Final Glides: GPS or Pressure Altitude?
Old July 6th 16, 06:20 PM posted to rec.aviation.soaring
Default Final Glides: GPS or Pressure Altitude?
Ignoring airspace and start/finish gate implications, which is better for managing final glides: GPS or pressure altitude?
At the Nephi Nationals, I was using a Dell Streak 5 running Top Hat glide computer software. I'd built a wiring harness for my PowerFLARM to successfully input traffic and pressure altitude date to a Kobo Mini but I couldn't get the Dell to work using the same set up. So all of the Dell's final glide info was based on GPS altitude.
GPS altitude at this contest differed dramatically from pressure altitude, from negligible at field elevation (5,000 ft.) to 1,000+ ft. at the top of our operating band (over 17,000 ft.). This was new to me. I just hadn't seen much difference between the two in my flying back east.
I assumed that forces on the glider airfoil were more likely based on density altitude, so I used my old Cambridge GPS/NAV driving GNII/Compaq 1550 for glide path control, since the Dell was telling me I had 1,000 ft. more altitude to play with when starting a long final glide.
The difference was also a factor at the start, where I had to configure the Dell with a 700 ft. higher start gate ceiling than the specified 12,000 MSL limit in order to get reasonably accurate automatic climb-thru-the-top starts.
Now that I've done some reading, I'm not so sure I should have ignored the Dell's GPS-based glide path recommendations, however. I've found several recommendations from knowledgeable authorities that GPS altitude is better for managing final glides. Obviously the GPS altitude is more accurate in an absolute sense, but my question relates to performance gliding through a non-standard atmosphere. Of course, I'm ignoring the IAS/TAS issues in all of this.
Comments?
Chip Bearden
ASW 24 "JB"
Pressure Altitude in Loggers ContestID67 Soaring 2 June 12th 07 02:41 AM
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Pressure Altitude or Density Altitude john smith Piloting 3 July 22nd 04 10:48 AM
Cabin Pressure Altitude Greg Esres Piloting 4 March 24th 04 08:35 PM
Greatest Altitude without pressure cabin/suit W. D. Allen Sr. Military Aviation 12 July 26th 03 04:42 PM
