal "flight time" clock. If it's too much of a pain, I'll go back to the tach time x 1.3. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Bob Fry" wrote in message
... "Tony Cox" writes: "Teacherjh" wrote in message ... It's been an hour and eighteen minutes. Do you log it as 1.3? Do you log it if you actually managed to get three feet in the air for twelve seconds before aborting the takeoff and landing again on the mile of runway remaining? If your intent was flight (even if you didn't get off the ground), then my understanding is that you can indeed log it. And why not? In the hypothetical (it *is*, right?), he got the engine started, talked to Departure, Ground, and Tower, dodged big iron and got to the starting point of the runway at a huge, confusing airport...that's lots more work than I do to go around the patch at my non-towered field. Yes, but if his intention was just to do a fast taxi, he'd do all the same talking, dodging & ground navigating but not be able to log it. Odd, don't you think? |
![]() "A Lieberman" wrote in message ... Tom Sixkiller wrote: At what point can one start recording _Flight Time_? Engine start? First master switch? I could'nt find anything in the FARS for "when" to start counting, but I am under the impression from my experiences, that anytime the prop is turning is the time you count. That's about what I've always used; from engine startup. |
![]() "Ron Rosenfeld" wrote in message ... On Sun, 21 Dec 2003 11:00:59 -0800, A Lieberman wrote: I could'nt find anything in the FARS for "when" to start counting, but I am under the impression from my experiences, that anytime the prop is turning is the time you count. You didn't look at the beginning: 14CFR Part 1 Sec 1.1 Flight time means: (1) Pilot time that commences when an aircraft moves under its own power for the purpose of flight and ends when the aircraft comes to rest after landing; or (2) For a glider without self-launch capability, pilot time that commences when the glider is towed for the purpose of flight and ends when the glider comes to rest after landing. For most people with a Hobbs, that could be an extra half hour, from master switch "ON", to shutdown. I wonder: does ANYONE does it that way? |
#29
![]() "Ron Natalie" wrote in message m... "Tom Sixkiller" wrote in message ... At what point can one start recording _Flight Time_? Engine start? First master switch? Since we are talking pilot time (we have bounced back and forth here), the rules say: elapsed time form the time the aircraft first moves under its own power for the purpose of flight until the time it comes to rest at its . Since my plane rears forward a little bit at engine start, and I don't tend to run it for very long when I finally get fully parked, the ENGINE RUNNING (hobbs) time is usually pretty danged close to the definition. I remember, several years back, a lot of pilots would do their engine start, and THEN do their ATIS, CD, Ground... Too expensive to do it that way except for the corporate jocks, big iron... |
#30
Jay Honeck wrote:
I log the following: Hobbs start/Hobbs stop Tach start/Tach stop Clock start/Clock stop Wheels off/Wheels on Why do you log four different times? And *where* do you log them? I rent, so the airplanes have different setups. The Champ has no electrical system, so I have Tach time. Depending on how "fast" (that's a relative term) or slow I fly, the clock time may be greater or less than the tach. On other aircraft with electrical systems, a Hobbs and a Tach, the time will varyfor several reasons. For example, the Hobbs on the Cherokee Six is tied to the oil pressure switch. Until the Tachometer gets above 1600 RPM, the Hobbs doesn't move. By recording Clock start/Clock stop, I have a true reference to Hobbs and Tach. By recording Wheels off/Wheels on, I have an accurate measure of actual flight time. What goes in the logbook is the greater of the three. I have made my own logging cards (5x8 blank index). I have also included blocks for logging fuel used from each tank to maintain fuel load balance and compare to the totalizer. The Cherokee Six and Bonanza have four tanks, do I included blocks for each. The logging card has space for five legs on each side. I have a four-hold punch for flip plates. I include logging cards with each aircraft checklist. The following block titles are used: DATE AIRCRAFT N-NUMBER DEPARTURE AIRPORT DESTINATION AIRPORT TACH START TACH STOP TACH FLIGHT HOBBS START HOBBS STOP HOBBS FLIGHT CLOCK START CLOCK STOP CLOCK FLIGHT WHEELS OFF WHEELS OFF BLOCK TIME RIGHT TIP RIGHT MAIN LEFT MAIN LEFT TIP |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
p3/95 | [email protected] | Military Aviation | 1 | September 27th 04 12:27 AM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
