What are you guys using for cockpit lights these days?
Old December 4th 03, 11:22 AM
Stealth Pilot
Default What are you guys using for cockpit lights these days?
My Tailwind had a really neat cockpit light on a stalk that went on
the fritz on me. It was on a bendable mount attached to one of the
roof struts.
I've been looking around for a few months now and havent found
anything remotely suitable to replace it.
I've even thought of taking one of the mid sized maglites and
machining up a fitting to put it on the end of the flexible mount then
using a 12 volt to 1.5volt stepdown regulator to power it.
I've noticed those little 12 volt dichroic lights are used in the new
boeings as the passenger reading lights so I'd assumed that they were
around as aircraft interior lights but a look around hasnt uncovered
anything.
the light was installed by the previous owner for instrument
illumination on those sneak back after dark long flights. (he was
instrument rated)
my use of it has just been for fetching something from the cockpit
after dark while tenting at flyins.
can anyone point me to a small aircraft quality interior light on a
bendable stalk ? preferably not plastic.
thanks
Stealth Pilot
Australia
These Guys Should Be Looking Forward Chris Home Built 0 October 15th 03 03:09 AM
I **warned** you guys that if you didn't shape up... Jim Home Built 44 September 28th 03 07:10 PM
Awright, you guys C J Campbell Home Built 3 September 1st 03 04:03 AM
LEDs with Strobe lights pekka1510 Home Built 11 September 1st 03 12:36 AM
LED for position lights Jerry Springer Home Built 2 August 19th 03 02:43 AM
