Does this exist-- program to generate speed-to-fly table?
Old June 10th 15, 02:40 AM posted to rec.aviation.soaring
Default Does this exist-- program to generate speed-to-fly table?
Here's what I want to do:
Input a minimum-sink-rate data point plus one or two other data points to establish a polar curve for a particular glider.
Have a computer program spit out a table showing the best airspeed to fly for variometer readings (not netto) of 200 fpm down, 300 fpm down, 400 fpm down, etc up to 1500 fpm down, for 0 mph headwind, 10 mph headwind, 20 mph headwind, and 30 mph headwind.
I only want to consider the best glide over the ground, not the best cross-country speed. I.e. a MacCready ring setting of zero.
This is to make a handy paper MacCready ring thing (but not moveable, and only a half a circle not a full circle) to tape around the vario of rented, borrowed, or club gliders. The arc will have three sets of numbers around it, corresponding to the 0 mph headwind, 10 mph headwind, 20 mph headwind, and 30 mph headwind cases.
Does such a program exist?
One speed-to-fly-explanation website says that "A really desperate pilot should set the ring to zero to maximize the area to be searched for a thermal.. ", so I guess I am a really desperate pilot, to be requesting such a thing...
S
Old June 10th 15, 05:06 AM posted to rec.aviation.soaring
SoaringXCellence
I don't know of such a program, but you might want to rethink your approach. It doesn't take into account areas of sink or the effects of a headwind.
I suggest you read Reichmann (or maybe it was Cochrane) for his discussion on why 0 MacReady is never the right value unless the air is void of all motion.
Old June 10th 15, 07:43 PM posted to rec.aviation.soaring
Sink or headwind is exactly what I want to take into account, that's the whole point! Was I unclear on the original post?
If you are trying to race along at an optimal cross-county speed then there's room for all kinds of nuanced discussions around how the basic MacCready theory falls short but if you are just trying to make the flattest possible glide toward the next thermal, given the existing sink and headwind, I don't think there is much rocket science to it is there? Draw the tangent line tothe polar curve, starting at the appropriate point to take into account sink and headwind.
But sure I'd be interested to read anything for more illumination, can you give titles as well as authors?
Anyway, I wrote a program to do exactly this years ago (and it also spit out the corresponding values for non-zero MacCready settings) but I don't have access to it now... someday I will resurrect it but it might be many months before I can tackle that.
S
Old June 10th 15, 08:49 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
As a matter of fact, your initial post was not clear. You said you wanted to know the best speed to fly for a variometer reading of 200 feet per minute down (not netto). Well, what is the air doing then? You could be flying 60 knots or 120 knots to get a variometer showing 200 feet per minute down (not netto), depending on what the air is doing. Or, you may not ever be able to get the variometer to show that little down. If the word "Not" slipped in there unexpectedly, your question becomes more clear. And that is what I assumed you meant.
No real need for a computer program to make this table. And I would make a simple table. It is not a ring you place around a variometer. You have the polar, you know the theory, you drew the lines, why not just type up the table?
Best L/D, no wind, for air going down 100 feet per minute is the line from the zero horizontal speed, 100 foot per minute vertical speed (on the opposite side from your polar), tangent to the polar. You can see the speed you should fly (tangent point), and the L/D you will make good (basically, horizontal speed divided by vertical speed). Headwinds move the origin point of your line towards your polar, tailwinds move the origin point away from your polar. For L/D with headwind or tailwind, you have to subtract or add, respectively, wind speed from or to flight speed to get ground speed to calculate L/D.
Can I ask why you want to make a program to create something you can create in less than 10 minutes, including time to type it up? The program won't likely save you much time in making the chart for a second, third, or fourth plane, as you still have to find the polar, pull data from it, enter it into the program, see that the polar it draws sort of matches what you see from your data source, and then trust the results. And if you make a ring, what happens when you go to a glider with a different number of degrees between each 100 ft/min increment in lift or sink?
My advice would be to make a simple table, not a ring. Put it on card stock and encase it in plastic (waterproof it). Tape it to the panel when you fly.
Just my 2 cents worth. BTW, I could have made a couple of those tables in the time I have spent typing this. :-)
Steve Leonard
Old June 11th 15, 03:01 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Steve Leonard
Steve,
I thought I knew where you were going and then you lost me.
To make the card you have to use the polar - or more easily a quadratic curve fit if you want to just do it by simple math instead of reading a graph. But since the stronger the airman sink rate the faster you need to fly and the faster you fly the more rapidly the glider sinks through the air you need to add these effects together to get the speed for a given vary reading.. This has always been the somewhat maddening thing about speed rings. You see the vario needle pointing at -2 kts and the speed the ring says 75 kts, so you push over to 75 kts and the needle moves up to -3 kts and a speed of 80 its - then the sink changes and you are chasing the vario needle versus the airspeed needle again. It is possible to print this out on a card, but I don't know how useful it will be since you only have the glider rate of sink, not net as you point out. I can't imagine trying to do this looking at the vario, the airspeed and a printed card, trying to line all three up.
