![]() "John Clear" wrote in message ... In article , Mike Rhodes wrote: Deakin also covers LOP in alot of his articles, specifically the ones titled 'Where should I run my engine?' He goes into the science of how an engine actually works, and examines how the 'your engine will burn up if you do that' OWTs relate to reality. All of Deakin's articles: http://www.avweb.com/news/columns/182146-1.html So I can ignore all the hysterics and lean to roughness, then enrichen it to smoothness. And we all should do so in any piston engine, as long as the power is markedly below 75%. Without an engine analyzer, you have know way of knowing how bad the fuel/air mixture is in each cylinder. Running at the standard 50F rich of peak EGT puts you right in the 'Red Zone'. Running 100-150F ROP is a better place to run the engine if you can't run LOP smoothly. Most non-fuel injected engines have such large differences in fuel/air mixture between cylinders that they can't be run LOP smoothly. At lower power settings, it doesn't matter much where you run your engine since lower power means lower heat and pressure. Deakin does a much better job of explaining all this. Save your breath. Numerous people have pointed out the articles. Evidently Rhodes is unwilling to read them or cannot comprehend them. |
On Thu, 1 Jul 2004 10:45:43 -0700, "Tom Sixkiller"
wrote: "Mike Rhodes" wrote in message .. . All of Deakin's articles: http://www.avweb.com/news/columns/182146-1.html John So I can ignore all the hysterics and lean to roughness, then enrichen it to smoothness. And we all should do so in any piston engine, as long as the power is markedly below 75%. No...you can read the articles and try to LEARN something instead of shooting your mouth off with your foot still in it. I glanced at one page of Deakin and thought the writing entertaining, & therefore also distracting. That was not intended as a critique of his understanding, though there appears to be a bit of desparation in that regard. Deakin's kind of wordy, especially if its expected to be used as reference material -- like from this news group. I think it unusual to be dissed for not reading something, and I got that feeling even before the above. So I chose not to pour over the material, which is not written as if it were intended to be used for reference. If you have a specific page I'd be glad to check it out; but not all of his articles. If I like that then I may read more, but on my time. Otherwise, quoting the header post by Mr. Scott, (and this is general info as I know/knew it)... Remember, when you are cruising at 60% power, you cannot hurt the engine no matter where you set the mixture control. You can't burn valves or cook the cylinderheads or cause detonation, it just isn't producing enough power to do that. Therefore I think I can assume (for I always have), that no 'red zone' actually exists in cruise throttle, as was mentioned someplace else in the thread. My 2nd reply, which is stated on top of this post (leaning to roughness), is therefore allowed, and without qualification, by the 'can't hurt engine at 60%'. The words "best economy" are in the title of this thread. Mr. Scott's polite reply (thank-you) to my lean-to-roughness said I "may have leaned to a safe setting, maybe not." But this is in conflict with his own statement above, for which he then gave no explanation, except to suggest the engine analyzer. But if the engine is below 75% power then what difference does it make what mixture is in any particular cylinder? If I need economy I go to roughness. If I need speed then I enrichen it to gain power. And I would expect more wear-and-tear at the higher power of richer mixture settings -- _IF_ I get higher power at richer mixture and don't begin to waste fuel. I can monitor my airspeed to see where an another optimum mixture setting exists. (Apologies for putting all my replies into this post, for my first, semi-uneducated post. It was an honest question on my part.) --Mike |
On Thu, 01 Jul 2004 21:44:26 -0500, Mike Rhodes
