#21
Got'cha!
"bumper" wrote in message ... On Friday, November 1, 2013 8:01:34 AM UTC-7, Dan Marotta wrote: Not sure what you mean by "unloaded" in this context, Bumper. Dan, That's the way my meter is connected as well, "across the bus" and so reads the voltage of whichever battery is connected. What I meant by "unloaded" is also as you describe . . . you can read each battery with no additional load on it if desired. The point being that to use the voltage function of say a Becker radio, the radio has to be turned on to view the voltage and so it applying at least standby current load to the battery. bumper |
Got my panel mounted meter installed yesterday and love it. But then I
found that my radio, transponder, and power supplies for PCAS and Streak no longer worked. I found an unknown in-line fuse in the spaghetti behind the panel and it was blown. I replaced it and recovered the radio but not the others. I'm going back in today... I have fuses at the terminals of my batteries, so the in-line fuse must have been there a long time without my knowledge. The wire was labeled "Battery 1". Maybe there's another. I'll remove them. "bumper" wrote in message ... On Friday, November 1, 2013 8:01:34 AM UTC-7, Dan Marotta wrote: Not sure what you mean by "unloaded" in this context, Bumper. Dan, That's the way my meter is connected as well, "across the bus" and so reads the voltage of whichever battery is connected. What I meant by "unloaded" is also as you describe . . . you can read each battery with no additional load on it if desired. The point being that to use the voltage function of say a Becker radio, the radio has to be turned on to view the voltage and so it applying at least standby current load to the battery. bumper |
Jim,
Sorry to hear about the infant death on your LASCAR LM1200. I also have been using mine for a long time (6 years) without any issue. Try another and get your money back if you can. The super mini LASCAR 1AS-BL, with its 0.22" high LCD, looks really interesting (maybe too small?) but the single threaded stud on the LM series sure is slick! - John |
On Friday, November 1, 2013 10:45:56 AM UTC-5, Admin Gliderguider wrote:
http://www.gliderguider.net/batttery_monitor.htm Just a single 6.5mm hole in the panel and two wires across your on-board battery supply. Developed specifically for use with 12V Sealed Lead Acid/Gel Cell batteries in the range 7-18 Ahr. Notably, the three thresholds (for Green, Yellow & Red) have been preset for batteries which are NOT used while connected to a charger. Regards Allan www.gliderguider.net Will this indicator work with these batteries: http://www.eglider.org/battery-12-vo...e-battery.html ? Kirk 66 |
Check out this one - it's the smallest I can find...
http://uk.farnell.com/jsp/search/pro...sp?sku=1215412 At 04:02 03 November 2013, JohnDeRosa wrote: Jim, Sorry to hear about the infant death on your LASCAR LM1200. I also have been using mine for a long time (6 years) without any issue. Try another and get your money back if you can. The super mini LASCAR 1AS-BL, with its 0.22" high LCD, looks really interesting (maybe too small?) but the single threaded stud on the LM series sure is slick! - John |
This one requires only a 5.5 mm hole in the panel to mount the meter. I
have one in my panel and it is great: http://www.jameco.com/webapp/wcs/sto...001_2095040_-1 Of course, it ships from the USofA... "Bryan Searle" wrote in message ... Check out this one - it's the smallest I can find... http://uk.farnell.com/jsp/search/pro...sp?sku=1215412 At 04:02 03 November 2013, JohnDeRosa wrote: Jim, Sorry to hear about the infant death on your LASCAR LM1200. I also have been using mine for a long time (6 years) without any issue. Try another and get your money back if you can. The super mini LASCAR 1AS-BL, with its 0.22" high LCD, looks really interesting (maybe too small?) but the single threaded stud on the LM series sure is slick! - John |
Good Digital Water Meter Wanted | Paul Remde | Soaring | 11 | April 7th 11 01:25 AM |
Panel mount IFR GPS for training ... | Bud_of_yours | Piloting | 23 | December 24th 06 06:38 PM |
Delcom 960 Panel Mount....... | [email protected] | Aviation Marketplace | 0 | June 27th 06 03:17 AM |
digital air-speed meter can be used in car? | [email protected] | Home Built | 17 | May 30th 06 02:42 AM |
Panel volt meter | Bob C | Soaring | 10 | January 13th 05 12:00 PM |