Old June 11th 15, 03:04 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
On Thursday, June 11, 2015 at 7:01:22 AM UTC-7, Andy Blackburn wrote:
I need to figure out how to turn off autocorrect when on RAS - corrections in CAPS below:
To make the card you have to use the polar - or more easily a quadratic curve fit if you want to just do it by simple math instead of reading a graph. But since the stronger the airmaSS sink rate the faster you need to fly and the faster you fly the more rapidly the glider sinks through the air you need to add these effects together to get the speed for a given varIO reading. This has always been the somewhat maddening thing about speed rings. You see the vario needle pointing at -2 kts and the speed the ring says 75 kts, so you push over to 75 kts and the needle moves up to -3 kts and a speed of 80 Kts - then the sink changes and you are chasing the vario needle versus the airspeed needle again. It is possible to print this out on a card, but I don't know how useful it will be since you only have the glider rate of sink, not netTO as you point out. I can't imagine trying to do this looking at the vario, the airspeed and a printed card, trying to line all three up.
9B
Old June 12th 15, 01:55 AM posted to rec.aviation.soaring
Steve Leonard
Steve,
To make the card you have to use the polar - or more easily a quadratic curve fit if you want to just do it by simple math instead of reading a graph. But since the stronger the airman sink rate the faster you need to fly and the faster you fly the more rapidly the glider sinks through the air you need to add these effects together to get the speed for a given vary reading. This has always been the somewhat maddening thing about speed rings. You see the vario needle pointing at -2 kts and the speed the ring says 75 kts, so you push over to 75 kts and the needle moves up to -3 kts and a speed of 80 its - then the sink changes and you are chasing the vario needle versus the airspeed needle again. It is possible to print this out on a card, but I don't know how useful it will be since you only have the glider rate of sink, not net as you point out. I can't imagine trying to do this looking at the vario, the airspeed and a printed card, trying to line all three up.
Andy--
* The "card" is in the form of a half-ring. It looks exactly like half a MacCready ring. It is taped around the lower half of the vario (sink portion only). To tell the best speed-to-fly through sink. It doesn't deal with what to do in lift. Think of it as MacCready ring set to zero, but with three added bands of numbers to deal with 10 mph 20mph and 30 mph headwinds, not just zero-wind conditions.
* I've also done this using a printed card that was separate from the vario but the ring mounted around the vario is much much easier to use.
* Yes absolutely there is some "chasing" involved. I mean, not chasing the airspeed up and down, but when you hit sink, you'll go through a gradual acceleration before the vario needle is finally pointing right at the airspeed number you are actually flying, and that's when you stop accelerating. You can't instantly know what speed you'll need to accelerate to, like you would if you were using netto. But this is nothing new, there's a long long history of pilots using MacCready speed-to-fly rings on non-netto variometers.
* If I were using a netto variometer it would be very easy to create the ring using a graphical printout of the polar curve, and a ruler. It would only take 10 minutes or 30 minutes at most to get data for a wide spread of sink rate points and 3 different wind conditions. It's using a non-netto vario, that makes the numbers more of a pain to come up with, especially if you to produce the appopriate airspeed to fly for nice ROUND numbers on the vario (100 fpm, 200 fpm, etc). If you are happy with a scattershot collection of numbers for the vario values on the ring, rather than round numbers, it's a little easier to make the ring, but a little less nice to use.
S
Old June 10th 15, 06:04 AM posted to rec.aviation.soaring
Tim Taylor
I have an excel spreadsheet that does what you want. Mine gives a table of speed to fly at three different wing loadings. I can send you the excel file but it was not designed for others to use. Alternately you can send me info about your glider and I can set it up for you and send it back.
Tim
Old June 10th 15, 02:49 PM posted to rec.aviation.soaring
Dan Marotta
If you use XCSoar, it provides a Speed to Fly info box.
Tim
Dan Marotta
Old June 10th 15, 05:07 PM posted to rec.aviation.soaring
SF
The Speed to fly functionality of the ClearNav vario works pretty well for giving you a speed to fly number based on the current conditions. I don't constantly chase the number it displays, but it is a good number to work off of.
SF
GE proposes to use artificial sink to generate 500 MW of power inSouthern AZ son_of_flubber Soaring 22 March 28th 14 11:56 PM
Can gliders and powered aircraft co-exist using the same runway? Ron Lee Soaring 17 January 31st 07 08:42 PM
Can gliders and powered aircraft co-exist on the same runway? Ron Lee Piloting 18 January 18th 07 02:36 AM
An animal so rare it may not exist . . . [email protected] Home Built 11 December 7th 06 06:46 PM
Does the elevator/stabilator generate upward force? Dan Piloting 20 December 6th 06 04:19 PM