wrote: But if the engine is below 75% power then what difference does it make what mixture is in any particular cylinder? If I need economy I go to roughness. If I need speed then I enrichen it to gain power. And I would expect more wear-and-tear at the higher power of richer mixture settings -- _IF_ I get higher power at richer mixture and don't begin to waste fuel. I can monitor my airspeed to see where an another optimum mixture setting exists. I think you've got it, at least as I understand it anyway. My only concern was that if you are using a high power setting at below 8,000 feet, leaning to roughness and then richening to smooth operation might put you into the red zone, that zone as defined in Deakin's graph's, which can cause high cylinderhead temperatures. I don't know how much you read through the "Mixture Magic" column, but there's that one, plus four others that go into minute detail on exactly what happens inside the engine on the Ground, Takeoff/Climb, Cruise and Descent. Deakin wrote columns for AVWeb, he wasn't writing NACA white papers. His "Mixture Magic" column included many graphs from Pratt and Whitney as well as Lycoming, Continental and actual test stand results from the GAMI shops. At one point, they boosted turbo pressure to demonstrate graphically what the onset of detonation looked like on the graph. Deakin remarked that the engine definately did not sound happy. This information was represented on a color coded graph. You could see the traces of detonation represented by squiggly lines on the pressure rise. In my opinion, if the subject interests you, you might want to download all five articles and print them out to a color printer so that you can read them at your leisure. I also enlarged those graphs that allowed you to do so and printed them out seperately so I could refer to them from the text. Otherwise the graphs printed out a bit small. It's my opinion that all the information you need to safely and economically operate your engine is there in those five columns. It isn't all conversational text, every single claim he makes is backed up by graphs and/or readouts and pictures. At one point he casually remarked that he wished he had the time to do timed climbs leaning as he climbed to plot the savings in gas and time to climb. One of his readers hopped into his own airplane which was equipped with a JPI EGT analyzer and flew out from under the LA Class B space and then made two climbs to 10,000 feet carefully leaning as he climbed during one climb and leaving it rich for the other. Then he e-mailed Deakin the electronically recorded information and Deakin formatted it into Excel and presented the results in his next column. I have a friend who has just became the owner of a V tail Bonanza, which is what Deakin flies, only Deakin's is turbocharged. He has been flying for a number of years and just cannot bring himself to run it LOP . . . yet. He understands the concept, but was a race driver and builder and engine assembler in his youth, and recalls what happened to his engines if they ran lean. As Deakin mentions though, we aren't talking about leaning during takeoff power operation. We will be trying out LOP operation in the next few weeks to see if the engine will tolerate it without running rough. He does not have GAMI injectors. Corky Scott |
"Ash Wyllie" wrote
GAMI claims something else is going on. Fuel from the upstream injectors is leaking into the downstream intake ports, making the downstream cylinders richer than the upstream cylinders. They can claim anything they want - but if what they were describing was real, the coke bottle test would show it and adjusting the injector nozzles would fix it. AS to intake air distribution, I would assume that it is like the rest of aviation, reliable junk. Junk? Yes. Reliable? I've heard of too many cases (from reliable sources) of the intake system developing leaks, causing cylinders to run overlean and fail. I think the term you're going for is UNreliable junk. Michael |
Michael opined
"Ash Wyllie" wrote GAMI claims something else is going on. Fuel from the upstream injectors is leaking into the downstream intake ports, making the downstream cylinders richer than the upstream cylinders. They can claim anything they want - but if what they were describing was real, the coke bottle test would show it and adjusting the injector nozzles would fix it. The coke bottle test won't find this, as it is an artifact of the way air flows in the intake manifold. And adjusting the injector nozzles is what GAMI is doing. By making accurate injectors designed for each cylinder all cylinders provide the same power. AS to intake air distribution, I would assume that it is like the rest of aviation, reliable junk. Junk? Yes. Reliable? I've heard of too many cases (from reliable sources) of the intake system developing leaks, causing cylinders to run overlean and fail. I think the term you're going for is UNreliable junk. Aircraft engines don't fail in the air, too often... -ash Cthulhu for President! Why vote for a lesser evil? |
On 02 Jul 04 12:03:47 -0500, "Ash Wyllie" wrote:
