Why do gyros use tilt head rather than swashplate
Old July 21st 03, 09:21 AM
Phillip
Default Why do gyros use tilt head rather than swashplate
Would a gyro with a swashplate ( just for pitch control) fly any different
(better,worse) than using a tilt type rotor head? Just more complex?
Also, I've seen some photos of early kit helicopters that appear to have
just a tilting head (no way to auto-rotate ?). Isn't this a bit of a death
wish? Does a helicopter need to have collective pitch for anything other
than auto-rotaion?
Silly questions, but it's a late night.
Old July 22nd 03, 12:52 AM
Phillip
"Rhodesst" wrote in message
Power adjustments. Wally
Power adjustments? I don't see the difference a swashplate over a tilt
head
for cyclic control would make to a gyros rotor system. Care to explain
further?
OTOH, I think that sport gyros today use the tilt rotor hub because it's a
very
simple design, and it works very well. No swashplate and associated
linkages,
not to mention the fact that there's no need for individual feathering
hinges
on the rotor blades themselves. Much less to go wrong and/or maintain.
JMO,
Fly Safe,
Steve R.
The K.I.S.S. formula at it's best.
So why not on a helicopter? (Like those old kits I mentioned). I'm assuming
because you'd lose auto-rotation?
Old July 22nd 03, 01:43 AM
Phil Miller
Just more complex. The net effect would be the same. Increase the angle
of attack 90 degrees before desired disc upward movement, decrease AoA
90 degrees before. Gyroscopic precession then makes the desire movement
happen.
than auto-rotaion?
Helicopter collective increase/decreases pitch angle of all blades
collectively and thereby increases/decreases lift. Pull collective up,
go up. lower collective, go down. It's a bit more complex than that, but
I'll leave that to the experts here.
Phil
Definitions of a pilot - No. 1
The average pilot, despite the sometimes swaggering exterior,
is very much capable of such feelings as love, affection,
intimacy and caring.
These feelings just don't involve anybody else.
US Navy Times
Old July 22nd 03, 02:08 AM
Stan Gosnell
"Phillip" wrote in
appear to have just a tilting head (no way to auto-rotate
?). Isn't this a bit of a death wish? Does a helicopter
need to have collective pitch for anything other than
auto-rotaion?
Helicopters depend on collective pitch for control of power -
they have no other way to fly. Without collective pitch, you
can't get off the ground, or change power, or get back on the
ground in one piece.
Regards,
Stan
Old July 22nd 03, 03:02 AM
Guy Alcala
Stan Gosnell wrote:
"Phillip" wrote in
auto-rotaion?
IIRC, at least the first Piasecki helo and maybe the first Hiller
lacked collective pitch. Lift was controlled by the throttle
(which controlled the engine and thus rotor rpm), and they seemed
to have flown just fine. There are clearly advantages to the
collective system as later models all included it, but it's not
as if a helo has to have one to fly.
Guy
Old July 22nd 03, 03:55 AM
Phillip
"Guy Alcala" wrote in message
Stan Gosnell wrote:
"Phillip" wrote in
auto-rotaion?
Guy
I guess what I wondered was , other than a need to auto-rotate, a tilt
system would work on a helicopter the same as a gyro? Yes I know
auto-rotation is needed...I'm just wounding if the concept is the same.
That's what these kits mentioned (it's been a long time), you added power
to go up, remove power to come down...seems simple enough. Don't think I'd
like the idea of no collective control for auto-rotation.
Old July 22nd 03, 04:09 AM
Phil Miller
On Tue, 22 Jul 2003 10:43:27 +1000, Phil Miller
happen.
Woops. After.
than auto-rotaion?
Phil
Phil
"Me fail english? That's unpossible!"
Ralph Wiggum
Old July 22nd 03, 11:07 PM
Paul Baechler
head
further?
very
linkages,
hinges
JMO,
Fly Safe,
Steve R.
The basic principle of autogyro flight is auto-rotation. What you'd lose
is a simple, practical way of controlling powered flight.
Paul Baechler
Old July 23rd 03, 07:41 AM
Phillip
"Bart" wrote in message
power
I'd
No, a helicopter can not operate without a swashplate. Without the
swashplate
you'd just be able to go up and down. I'll probably draw some heat here
for
this,
but autogyros have more in common with airplanes than they do helicopters.
The aerodynamics are really different.
In horizontal flight, a helicopter is constantly changing the pitch of
each main rotor blade independently as it travels around in the circuit.
The advancing blade has negative relative pitch, and the retreating blade
has hugely positive relative pitch. Horizontal thrust is not derived by
tilting the mast.
The swashplate is controlled by the cyclic and collective together. The
two
flight controls are "mixed together" to move the swashplate. The
collective
moves the pitch of all blades equally, the cyclic tilts the swashplate to
cause the pitch changes to be become "cyclical".
Bart
I see those brothers (Nolan ?? ) built a coaxial with no swash plate....but
also no auto-rotation. twin engine though. How do they get away with it? I
guess the twin rotors would cancel all those bad things out.
This is one of the kits I saw.
http://www.airscooter.com
No swashplates, no collective, NO AUTOROTATION (scary) two engines I think.
Old July 25th 03, 01:22 PM
Phil Miller
On Fri, 25 Jul 2003 11:57:53 GMT, Terry Spragg
For the simplest possible reason:
An auto gyro is always flown in autorotation, with fixed plade
pitch set for 'gliding'. If you apply torque to an auto rotor,
you do not get lift, you get propelled groundward.
G'day Terry,
Are you saying that autogyro's have negative pitch on their rotor
blades? If so, you are wrong.
If that's not what your saying, I apologise. I have misunderstood your
meaning. Could you please explain this statement?
Cheers,
Phil
Pfft...english! Who needs that? I'm never going to England.
Homer J. Simpson
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Bothersome Phillips Head Screws Larry Smith Home Built 48 January 10th 04 04:26 AM
Aviano thanks base guardians as Puerto Rican guardsmen head home Otis Willie Military Aviation 0 September 1st 03 02:24 AM
Child head set Dennis O'Connor Piloting 7 July 15th 03 01:55 PM
Citabria with gyros Bob Esser Piloting 6 July 9th 03 12:03 AM
