#21
and a fire extinguisher...
-- Dan D. http://www.ameritech.net/users/ddevillers/start.html .. "B2431" wrote in message ... From: Richard Lamb Date: 7/1/2004 10:53 AM Central Daylight Time Message-id: GreenPilot wrote: All great pointers. I appreciate everyone's suggestions. Now...to the shop! One more - something I wish I had - a sink. Great for washing the gashes on your hands from checking that part you thought you had just deburred. This brings me to something important: have a first aid kit with extra bandages handy. Dan, U.S. Air Force, retired |
I call them horizontal clutter magnets
-- Dan D. http://www.ameritech.net/users/ddevillers/start.html .. "John Kunkel" wrote in message news:erXEc.8052$XM6.6112@attbi_s53... "GreenPilot" wrote in message om... I have a 20'x20' shop that I am remodeling and am seeking suggestions for an optimum layout for building. Currently it is wired basically, and I know I (read electrician) will adding a plurality of shop lights and higher voltage outlets. Other than that, what else should I consider? Should I just build a big workbench down one side, put tools on another, put a compressor outside, and leave the floor space for building? I'm of the opinion than any vacant horizontal surface will eventually become "storage". I prefer a smaller workbench surface with the additional footage devoted to verticle storage. |
I built three of the EAA 1000 tables. I made them just a bit wider for my
Hatz airframe. They are very functional and moving them into different configurations works great for doing tailfeather, gear, torque tube etc.. The lower shelf is a must as it stabilizes the table and provides great storage. If I recall they worked out to about $60 apiece and I had a lot of 3/4" plywood left over for other things. That was 2 years ago. -- John "Ebby" Ebensperger Hatz Classic s/n 37 Camden, NY |
From: "Blueskies" Date: 7/1/2004 6:59 PM Central Daylight Time Message-id: and a fire extinguisher... -- Dan D. http://www.ameritech.net/users/ddevillers/start.html Great for throwing at the "friend" who asks "do ya really expect that thing to fly?" Dan, U.S. Air Force, retired or for using as a power source - look out Spaceship One!?!? -- Dan D. http://www.ameritech.net/users/ddevillers/start.html .. |
Shelly wrote ...
GreenPilot wrote: I have a 20'x20' shop I'm sure you realize that isn't much room when it comes time to assemble the project - wings and empennage to fuselage? What are you going to build? Folks build airplanes in attics, dining rooms and basements. Either foldable/removable wings or final assembly at the plane's new home will do the trick. Daniel |
On Thu, 01 Jul 2004 01:17:00 GMT, "Cy Galley"
wrote: I would protect yourself with ground fault interrupters. One GCF can protect several outlets. I think the NEC now requires them. Making the first outlet a GFI can eliminate the need for a GFI circuit breaker back at the panel and is one whale of a lot cheaper. I used surface mount thin wall conduit with a GFI outlet on each circuit. I have 6 circuits just for 110 VAC outlets and three for 220. The circuits for the outlets are arranged so if a breaker pops you can pull the plug and still have power in the outlet beside it. I saw a guy trip one with his fingers. Said he didn't feel it, but I think I'll pass on that test myself. :-)) If you have any fuel burning heaters, get a CO detector. I use one powered off the AC instead of straight batter power. Only one in the shop but three in the house. I decided to keep the compressor in the shop where it's warm with a blow down line running outside. I need to plant some barberry bushes around the outlet so no one will walk up in front of it although it is pretty well protected...but junk. Eventually I plan on building a sound proofed enclosure around the compressor. Galvanized pipe for air lines around the inside of the shop instead of having to pull a hose around. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() "Roger Halstead" wrote Eventually I plan on building a sound proofed enclosure around the compressor. Galvanized pipe for air lines around the inside of the shop instead of having to pull a hose around. Roger Halstead Not galvanized pipe. It is illegal to use as gas pipe, cause the plate can flake off, and plug stuff up. It could be bad for your power tools. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.711 / Virus Database: 467 - Release Date: 6/26/2004 |
#29
![]() "Richard Riley" wrote in message ... On Sat, 3 Jul 2004 00:46:48 -0400, "Morgans" wrote: : :"Roger Halstead" wrote : : : Eventually I plan on building a sound proofed enclosure around the : compressor. Galvanized pipe for air lines around the inside of the : shop instead of having to pull a hose around. : : Roger Halstead Not galvanized pipe. It is illegal to use as gas pipe, :cause the plate can flake off, and plug stuff up. It could be bad for your ![]() So what's legal? Last year I spent a day running galvi parallel to the PVC that was there before, because I was being told it could blow out. OK, legal may not be an issue, cause your air tools will not go boom, but use some kind of filter to save them the flakes inside them. Good move, replacing your PVC. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.711 / Virus Database: 467 - Release Date: 6/26/2004 |
#30
On Fri, 02 Jul 2004 21:52:52 -0700, Richard Riley
wrote: On Sat, 3 Jul 2004 00:46:48 -0400, "Morgans" wrote: : :"Roger Halstead" wrote : : : Eventually I plan on building a sound proofed enclosure around the : compressor. Galvanized pipe for air lines around the inside of the : shop instead of having to pull a hose around. : : Roger Halstead Not galvanized pipe. It is illegal to use as gas pipe, :cause the plate can flake off, and plug stuff up. It could be bad for your ![]() So what's legal? Last year I spent a day running galvi parallel to the PVC that was there before, because I was being told it could blow out. I've run copper pipe through my shop. We're building a new home and shop and I plan to run 3/4" copper throughout the shop. I might even run a line to the house since I'll have a hobby room there, too. John |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
