TE probe?
Old July 25th 14, 04:19 PM posted to rec.aviation.soaring
Default TE probe?
Anyone have any ideas why the TE probe is on the left tip of the horizontal stab of the just announced JS-1 EVO.
Old July 25th 14, 04:52 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default TE probe?
So they could add a few more potential leak points in the line?
Maybe Jet Blast? Is thrust offset to the right?
Old July 25th 14, 04:56 PM posted to rec.aviation.soaring
JS
Default TE probe?
Perspective?
Having additional connections that will eventually leak is the big advantage.
Old July 25th 14, 05:13 PM posted to rec.aviation.soaring
Sean Fidler
Default TE probe?
Interesting. Do you have a link to the photo you have seen?
Sean
Old July 25th 14, 06:02 PM posted to rec.aviation.soaring
Default TE probe?
Nice pic on the Jonkers site.
Old July 25th 14, 06:56 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default TE probe?
No tailwheel visible. Comp number goes awfully far forward on the vertical. Looks a lot like an "assembled" picture.
Old July 26th 14, 03:47 AM posted to rec.aviation.soaring
Default TE probe?
1)Further from the stuff that goes on at the wing root.
2)One flying surface at the tail affecting the pressure field instead of two.
3) Adding complexity for the heck of it
4) Avoiding engine wash
5) Messin' with your mind
UH
Old July 26th 14, 09:42 AM posted to rec.aviation.soaring
Default TE probe?
Maybe they have a stake in LXNav or another vario manufacturer that makes equipment compatible with electronic T.E. that only requires pitot-static to work:-)
Old July 28th 14, 10:25 PM posted to rec.aviation.soaring
Craig Funston
Default TE probe?
For those with Facebook access there's a good picture of the probes on the Aussie's WGC page.
https://www.facebook.com/AUglidingteam
Craig
Old July 28th 14, 10:41 PM posted to rec.aviation.soaring
John Galloway[_1_]
Default TE probe?
probes on the
Aussie's WGC page.
Craig
Don't think that probes in that tailplane location would survive
long on a typical gliding airfield.
John Galloway
TE probe up or down? kirk.stant Soaring 25 September 29th 10 07:48 PM
Ka-6 TE Probe vontresc Soaring 14 August 30th 08 03:17 AM
TE Probe on ASW-15 [email protected] Soaring 4 April 29th 07 01:43 AM
Outside air temperature probe dlevy Owning 9 November 7th 06 05:14 PM
TE-Probe for 1-26D Heinz Gehlhaar Soaring 6 January 17th 05 10:52 PM
