Does this exist-- program to generate speed-to-fly table?
Old June 12th 15, 04:03 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Does this exist-- program to generate speed-to-fly table?
On Thursday, June 11, 2015 at 7:55:56 PM UTC-5, wrote:
* The "card" is in the form of a half-ring. It looks exactly like half a MacCready ring. It is taped around the lower half of the vario (sink portion only). To tell the best speed-to-fly through sink. It doesn't deal with what to do in lift. Think of it as MacCready ring set to zero, but with three added bands of numbers to deal with 10 mph 20mph and 30 mph headwinds, not just zero-wind conditions.
* I've also done this using a printed card that was separate from the vario but the ring mounted around the vario is much much easier to use.
* Yes absolutely there is some "chasing" involved. I mean, not chasing the airspeed up and down, but when you hit sink, you'll go through a gradual acceleration before the vario needle is finally pointing right at the airspeed number you are actually flying, and that's when you stop accelerating. You can't instantly know what speed you'll need to accelerate to, like you would if you were using netto. But this is nothing new, there's a long long history of pilots using MacCready speed-to-fly rings on non-netto variometers.
* If I were using a netto variometer it would be very easy to create the ring using a graphical printout of the polar curve, and a ruler. It would only take 10 minutes or 30 minutes at most to get data for a wide spread of sink rate points and 3 different wind conditions. It's using a non-netto vario, that makes the numbers more of a pain to come up with, especially if you to produce the appopriate airspeed to fly for nice ROUND numbers on the vario (100 fpm, 200 fpm, etc). If you are happy with a scattershot collection of numbers for the vario values on the ring, rather than round numbers, it's a little easier to make the ring, but a little less nice to use.
S
So, I guess the choice is yours. Quick, and "scattershot" numbers and be able to use it this weekend, or wait until you can resurrect the program and make it the way you like. If I were making one of these, I would color code, and put zero wind closest in, then 10 and 20 MPH headwinds and to heck with trying to put the speeds on a nice, round sink rate.
Steve Leonard
Old June 12th 15, 04:24 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
On Thursday, June 11, 2015 at 5:55:56 PM UTC-7, wrote:
On Thursday, June 11, 2015 at 7:01:22 AM UTC-7, Andy Blackburn wrote:
On Wednesday, June 10, 2015 at 12:49:41 PM UTC-7, Steve Leonard wrote:
On Wednesday, June 10, 2015 at 1:43:44 PM UTC-5, wrote:
Sink or headwind is exactly what I want to take into account, that's the whole point! Was I unclear on the original post?
As a matter of fact, your initial post was not clear. You said you wanted to know the best speed to fly for a variometer reading of 200 feet per minute down (not netto). Well, what is the air doing then? You could be flying 60 knots or 120 knots to get a variometer showing 200 feet per minute down (not netto), depending on what the air is doing. Or, you may not ever be able to get the variometer to show that little down. If the word "Not" slipped in there unexpectedly, your question becomes more clear. And that is what I assumed you meant.
No real need for a computer program to make this table. And I would make a simple table. It is not a ring you place around a variometer. You have the polar, you know the theory, you drew the lines, why not just type up the table?
Best L/D, no wind, for air going down 100 feet per minute is the line from the zero horizontal speed, 100 foot per minute vertical speed (on the opposite side from your polar), tangent to the polar. You can see the speed you should fly (tangent point), and the L/D you will make good (basically, horizontal speed divided by vertical speed). Headwinds move the origin point of your line towards your polar, tailwinds move the origin point away from your polar. For L/D with headwind or tailwind, you have to subtract or add, respectively, wind speed from or to flight speed to get ground speed to calculate L/D.
Can I ask why you want to make a program to create something you can create in less than 10 minutes, including time to type it up? The program won't likely save you much time in making the chart for a second, third, or fourth plane, as you still have to find the polar, pull data from it, enter it into the program, see that the polar it draws sort of matches what you see from your data source, and then trust the results. And if you make a ring, what happens when you go to a glider with a different number of degrees between each 100 ft/min increment in lift or sink?
My advice would be to make a simple table, not a ring. Put it on card stock and encase it in plastic (waterproof it). Tape it to the panel when you fly.
Just my 2 cents worth. BTW, I could have made a couple of those tables in the time I have spent typing this. :-)
Steve Leonard
Steve,
I thought I knew where you were going and then you lost me.
