Does anyone know of any adapters or such that would allow hooking up
an audio recorder to record all cockpit communications? ie, both transmissions to ATC and conversations to other passengers. Thanks, Glenn |
"Glenn Westfall" wrote in message
Does anyone know of any adapters or such that would allow hooking up an audio recorder to record all cockpit communications? ie, both transmissions to ATC and conversations to other passengers. Assuming your aircraft has an intercom, you can make a direct-connect cable using Gene Whitt's directions found he http://tinyurl.com/36x3c I typically use a portable intercom that has an audio out jack. I use a patch cord to connect that to either my voice recorder or my video recorder. Having the portable intercom handy also provides a battery-powered backup for the plane's intercom (actually used in that capacity once). -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
cable using Gene Whitt's directions found he http://tinyurl.com/36x3c I've made one of these cables, and they work good. I don't mess with tapes, though. I bought an Olympus DM-1 digital recorder.. With the included 64MB Smart Media, it will record for 10 hours on best quality. Double that if you get a 128MB card. (Which is the max you can use). It also plays back MP3/WMA format music files too. Here's a small .wav clip from one of my recordings: http://tinyurl.com/2ycds -- Ben C-172 - N13258 @ 87Y |
"Ben Smith" wrote in message ...
Assuming your aircraft has an intercom, you can make a direct-connect cable using Gene Whitt's directions found he http://tinyurl.com/36x3c I've made one of these cables, and they work good. I don't mess with tapes, though. I bought an Olympus DM-1 digital recorder.. With the included 64MB Smart Media, it will record for 10 hours on best quality. Double that if you get a 128MB card. (Which is the max you can use). It also plays back MP3/WMA format music files too. Here's a small .wav clip from one of my recordings: http://tinyurl.com/2ycds I record all my flights with students using a tiny digital recorder. I have a very simple system that works wonderfully. You don't have to tap into the intercom system. It is so simple that I record every single flight, whether it is useful or not. I have written an article about the setup on my website. http://www.geocities.com/asarangan/aviation (and click on Cockpit Voice Recorders). |
"Andrew Sarangan" wrote in message
om... I record all my flights with students using a tiny digital recorder. I have a very simple system that works wonderfully. You don't have to tap into the intercom system. It is so simple that I record every single flight, whether it is useful or not. I have written an article about the setup on my website. http://www.geocities.com/asarangan/aviation (and click on Cockpit Voice Recorders). That's pretty cool. Even more straightforwardly, if you have a spare headset and intercom station, you can just give the recorder its own headset, pressing the two ear pieces together with the recorder in between. I think I'll try that next time I fly. --Gary |
![]() Gary Drescher wrote: That's pretty cool. Even more straightforwardly, if you have a spare headset and intercom station, you can just give the recorder its own headset, pressing the two ear pieces together with the recorder in between. Would the "pilot isolate" or "crew isolate" feature interfere with that? George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
Would this work? Plug in a headphone adapter that goes from the big size to the small walkman size in an unused intercom jack. Run an extension cable from the adapter to the mic in on a recorder or video camera. Not necessarily. You have to consider the impedance differences. -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
The impedance of the aircraft headsets are quite different than the
audio inputs of walkmans (I can't recall the numbers). You could use an impedance matching network, but now things are starting to get complicated. Since I use the recorder for flight instruction, and since I fly a dozen different aircrafts, I did not want to rely on tapping into the intercom system. Every intercom is different, and what worked in one airplane may not work in another. With my arrangement (condenser microphone in the headset), it works in all airplanes equally. If anyone wants to listen to the audio quality from my setup, I will be happy to email you a clip. (Glenn Westfall) wrote in message ... After I posted this message I started thinking about it. Would this work? Plug in a headphone adapter that goes from the big size to the small walkman size in an unused intercom jack. Run an extension cable from the adapter to the mic in on a recorder or video camera. That shoud do the trick correct? The headphone jack of aviation headsets are standard size and can be converted to the smaller size. On 22 Jan 2004 12:26:06 -0800, (Andrew Sarangan) wrote: "Ben Smith" wrote in message ... Assuming your aircraft has an intercom, you can make a direct-connect cable using Gene Whitt's directions found he http://tinyurl.com/36x3c I've made one of these cables, and they work good. I don't mess with tapes, though. I bought an Olympus DM-1 digital recorder.. With the included 64MB Smart Media, it will record for 10 hours on best quality. Double that if you get a 128MB card. (Which is the max you can use). It also plays back MP3/WMA format music files too. Here's a small .wav clip from one of my recordings: http://tinyurl.com/2ycds I record all my flights with students using a tiny digital recorder. I have a very simple system that works wonderfully. You don't have to tap into the intercom system. It is so simple that I record every single flight, whether it is useful or not. I have written an article about the setup on my website. http://www.geocities.com/asarangan/aviation (and click on Cockpit Voice Recorders). |
I did exactly that with my Sony TRV18 Digital camera. It works like a chram.
If you mount the camera in the back seat, just make sure you have it high enough to almost hit the roof. Otherwise you will see nothing but the panel. It's good to see the runway. Marco "Glenn Westfall" wrote in message ... After I posted this message I started thinking about it. Would this work? Plug in a headphone adapter that goes from the big size to the small walkman size in an unused intercom jack. Run an extension cable from the adapter to the mic in on a recorder or video camera. That shoud do the trick correct? The headphone jack of aviation headsets are standard size and can be converted to the smaller size. On 22 Jan 2004 12:26:06 -0800, (Andrew Sarangan) wrote: "Ben Smith" wrote in message ... Assuming your aircraft has an intercom, you can make a direct-connect cable using Gene Whitt's directions found he http://tinyurl.com/36x3c I've made one of these cables, and they work good. I don't mess with tapes, though. I bought an Olympus DM-1 digital recorder.. With the included 64MB Smart Media, it will record for 10 hours on best quality. Double that if you get a 128MB card. (Which is the max you can use). It also plays back MP3/WMA format music files too. Here's a small .wav clip from one of my recordings: http://tinyurl.com/2ycds I record all my flights with students using a tiny digital recorder. I have a very simple system that works wonderfully. You don't have to tap into the intercom system. It is so simple that I record every single flight, whether it is useful or not. I have written an article about the setup on my website. http://www.geocities.com/asarangan/aviation (and click on Cockpit Voice Recorders). Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
backup cockpit lighting | Josef Burger | Instrument Flight Rules | 35 | January 2nd 05 01:23 AM |
Antonov vs Galaxy cockpit | Emilio | Military Aviation | 13 | July 2nd 04 06:15 AM |
Survey - 3 blade prop conversion- Cockpit vibration, happy or not | Fly | Owning | 20 | June 30th 04 05:32 PM |
What are you guys using for cockpit lights these days? | Stealth Pilot | Home Built | 6 | December 9th 03 09:14 AM |
FS DeHavilland Open Cockpit Chipmunk | [email protected] | Aviation Marketplace | 0 | October 14th 03 11:10 AM |
