Shop Layout Questions
Old June 30th 04, 10:43 PM
GreenPilot
Default Shop Layout Questions
I have a 20'x20' shop that I am remodeling and am seeking suggestions
for an optimum layout for building. Currently it is wired basically,
and I know I (read electrician) will adding a plurality of shop lights
and higher voltage outlets. Other than that, what else should I
consider?
I will be building with aluminum (no composites) so temperature, other
than my personal comfort, won't be an issue.
Should I just build a big workbench down one side, put tools on
another, put a compressor outside, and leave the floor space for
building?
TIA.
Old July 1st 04, 02:32 AM
Richard Lamb
B2431 wrote:
Date: 6/30/2004 3:43 PM Central Daylight Time
Message-id:
consider?
building?
TIA.
The bench should be in or near the middle or far enough from a wall so you can
work from both sides. The compressor is more prone to corrosion if outside.
A rolling tool box as well as shelves and pegboards on a wall should suffice.
The tools only have to be easily reached, not in the way. A rolling tool box
also has the advantage of having a flat top so you lay tools and parts out and
handy.
If I were me I'd walk around the open floor trying to visualize the best layout
for YOU.
Resiliant floor matts near your bench will make standing for long periods
easier.
You are going to make a mess so however you lay your shop out think of ways to
make clean up as simple as possible.
Good luck with your project.
Dan, U.S. Air Force, retired
OUTSIDE air compressor room(!), and air piped around the shop?
Some people use PVC pipe for that, but I'm too chicken.
Mine is iron gas pipe.
Old July 1st 04, 03:17 AM
Cy Galley
I would protect yourself with ground fault interrupters. One GCF can
protect several outlets.
If you have any fuel burning heaters, get a CO detector.
Cy Galley - Chair, Emergency Aircraft Repair
Safety Programs Editor - TC
EAA Sport Pilot
"Richard Lamb" wrote in message
Message-id:
consider?
building?
TIA.
you can
outside.
suffice.
box
out and
handy.
layout
for YOU.
periods
easier.
ways to
Old July 1st 04, 03:21 AM
Morgans
"Richard Lamb" wrote Dan, U.S. Air Force, retired
I'll take my noise maker (compressor) outside any day. Also make note of
the use of _iron_ pipe, not galvanized. Put your air disconnect in a "T",
with a foot of pipe below the "T", with a petcock to drain off water.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.711 / Virus Database: 467 - Release Date: 6/25/2004
Old July 1st 04, 08:53 AM
Craig
Richard Lamb wrote in message news:
I'll second putting the compressor outside the normal work area.
As to using PVC....well use it only if you like playing with bombs
with random length fuses... when it lets go, it becomes a shrapnel
generating machine. Also, let us know your shop location so we can
avoid being close to it.
The PVC and CPVC pressure ratings are for incompessible fluids only.
When you rerate the pipe using the correct formulas and apply the
correction factors for compressible fluid service and for operating
temps, you will find that the stamped 200 psi working pressure is now
about 4 psi.....
Now lots of people will pooh-pooh this and tell you that they have
been using it for years without a problem....just means that they
haven't had a failure yet. Take the time and read the exact working
of the ASTM rating stamped on that piece of PVC or CPVC as well as run
the numbers for yourself. I'll gladly point you to the specs and codes
as well as numerous vendor sites.
If you don't like this answer, then do a Google search on air and PVC
over in rec.crafts.metalworking. Lots of real world experience with
the failure side of PVC used as air lines over there.
Craig C.
Old July 1st 04, 03:21 PM
Shelly
I'm sure you realize that isn't much room
when it comes time to assemble the project -
wings and empennage to fuselage? What
are you going to build?
Shelly
Old July 1st 04, 04:02 PM
GreenPilot
All great pointers. I appreciate everyone's suggestions. Now...to the shop!
Old July 1st 04, 04:45 PM
pacplyer
(Craig) wrote in message . com...
about 4 psi.....
Craig C.
Craig's right. We put pvc all through my hangar and forgot to glue
one joint after dry fit. It went off like a pipe bomb with a sharp
peice hitting me in the face after whizzing by the eyes of my friend
and bouncing off a wall. Close call. You don't want to use this idea
unless it's good new schedule 40 stuff and you put it in the wall
behind sheetrock on purlings or something. Even then you may have
just built yourself a ticking sheetrock bomb (I don't know.) If it
sits out in the sun with the door open, you're getting UV damage and
the failure will happen a lot sooner. Also we discovered that the
straight sections are only schedule 125: they were sitting in the
Schedule 40 bin at Home Depot. I can't believe that I fell for that.
I thought it was a new thin-wall formulation or something (no legible
markings on the pipes.) But the nice new looking extruded stuff is
just 125psi sprinkler pipe and I'm at about 110psi in the shop.
Between that and the green lumber I don't think I'm going to go back
to Home Depot. IMHO use iron water pipe. And don't screw around with
those cheap oil-less air compressors. They just never recover,
running up your power bill and making your neighbors deaf.
Old July 1st 04, 04:48 PM
Don Lewis n FTW
building?
TIA.
You might want to look at this for your construction table/tables...
http://www.eaa1000.av.org/technicl/w...l/worktabl.htm
Don n FTW
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 3rd 04 12:41 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
