Why do gyros use tilt head rather than swashplate
Old August 3rd 03, 05:43 PM
Ken Sandyeggo
(Stephen Austin) wrote in message ...
Let me jump in here a little. I got to ride with John Potter at
Paducah, KY last winter in an Air & Space.
I think the key word there is winter. Low density altitude is key.
Once the proper rotor rpm was reached, John reached to the panel and
pressed a button.
Hmm, well, the button on the panel is to engage the prerotator clutch. If
you'll remember, once that button is pushed the throttle is increased so the
engine is about 1500 RPM. At that point you begin pumping the hydraulic lever
to engage the clutch. You slowly pump the handle to maintain continous
pressure while at the same time working the throttle to maintain 800 RPM. It
is very much like engaging the clutch on an Enstrom. Once rotor RPM and engine
RPM marry the handle is quickly pumped until the engage button on the panel
pops out. This indicates the system is fully engaged. From then the RPM is
increased to 370 RPM.
The blades instantly repitched and we shot straight
up like a rocket. I'm sure that the transmission disengages
simultaneously.
The blades are depitched by pushing a button on the top of the throttle. Hehe,
it all happens so quickly that it is easy to lose track of what happens when.
That's why the depitch button is on the throttle. It would take too long to
push a button on the panel and then have to bring your hand back to the
throttle.
The ship reaches maybe 30-40 feet and smoothly
transitions into forward flight and a climb mode. There is no loss of
altitude during the transition.
Winter had a lot to do with that. Jump takeoff is unlikely above a 2000' DA.
No doubt pilot skill, gross weight, wind, etc. play a major part. But I do
know that when I've flown the 18A it was in the summer. Max jump height was
about fifteen feet and after the jump we sunk to about five feet before we got
ahead of the power curve and established a climb. I do remember also that if,
after the jump, the aircraft settles to the ground, power must be reduced and
the sequence started all over again.
BTW, for a jump, the rotor is spun to 370 RPM. Operating RPM green arc is from
200-320 RPM. It's all a bit tricky but quickly becomes second nature.
Regardless the 18A is a great flying ship.
Stephen Austin
Austin Ag Aviation
Charleston, Missouri
Hi Steve,
Thanks for the technical straightening out. It does happen quickly
and you're right, I missed a lot of it. It is a kick to ride in. It
was the middle of winter....I think the temp was in the low 20s. I'm
sure the jump wouldn't be as impressive on a hot day at some altitude.
John is still restoring them at about 2-3 per year and you can buy one
ready to go in like-new condition......I'm going to guess here
again.....around a 100 thou if I recall the number John gave me. I'm
thinking it was either a little more or a little less. Short-term
memory must be going.
Ken J. - Sandy Eggo
Old August 3rd 03, 08:04 PM
Michael Pilla
"Stephen Austin" wrote in message
NJ, but I forget the town. Even though the
airstrip was in the Western (less populated portion of the state - rural,
actually), the local residents were the highly paid, city-commuter types
(NYC) and, apparently both vocal and influential. The 18A clearly was
louder than the other planes (typical spam can range, plus a goodly
amount
of low-powered Cubs, Champs, etc.) - it definitely stood out during ops.
Michael Pilla
Man, don't you hate that? Was it one of those deals where the airport was
there long before any of the homes?
Stephen Austin
Austin Ag Aviation
Of course. But, of course, that is irrelevant to those who move, later.
Even Steve Forbes, of Forbes magazine, fought the improvements at a small
airport that was near his property even though, years earlier, the airport
owners supported Forbes when he wanted to have an exemption to zoning
ordinances. The record was clear: airport owners supported him, he
vociferously opposed their improvements. Result: Forbes: 2, Somerset
Airport, 0.
Michael Pilla
Old August 4th 03, 03:36 AM
Terry Spragg
Rod Buck wrote:
In message , lid writes
You lost me there. I was talking about the use of a tilt rotor (with a
fixed pitch) on a helicopter. Other than losing auto-rotation, what is the
downside? I know losing auto-rotation IS a big deal. I saw a coaxial kit
that uses a tiltrotor (no swashplate, no collective...no auto-rotation) But
they have two engines. Seems like dropping all the extra hardware for pitch
control (they use engine speed to control lift) would be a good thing.
Look, you can alter the lift force of a rotor by two methods. Either you
keep the same rotor rpm, and alter the pitch angle of the blades, OR you
keep the blade angle the same, and alter the rotor RPM.
