On Wednesday, March 25, 2015 at 10:50:30 AM UTC-4, Sarah wrote:
Timely thread, gearing up for northern hemisphere spring. I've towed with a Honda Accord ( V6 manual ). It's relatively heavy at 3400 lb, plenty of power and tows my old Komet ( around 2000 lb ) stably up to 70 mph. I've only been nervous once - coming down I70 into Denver with a steep downgrade. Slowed way down and it was OK. The trailer surge brake has been inop for years -Any one have suggestions on where I could take it for overhaul or replacement with electric brakes? Local garage? Or, is even necessary? I really should check for trailer tongue corrosion and double check the hitch mount points. On Tuesday, March 24, 2015 at 11:04:01 AM UTC-5, wrote: Hi All, .. What is the typical range o gross weights of a single seat glider plus trailer? Recommendations on a good tow vehicles? Thanks for your help Bill Google "Adjusting the wheel brakes of your Cobra trailer" and you get a pdf with lots of pictures on adjustment of the alko running gear: http://www.cobratrailer.com/Bremsein...englisch_1.pdf Dan |
On Wednesday, March 25, 2015 at 8:20:50 AM UTC-7, Dan Daly wrote:
On Wednesday, March 25, 2015 at 10:50:30 AM UTC-4, Sarah wrote: Timely thread, gearing up for northern hemisphere spring. I've towed with a Honda Accord ( V6 manual ). It's relatively heavy at 3400 lb, plenty of power and tows my old Komet ( around 2000 lb ) stably up to 70 mph. I've only been nervous once - coming down I70 into Denver with a steep downgrade. Slowed way down and it was OK. The trailer surge brake has been inop for years -Any one have suggestions on where I could take it for overhaul or replacement with electric brakes? Local garage? Or, is even necessary? I really should check for trailer tongue corrosion and double check the hitch mount points. On Tuesday, March 24, 2015 at 11:04:01 AM UTC-5, wrote: Hi All, .. What is the typical range o gross weights of a single seat glider plus trailer? Recommendations on a good tow vehicles? Thanks for your help Bill Google "Adjusting the wheel brakes of your Cobra trailer" and you get a pdf with lots of pictures on adjustment of the alko running gear: http://www.cobratrailer.com/Bremsein...englisch_1.pdf Dan Link is inop (404 not found) |
On Wednesday, March 25, 2015 at 2:30:45 PM UTC-4, SoaringXCellence wrote:
On Wednesday, March 25, 2015 at 8:20:50 AM UTC-7, Dan Daly wrote: On Wednesday, March 25, 2015 at 10:50:30 AM UTC-4, Sarah wrote: Timely thread, gearing up for northern hemisphere spring. I've towed with a Honda Accord ( V6 manual ). It's relatively heavy at 3400 lb, plenty of power and tows my old Komet ( around 2000 lb ) stably up to 70 mph. I've only been nervous once - coming down I70 into Denver with a steep downgrade. Slowed way down and it was OK. The trailer surge brake has been inop for years -Any one have suggestions on where I could take it for overhaul or replacement with electric brakes? Local garage? Or, is even necessary? I really should check for trailer tongue corrosion and double check the hitch mount points. On Tuesday, March 24, 2015 at 11:04:01 AM UTC-5, wrote: Hi All, .. What is the typical range o gross weights of a single seat glider plus trailer? Recommendations on a good tow vehicles? Thanks for your help Bill Google "Adjusting the wheel brakes of your Cobra trailer" and you get a pdf with lots of pictures on adjustment of the alko running gear: http://www.cobratrailer.com/Bremsein...englisch_1.pdf Dan Link is inop (404 not found) I found it pretty easily from the website. Look under the "Manuals" tab. |
Sarah wrote:
Timely thread, gearing up for northern hemisphere spring. I've towed with a Honda Accord ( V6 manual ). It's relatively heavy at 3400 lb, plenty of power and tows my old Komet ( around 2000 lb ) stably up to 70 mph. I've only been nervous once - coming down I70 into Denver with a steep downgrade. Slowed way down and it was OK. The trailer surge brake has been inop for years -Any one have suggestions on where I could take it for overhaul or replacement with electric brakes? Local garage? Or, is even necessary? I really should check for trailer tongue corrosion and double check the hitch mount points. On Tuesday, March 24, 2015 at 11:04:01 AM UTC-5, wrote: Hi All, .. What is the typical range o gross weights of a single seat glider plus trailer? Recommendations on a good tow vehicles? Thanks for your help Bill YES you want working surge brakes. I have a good working setup on my tube trailer for my Libelle. I tow with a Mazda protege5 wagon (4 cylinder manual), and having the surge brakes makes a real difference. Stability is good. Had it up to 80 once while not paying attention. You can tow with a small car just have a good trailer with brakes. The German tow ratings usually are cut in half for trailers without brakes. Peter |
Hi Bill,
Once you have narrowed down your search, look at the towing capacities of the vehicles. Some will even say (ie. Honda Civic), "not recommended for towing". I am on the bubble with mine in respect to towing (2.5l Outback) but with the bigger engine, I could tow more (bigger brakes?) and with trailer brakes, I could tow more. Anything can tow going down the highway at 60-70 mph but not anything can stop/slow down in time. mas |
The CVT is an awesome transmission for towing. My Nissan Murano has a CVT, great stability and very short rear axle to hitch distance. The CVT smooths out the power delivery to the wheels. There is no jerking going up hills like when the automatic transmissions downshift. Just a slow and steady increase in RPM. A great towing vehicle.