To make the card you have to use the polar - or more easily a quadratic curve fit if you want to just do it by simple math instead of reading a graph. But since the stronger the airman sink rate the faster you need to fly and the faster you fly the more rapidly the glider sinks through the air you need to add these effects together to get the speed for a given vary reading. This has always been the somewhat maddening thing about speed rings. You see the vario needle pointing at -2 kts and the speed the ring says 75 kts, so you push over to 75 kts and the needle moves up to -3 kts and a speed of 80 its - then the sink changes and you are chasing the vario needle versus the airspeed needle again. It is possible to print this out on a card, but I don't know how useful it will be since you only have the glider rate of sink, not net as you point out. I can't imagine trying to do this looking at the vario, the airspeed and a printed card, trying to line all three up.
Andy--
S
Yes, the trick is getting the speed for even-knot sink indications on an uncompensated vario. I have a spreadsheet that I can probably modify to make a brut force table for any glider for which you have three velocity vs sink rate pairs (to make a quadratic polar curve fit) that you can then use to build a ring for 1 knot increments. Send me a PM with an email address.
9B
Old June 12th 15, 02:49 PM posted to rec.aviation.soaring
When I had the old computer program running, I did have a function that showed how much faster or slower you could fly and have your performance only reduced by X percent. As you might imagine, it was a lot more critical to hit the right numbers if you were going for best cross-country speed, than simply going for flattest glide through sink and /or headwind for non-racing recreational flying. In the latter case you could be at least 5 mph slow without losing much. I really need to get that program running again one of these days. S
On Thursday, June 11, 2015 at 8:54:26 AM UTC-7, Bob Pasker wrote:
what is just as interesting is what happens when the answer is off by some amount.
for example, how badly would the flight be affected by -10, -5, +5, and +10 knots/mph/kph off the optimal speed to fly?
--bob
Old June 13th 15, 05:25 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
On Friday, June 12, 2015 at 6:49:47 AM UTC-7, wrote:
Okay, I got out my dog-eared copy of "Cross Country Soaring" and pulled the right formula out of the math section. Here is a spreadsheet that takes three points off of a polar of your choosing, adjusts it for actual takeoff weight versus the weight the polar was measured at and creates a quadratic formula for the polar. It then calculates the locations on a speed ring for any given speed to fly. If you assume Mc=0 it will give you speed for best L/D, but it also works if you want to make a ring that rotates for different Mc values.
It does the calculation for zero wind and for a wind velocity you can input.. Everything is in knots and pounds. Headwinds are negative numbers. Inputs are in red and a graph of the polar is produced for the weight used to create the polar, for the actual takeoff weight as well as for the designated wind condition at actual takeoff weight. It's in 1-knot STF increments, so you can either place even speed increments around the ring at irregular intervals or put irregular increments of STF at even increments around the ring, whatever is easier for you to use in the cockpit.
Here's a link to download the Excel file:
https://drive.google.com/folderview?...ms&usp=sharing
Building this was an interesting review of some basic cross-country soaring principles. It reminded me that I should never, ever fly best L/D if I can avoid it when racing. The speed penalty huge and the benefit is marginal.
9B
Old June 13th 15, 05:32 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
It does the calculation for zero wind and for a wind velocity you can input. Everything is in knots and pounds. Headwinds are negative numbers. Inputs are in red and a graph of the polar is produced for the weight used to create the polar, for the actual takeoff weight as well as for the designated wind condition at actual takeoff weight. It's in 1-knot STF increments, so you can either place even speed increments around the ring at irregular intervals or put irregular increments of STF at even increments around the ring, whatever is easier for you to use in the cockpit.
Building this was an interesting review of some basic cross-country soaring principles. It reminded me that I should never, ever fly best L/D if I can avoid it when racing. The speed penalty huge and the benefit is marginal..
9B
Also - the polar pre-loaded in the spreadsheet is for an ASW-27. You need to provide the polar for the glider you are flying - preferably a polar where you know the takeoff weight and the takeoff weight for the glider you are flying as it makes a bit of a difference.
9B
GE proposes to use artificial sink to generate 500 MW of power inSouthern AZ son_of_flubber Soaring 22 March 28th 14 11:56 PM
Can gliders and powered aircraft co-exist using the same runway? Ron Lee Soaring 17 January 31st 07 08:42 PM
Can gliders and powered aircraft co-exist on the same runway? Ron Lee Piloting 18 January 18th 07 02:36 AM
An animal so rare it may not exist . . . [email protected] Home Built 11 December 7th 06 06:46 PM
Does the elevator/stabilator generate upward force? Dan Piloting 20 December 6th 06 04:19 PM