Or, of course, a combination of the two.
The problem is that, without collective pitch control, you can only vary
the lift force by increasing or decreasing rotor rpm, ie by altering
engine power.
This is very slow to act, due to rotor inertia (flywheel effect) and
means that control is extremely sluggish and imprecise compared to
collective pitch control, where the rotor speed is constant, but the
attack angle of the blades is changed instantly.
You do NOT need a collective-pitch control to change from powered flight
to autorotation - you could just set the blades to autorotation angle to
start with, and then vary power to increase lift - then, if the engine
quit, the freewheel device in the drive chain would let the blades
outspeed the engine, and you'd enter autorotation automatically.
The confusion you are having is, I think, because you (and several
others) think that the blades have to be at positive pitch for powered
flight, and altered to negative pitch (nose-down to the plane of the
rotor disk) for autos. THIS IS INCORRECT.
Blades autorotate perfectly well with a small positive pitch angle -
normally about 1-3 degrees (depends on the airfoil used)
Rod Buck
Well...
You also change the flight path. The blades need to see an
updraught to absorb power to spin, to generate lift somehow.
The change in direction of the airflow between a nose down
attitude under power in a helo and a nose up, direction slightly
down for autorotation makes the mechanical aoa at the hub
different from the aoa of the airflow on the rotor.
I cannot claim any authority for this beyond personal
experimentation, and my conjecture, apparantly widely debated if
not misunderstood, seems in at least a common sense way to be
true.
A small toy illustrates a point which becomes intuitive. A stick
twirled between the palms with rotor blades attached ascends
until the energy stored on the rotor is consumed. The toy begins
to descend rapidly. The rotor reverses and spins up. The descent
slows dramatically.
The apparent wind on the blades must be at a + aoa to
autorotate, even if the aoa at the reversed hub wrt the shaft may
be -, and the airflow presents a greater + to the reversed blade
with as much - mechanical aoa as it was + rotating in the
ascending phase, spinning it up by energising it, and with
increase in apparent airspeed of the rotor the aoa becomes less +
in regard to the flightpath of the blade arounds the hub, while
being - to the airflow around the craft. Autorotation is a
delicate balance, yes? One must fly the collective carefully to
do autos. It is a skill I cannot claim.
The airflow changes from downward to upward on the rotor blades
of the toy. If the hub rotation does not reverse, the +
mechanical aoa of a powered nose up gyro becomes - wrt the
airflow in the retreating blade, the flight path becomes
downward, wrt apparent airflow to the craft now nose down wrt
horizon, but still + in one sense, and - in another. In
autorotation, part of the rotor's flightpath must be - aoa wrt
the aparrent airflow on the blade.
Watch the toy fly again. Meditate some more. Grok the universe.
Be one with gravity.
Is it possible to explain this in some other way? I can't seem to
express it well. Perhaps a cartoon video is available somewhere?
This is possibly a flawed intuit, and I cannot yet grasp it all.
I am not a rotorhead, but have watched many autorotations from
the tower at a helo flight school, complete with commentary from
those "3 dimensional thinkers" that direct the traffic. As a
control tower radio tech, I have had some "unofficial" flight
training, er, perhaps I should say unofficial experience in fixed
wing and rotor, and understand aerodynamics to an extent in model
design and flight.
If I claim to be a little perlexed, at least you must respect my
honesty. In autorotation flight, part of the rotor disk must be
in - air aoa, yes or no?
Terry K - My email address is MY PROPERTY, and is protected by
copyright legislation. Permission to reproduce it is
specifically denied for mass mailing and unrequested
solicitations. Reproduction or conveyance for any unauthorised
purpose is THEFT and PLAGIARISM. Abuse is Invasion of privacy
and harassment. Abusers may be prosecuted. -This notice footer
released to public domain. Spamspoof salad by spamchock -
SofDevCo
Old August 4th 03, 04:00 AM
Phil Miller
On Mon, 04 Aug 2003 02:36:31 GMT, Terry Spragg
G'day Terry,
I am going to read your post in full again offline, but let me answer
this bit quickly.
There is no need for any part of the aerofoil to be in -ve AoA. It is
not blown around like a toy fan. Have a look at this page
http://www.copters.com/aero/autorotation.html
See in figure 2-89 that because of the upward inflow the lift vector is
tilted forward? The portion of lift in the forward direction acts to
pull the blade forward (or around).
Hope this helps. I'll reread your post and send some more later, if
required.
