#21
Definitely a troll.
Vaughn wrote:
That said, a slip/skid indicator costs a whole $45.00 at Wings& Wheels and there is no reason for any trainer to be without one. I wonder if one can get an experimental version at Orchard Supply for $2.35... :P |
In article
, "Vaughn" wrote: I should tell my early-solo students that a missing or stuck yaw string is sufficient reason for them to make a non-standard pattern, make deliberately uncoordinated and little-practiced turns near the ground, and give up the advantage of a correctly functioning IAS? I don't think so! I once hired an ASK-21 (the one at Turf that crashed recently :-( ), and on two flights I found after takeoff that the yaw string had got caught by the front canopy and was inoperative. It was unnerving at first, but didn't seem to make any difference to being able to soar sucessfully. -- Bruce |
"Mark James Boyd" wrote in message news:40252ec1@darkstar... Vaughn wrote: That said, a slip/skid indicator costs a whole $45.00 at Wings& Wheels and there is no reason for any trainer to be without one. I wonder if one can get an experimental version at Orchard Supply for $2.35... I have seen bubble levels used, they work in the opposite direction from a slip/skid (same as the yaw string), are excessively sensitive, but the one I flew with seemed to agree with the yaw string. Vaughn :P |
Vaughn wrote: "Mark James Boyd" wrote in message news:40252ec1@darkstar... Vaughn wrote: That said, a slip/skid indicator costs a whole $45.00 at Wings& Wheels and there is no reason for any trainer to be without one. I wonder if one can get an experimental version at Orchard Supply for $2.35... I have seen bubble levels used, they work in the opposite direction from a slip/skid (same as the yaw string), are excessively sensitive, but the one I flew with seemed to agree with the yaw string. Vaughn www.aircraft-spruce.com $34. but the real long, sensitive ones at store.wagaero.com look about in this price range too, and a selection of 5... |
"Mark James Boyd" wrote in message news:4025866c$1@darkstar... www.aircraft-spruce.com $34. http://www.aircraftspruce.com/ntoc.p...slipindicators $24.50 |
Vaughn wrote: "Mark James Boyd" wrote in message news:4025866c$1@darkstar... www.aircraft-spruce.com $34. http://www.aircraftspruce.com/ntoc.p...slipindicators $24.50 Somewhere in these there is a 6" long indicator with 10 degrees incremented on either side! This sooms like pretty good resolution! Experts only, of course, since for a poor new student, this might really be a confidence breaker (jus' can't get that thing the last 1/6th of a degree on) :P |
"Mark James Boyd" wrote in message news:40265cde$1@darkstar... In article , Vaughn wrote: "Mark James Boyd" wrote in message news:4025866c$1@darkstar... www.aircraft-spruce.com $34. http://www.aircraftspruce.com/ntoc.p...slipindicators $24.50 Somewhere in these there is a 6" long indicator with 10 degrees incremented on either side! This sooms like pretty good resolution! Experts only, of course, since for a poor new student, this might really be a confidence breaker (jus' can't get that thing the last 1/6th of a degree on) :P I have a 6" ball indicator and tried it in a glider. The result was that the ball stayed perfectly in the center while the yaw string was all over the place. Clearly, it's not sensitive enough. Bill Daniels |
#29
Chris OCallaghan wrote:
Mixed feelings about slips... can be very useful, but most instances of need can be attended to before needed, as others in the thread have pointed out. Frozen airbrakes are one of these. If you intend to fly at altitude, or anytime the temperature is below freezing, a layer of vaseline between the mating surfaces will tyically prevent them freezing together. The only time I had the spoilers freeze shut was when a light shower came through just as I was preparing to tow. We waited until it passed, then towed off. It turned into a wave flight, freezing the brakes shut, which I discovered during the descent. They released in the warmer air at about 4000' agl, so no problem. Has anyone had the spoilers freeze shut without having rain first, and without flying in cloud? -- ----- change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#30
My instructor had me do this the last time I was up. Actually, he told me to hold the aircraft (2-33) high in the pattern so that I was at "800-1000' abeam of the numbers", then set it down, he didn't say how...that was the excercise for the student(me). There was a slight crosswind and a bit more (landing)headwind as well. 3-5kts by 5-10kts at ground level. It was an *interesting* ride. I went to full slip, full spoilers and extended the downwind leg a bit, then 1/2 spoilers and less rudder to let the slip turn to base (didn't know how much altitude I'd lose in the turn), held slip and spoilers on base, 1/2 spoilers and less rudder to slip turn to final. The crosswind was opposite the slip (left pattern, right to left x-wind on final) so closed spoilers and converted from left slip to right slip (that was the *interesting* part...never did that in a pattern before...can't let the track wander) and laid on full spoilers, did a normal slip to landing...yes I reduce spoilers on final just before flare...the 2-33 is a barge and flares like one too. An indestructable barge, but a barge nonetheless. AT "ISoar" wrote in message ... I can't find anything in my books about how to make a 90 degree turn (e.g., downwind to base) while in a full slip, but maybe that's because it's so obvious. (Given my limited # hours, just because something seems obvious to me doesn't mean I'm not going to check it out.) I figure I'll turn with roll input, but can't picture the side effects from doing that. If I know the side effects I can have a chance of being ahead of the plane during the maneuver. Anyway, is there going to be any adverse yaw from turning in this mode? Even if there is, I don't think I can do anything about it, but enquiring minds want to know. The other question is if the attitude going to change as a side effect of the roll input. This will be in a 2-33. Thanks |
| Thread Tools | |
| Display Modes | |
| Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 06:14 AM |
| "Proceed on Course" = "Right turn approved"? | Bob Chilcoat | Piloting | 41 | July 19th 04 12:48 AM |
| Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 04:27 AM |
| Rate of turn indicator on commercial jets (Boeing / Airbus) | Mark | Simulators | 1 | November 1st 03 11:35 AM |
| IFR in the 1930's | Rich S. | Home Built | 43 | September 21st 03 02:03 AM |
