leakage through flight computer
Old June 30th 09, 08:49 PM posted to rec.aviation.soaring
thomas
Default leakage through flight computer
I did a leak test on my instruments and plumbing because I suspect my
ASI to be indicating low. I was surprised to find a rather large
leakage through the MNAV. I understand why the MNAV leaks, but would
welcome input from others on whether my observations are normal or not
before I open the instrument. Without the MNAV, the total pressure
line holds the pressure very well. If I include the MNAV, I am losing
total pressure at a rate of about 10knots/4sec (rough estimate, at
100knots). I didn’t add an additional capacity to the pressure line to
stabilize the pressure.
I do not need input on true vs. indicated airspeed. But I would
welcome input from others who have looked at such instrument leakages
as well.
Regards,
Thomas
Old June 30th 09, 09:30 PM posted to rec.aviation.soaring
John Ferguson
Cambridge equipment leaks air from the pitot line as it uses a flow
arrangement rather than a pressure sensor. Worried me as well till I
worked it out.
Some glider makers insist on a separate pitot arrangement for such varios
in order that the asi does not under read. An LS7 I used to have have a
three way probe and a standard pitot installed for this reason.
New technologies flight computer Ed Gaddy[_2_] Soaring 0 July 14th 08 04:41 PM
Antique Flight Computer James Hamilton Soaring 0 January 5th 06 07:04 PM
Antique Flight Computer James Hamilton Soaring 0 January 5th 06 07:03 PM
Fuel leakage during in-flight refueling mark johnston Naval Aviation 15 March 30th 05 06:22 AM
Zander 820 Flight COmputer Dave Kuchenbecker Soaring 0 May 7th 04 03:27 AM