Unfortunately, for the new 2015 model, Nissan has reduced the rated towing capacity to 1500 lb. I guess I won't be buying another one. Anyone at Nissan listening? I won't be buying another one unless you fix that! My wife has a Subaru XV and it is rated for 1500 lb and we found that an ASW-27 in a Cobra trailer was getting to the limit for the XV. Probably fine for short retrieves on back roads at 40-50 mph, but not out on the highway at 60-70. |
On Thursday, March 26, 2015 at 12:33:12 PM UTC+13, Dave Springford wrote:
My wife has a Subaru XV and it is rated for 1500 lb and we found that an ASW-27 in a Cobra trailer was getting to the limit for the XV. Probably fine for short retrieves on back roads at 40-50 mph, but not out on the highway at 60-70. According to Subaru Australia, the XV is tow rated for 1400 kg, not lb. http://www.subaru.com.au/car-advice/...owing-capacity |
From Canadian Subaru Website:
http://www.subaru.ca/WebPage.aspx?We...ModelYear=2015 Measurements: Towing Capacity Maximum weight (kg) with trailer brakes (Review Owner's Manual for details)680 Very strange how the same car has different ratings on different continents. |
I think you'll find the different in ratings is a function of different test requirements in each country. My understanding is that in some countries (can't remember which) it is simply how heavy a trailer you can pull from a stationary start on a specific gradient.
As such it really doesn't tell you much at all about how it tows. Best place for information on this stuff is the caravan sites. It's not like most glider trailers are very heavy. |
Favorite tow car: Saab 900T
Current tow car: Hyundai Tucson - 2010, front wheel drive, 6 speed manual, 1000 lb tow capacity with out trailer brakes, 2000 lb tow capacity with trailer brakes Great around town car. Would be excellent, if not for rearward visibility issues. 26-27 mpg freeway at normal speeds (around 75 mph). 22-23 mpg towing the trailer. Adequate tow car. Normally tow Avionic/SZD 55-1 combo with an all up weight of 1700 lbs. (Yes, I did weigh it.) Have also towed Jantar Junior/Gehrline, 2-33/open trailer, 1-26/open trailer and single seat Grob/tube type trailer. Have towed to Montague, Ephrata, AirSailing, Logan, and Nephi. Have towed logging roads and freeway up to (shhhh! don't tell anyone) 90 mph. Front wheel slippage can be a problem towing up steep dirt roads in the rain. Recommend all wheel drive if you land off field a lot. P9 |
| Thread Tools | |
| Display Modes | |
| Uvalde Worlds 2012 - trailer + truck help | Tim[_2_] | Soaring | 0 | October 24th 11 05:13 PM |
| Moving a glider with a U-Haul Truck | [email protected] | Soaring | 11 | February 10th 09 09:48 PM |
| Hauling a trailer by rail or car-carrier truck | GM | Soaring | 11 | April 18th 08 10:46 PM |
| truck + 5th wheel RV + glider trailer ?? | Steve Koerner | Soaring | 16 | March 27th 07 04:44 AM |
| Glider pull-up and ballast | M B | Soaring | 0 | September 15th 03 07:29 PM |
