TE probe installation
Old December 6th 14, 10:59 PM posted to rec.aviation.soaring
Dave Nadler
Default TE probe installation
On Saturday, December 6, 2014 12:27:42 AM UTC-5, krasw wrote:
... variometer does not care about the absolute pressure.
Really? What happens at 10,000 feet vs. sea level?
Discuss amongst yourselves...
Old December 7th 14, 12:05 AM posted to rec.aviation.soaring
Jim Lewis[_2_]
Well, let's see. The air is less dense at 10,000 MSL than it is at sea level. One formula for force is F = ma. This suggests the air flow through the variometer would produce less force at 10,000MSL than
it would at sea level. If the variometer is a vane-type variometer perhaps the variometer vane would not be moved as much at 10,000 MSL than it would be at sea level. So... the variometer would read less lift/drag at 10,000 MSL than it would at sea level? Just a guess. I really have no idea.
Old December 7th 14, 12:44 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
In it's most simplistic for a vario measures differences in pressure over
time. Again in the most simplistic form the instrument measures the rate of
flow of air from a sealed flask trying to equalise the pressure within it
to the outside air (static). It converts the rate of flow to give an
indication of the rate of climb/descent. In that respect it does not care
about the absolute pressure. Whether the reduced air density in the flow
will cause any detectable change in the indication is debatable, I can't
see why it should.
Modern electronic instruments calculate a rate by comparing minute
differences in pressure directly. If the instrument is measuring changes in
pressure then it relies on the absolute pressure value entirely. In this
type of instrument the altitude will make no difference.
Old December 7th 14, 02:39 PM posted to rec.aviation.soaring
Dave Nadler
On Saturday, December 6, 2014 12:55:05 PM UTC-5, Jim Lewis wrote:
I understand now that the TE probe (and the pitot probe,
for that matter) cannot help but sense static pressure -
in addition to dynamic pressure.
Right! This is easy to understand by considering the pressure
sensed by TE or pitot probes with glider on the ground.
Old December 7th 14, 04:46 PM posted to rec.aviation.soaring
Dan Marotta
Seems to me that if the vario measures a volume rate of flow, then at
higher altitudes, for a given change in altitude, the change of pressure
would be less (recall that pressure change is non linear with altitude),
hence a lower volume flow, hence a lower rate of change reading (lift or
sink).
So, if I'm climbing at 10 kts at sea level and my vario reads 10 due to
some finite number of moles or molecules of gas exiting the flask, past
a sensor, to the atmosphere, I'd think that, at 18,000' MSL where the
static pressure is roughly half what it is at sea level, then the volume
of air leaving the flask and passing the sensor would be roughly half of
what it was at sea level, then an absolute climb rate of 10 kts would be
displayed at something more like 5 kts. It probably doesn't make a damn
bit of difference anyway.
Flash update! I passed this by my wife (who's a current student glider
pilot) and she opened the topic of indicated vs. true speed. I think
that's the answer. We'll be reading an indicated 10kts regardless of
altitude but our true rate of climb will depend upon altitude. I think
that supports what I said above but I'd still like a mathematical
explanation.
Would somebody with an actual education in the subject please explain it
for the rest of us?
Dan Marotta
Old December 7th 14, 05:55 PM posted to rec.aviation.soaring
sink).
explanation.
for the rest of us?
Dan Marotta
What you have described is generally correct for FLOW type variometers such as mechanical instruments and early electric instruments. Almost all modern electric varios use pressure transducers and do not have the change in flow volume to consider.
UH
Old December 7th 14, 06:16 PM posted to rec.aviation.soaring
Dave Nadler
How you sense the pressure is unimportant.
The pressure change between 0 and 1 feet MSL is much larger
than the pressure difference between 10,000 and 10,001 feet MSL.
Old December 7th 14, 06:56 PM posted to rec.aviation.soaring
Looking at my decade old code for a transducer based variometer, I see that I went to a bit of trouble to convert pressure to ISA altitude before differentiating to get rate of climb. For even more amusement, consider the relationships between "altitude corrected" rate of climb, IAS, TAS, calculated total energy compensation, and speed to fly...
Marc
  #29
Old December 7th 14, 07:03 PM posted to rec.aviation.soaring
Dave Nadler
Good, but its much easier just to correct by one_over_sigma ;-)
Right, proper instruments consider MC as a 'true' input as
well as correcting vario, IAS-TAS, and of course polar.
Discuss amongst yourselves ;-)
  #30
Old December 7th 14, 08:00 PM posted to rec.aviation.soaring
Dan Marotta
....And it's not even officially winter yet...
OK, I understand about correcting the transducer based altitude,
corrected for ISA, so I guess you're using your static and OAT inputs to
calculate altitude before calculating and displaying the rate of change.
So am I to understand, then, that my mechanical vario is displaying
*indicated* rate of lift/sink while my electronic vario is displaying
*true* rate of lift/sink? I guess I'll take a close look on my next
wave flight.
Dan Marotta
TE probe? [email protected] Soaring 12 July 29th 14 03:54 AM
TE probe up or down? kirk.stant Soaring 25 September 29th 10 07:48 PM
Ka-6 TE Probe vontresc Soaring 14 August 30th 08 03:17 AM
TE Probe on ASW-15 [email protected] Soaring 4 April 29th 07 01:43 AM
TE-Probe for 1-26D Heinz Gehlhaar Soaring 6 January 17th 05 10:52 PM