Cheers,
Phil
Pfft...english! Who needs that? I'm never going to England.
Homer J. Simpson
Old August 4th 03, 11:41 PM
Rhodesst
Hi Phil,
Great link! Turns out I understood this stuff better than I thought I did.
I've read plenty about the physics, just never seen it laid out this well in
pictures. Thanks for posting it.
Fly Safe,
Steve R.
Old August 5th 03, 12:37 AM
Phil Miller
Hi Phil,
No probs, Steve.
Google is a wonderful tool. I typed in "autorotation" and that was one
of the first ones listed. :-)
Phil
I am so smart...S.M.R.T.
Homer J. Simpson
Old August 5th 03, 12:50 AM
Phil Miller
Well...
G'day Terry,
Did the page I pointed you to help at all?
Yeah.
The blades need to see an updraught
Yep.
Not sure what this means?
Not sure what you mean by mechanical AoA at the hub, but the AoA of the
blades increases (more +ve), for the same pitch angle, with an upward
flowing airstream.
true.
slows dramatically.
ISTR from childhood playing with this type of device, but I don't
remember them reversing direction of rotation during flight. They would
descend as rpm decreased. Are you just doing a thought experiment and
extending the flight?
autorotate,
Yeah.
be -,
Do you mean the *pitch* is -ve because the rotor is now turning in
reverse?
No. I lost it completely there. Are you saying that although the toy,
now spinning in reverse, seems to have a -ve pitch, it actually has a
+ve AoA because it is descending?
Autorotation is a delicate balance, yes?
One must fly the collective carefully to do autos.
As I understand it (and I never got that far in my (limited) experience
in helicopters), it's a matter of engine failure...collective to minimum
ASAP...leave it there until the correct height above the ground...pull
collective to flare. It's not a matter of adjusting the collective
during the auto. I stand ready to be corrected by those in the know.
As for gyroplanes, they will happily autorotate all day without any
means to vary the pitch collectively at all.
No. And this is where you are striking trouble, I suspect. The AoA on
the retreating blade does not go -ve. In fact, if anything, the
retreating blade has a higher angle of attack than the advancing blade
(but that is another discussion). the rotor disk is tilted back, yes,
but the blade is doing several hundred miles per hour. The apparent wind
is several hundred miles per hour *in the direction of travel* (plus a
downward component). The direction of the craft has an influence, but
not as significant as I think you think.
I don't see what you mean. Unless you are thinking that the airflow
caused by craft movement is the apparent airflow. In an aeroplane this
would be the case, but an aeroplane's wings are not doing several
hundred miles an hour and creating their own apparent airflow.
Ooom...OOooommm...
design and flight.
My vote? No.
Cheers,
Phil
Definitions of a pilot - No. 1
The average pilot, despite the sometimes swaggering exterior,
is very much capable of such feelings as love, affection,
intimacy and caring.
These feelings just don't involve anybody else.
US Navy Times
Old August 5th 03, 05:43 AM
Rhodesst
flowing airstream.
I think what they're refering to when they say "mechanical AoA" is blade
incidence.
Fixed wing aircraft generally have their wings set a some positive incidence
relative to the long axis (longitudinal) of the fuselage. The main reason for
this, as I understand it, is so the fuse will fly in a level attitude at cruise
while allowing the wing to fly at a positive AoA to produce the lift needed to
maintain flight. This positive incidence is fixed and cannot be changed or
adjusted by the pilot.
Helicopters, OTOH, adjust the incidence of their rotor blades through
collective and cyclic commands. In this case, the incidence is a measurement
of the angle of the rotor blade cord line relative to an imaginary line running
perpendicular (90 degrees to) the rotor mast. While changing the incidence of
the main rotor blades (through collective and cyclic commands) will change the
aerodynamic AoA, they are not the same thing. For example, if you could lower
the collective to a negative "incidence" (I'm not sure if full size helicopters
do this, I know that RC models do), the rotor blades would still be seeing a
positive AoA while in flight due to the steep descent angle.
FWIW,
Fly SAfe,
Steve R.
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Bothersome Phillips Head Screws Larry Smith Home Built 48 January 10th 04 04:26 AM
Aviano thanks base guardians as Puerto Rican guardsmen head home Otis Willie Military Aviation 0 September 1st 03 02:24 AM
Child head set Dennis O'Connor Piloting 7 July 15th 03 01:55 PM
Citabria with gyros Bob Esser Piloting 6 July 9th 03 12:03 AM