Michael opined "Ash Wyllie" wrote GAMI claims something else is going on. Fuel from the upstream injectors is leaking into the downstream intake ports, making the downstream cylinders richer than the upstream cylinders. They can claim anything they want - but if what they were describing was real, the coke bottle test would show it and adjusting the injector nozzles would fix it. The coke bottle test won't find this, as it is an artifact of the way air flows in the intake manifold. And adjusting the injector nozzles is what GAMI is doing. By making accurate injectors designed for each cylinder all cylinders provide the same power. snipped.... Do they provide the same power or do they provide the same air/fuel ratio? I don't believe that they can do both. If they are providing the same air/fuel ratio to all cylinders the power that they develop will be dependent upon the volume of air that was getting to each cylinder. If all cylinders are providing the same power, then they must be receiving the same amount of air, which is not the case with most aircraft induction systems that I've seen (not that that is a lot). Not an expert, just curious and want to understand the situation correctly. Rich Russell |
Ash,
causing cylinders to run overlean and fail. NO, NO, NO!!! Running "overlean" does NOT hurt cylinders! This is the core of the OWT surrounding all this. Run the cylinder leaner and leaner - and it will get cooler until combustion quits. A little more correct would be to say "not running lean enough and fail". The correct description is "changing the mixture to a point where the temperatures and pressures in the cylinder failed it". But this is in NO WAY the leanest point, or "overleanest" - whatever that may be. -- Thomas Borchert (EDDH) |
#29
Richard Russell opined
On 02 Jul 04 12:03:47 -0500, "Ash Wyllie" wrote: Michael opined "Ash Wyllie" wrote GAMI claims something else is going on. Fuel from the upstream injectors is leaking into the downstream intake ports, making the downstream cylinders richer than the upstream cylinders. They can claim anything they want - but if what they were describing was real, the coke bottle test would show it and adjusting the injector nozzles would fix it. The coke bottle test won't find this, as it is an artifact of the way air flows in the intake manifold. And adjusting the injector nozzles is what GAMI is doing. By making accurate injectors designed for each cylinder all cylinders provide the same power. snipped.... Do they provide the same power or do they provide the same air/fuel ratio? I don't believe that they can do both. If they are providing the same air/fuel ratio to all cylinders the power that they develop will be dependent upon the volume of air that was getting to each cylinder. If all cylinders are providing the same power, then they must be receiving the same amount of air, which is not the case with most aircraft induction systems that I've seen (not that that is a lot). Not an expert, just curious and want to understand the situation correctly. Same mixture. -ash Cthulhu for President! Why vote for a lesser evil? |
#30
Thomas Borchert wrote
NO, NO, NO!!! Running "overlean" does NOT hurt cylinders! It does at takeoff power. At takeoff power, a VERY rich mixture (probably 200 degrees rich of peak, or more) is normally and properly used. An induction leak can cause the mixture to be significantly leaner, meaning much closer to peak. Running at peak EGT at takeoff power most certainly will hurt the cylinders. If the induction leak was bad enough that a cylinder was running well lean of peak, that would probably be OK - but in that case, there would be noticeable roughness and loss of power. The insidious thing about a slight induction leak is that there is no loss of power - in fact there is a slight gain - and smooth operation is maintained right to peak on the affected cylinder. Without all-cylinder EGT, this is undetectable. The design of the induction systems in certified aircraft engines is such that they are prone to this problem of having one jug running at close to peak due to an induction leak while the other jugs run well rich. Thus they are, by design, unreliable junk. I'm sorry if you found the term "overlean" confusing. In this context, it simply means leaner than is proper for the operation. Michael |
What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Naval Aviation | 5 | August 21st 04 12:50 AM |
What's Wrong with Economics and how can it be Fixed | What's Wrong with Economics and how can it be Fixe | Military Aviation | 3 | August 21st 04 12:40 AM |
Power settings for 182RG | Andrew Gideon | Piloting | 19 | March 3rd 04 07:41 PM |
Cessna 404 Cruise settings | Katia | General Aviation | 0 | December 19th 03 05:04 PM |
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 04:00 PM |
