DIY Flight-Computer
Old February 16th 15, 08:27 AM posted to rec.aviation.soaring
Kilo-Bravo
Default DIY Flight-Computer
Am Sonntag, 15. Februar 2015 20:58:20 UTC+1 schrieb Martin Gregorie:
On Sun, 15 Feb 2015 09:49:20 -0800, Charlie M. (UH & 002 owner/pilot)
Looking in this picture...
https://www.facebook.com/453238281445186/photos/
pb.453238281445186.-2207520000.1424006006./475975595838121/?
type=1&permPage=1
I'm guessing the cables run inside the tube in the vertical, but look to
be on the outside/bottom (see the ty-wraps?) on the horizontal.
I see what he's done. The cable bundle is never inside the metal Z-tube
that forms the stick's structure. Instead, the wires run down the outside
of the tube but within the body of the much larger carbon moulding.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Thats correct.
Rgds Klaus
Old February 22nd 15, 07:59 PM posted to rec.aviation.soaring
Fair enough: very often hardware gets picked simply because one of the
technical people has used it before - and nothing wrong with that!
The main reason for choosing the Cubieboard was the LVDS interface that can drive the Pixel Qi LCD without additional hardware. It has good community support, lots of interfaces (four accessible UARTS vs. one on the BBB, touch screen controller, etc.) and a suitable connector layout. This makes the adapterboard easier which is basically just power supply, RS232 level converters and a way of matching LCD and touch screen connectors.
Can you say if you're planning to support touch screens or if the plan is
to control the flight computer entirely from the control column? I can't
see any control switches in the photos of panels.
There are no control switches on the flight computer to keep size to a minimum. They could be easily implemented with a slightly bigger housing, but I really prefer the stick remote for in-flight use. For setup on the ground the touchscreen or a trackball is fine.
Michael
Zander ZS 1 Flight Computer [email protected] Soaring 1 July 28th 13 06:48 AM
leakage through flight computer thomas Soaring 1 June 30th 09 08:30 PM
New technologies flight computer Ed Gaddy[_2_] Soaring 0 July 14th 08 03:41 PM
Flight computer for Sale [email protected] Piloting 0 August 20th 05 06:12 PM
flight computer calculation Tim General Aviation 1 April 26th 05 10:40 AM
