In an overshoot situation in a glider I was taught that it is better to be on
the ground overunning the landing area at 20mph rather than be too clever trying fancy S turns at low altitude. Having said that if he had a tail wind component wast a 180 an option? Condolances |
A 180 can only be safely done above 200 ft with good energy--just like a
rope-break. Even then, doing a 180 after over-shooting final is a good way to stall/spin. One time while instructing, a student was way too high on final and hadn't recognized how bad the problem was yet. By the time he realized, he developed complete tunnel vision on the glider runway that was now impossible to make. As we over-flew the glider runway, he wanted to try a 180 from 100ft and 60mph. I took over, closed the spoilers, and few straight ahead to the field you would use for a rope-break at 50 or 100 ft. Just like planning for rope-breaks, you need to plan your missed-approach options before you fly (or during instruction) what to do about being too low or too high to make the usual runway. "OscarCVox" wrote in message ... In an overshoot situation in a glider I was taught that it is better to be on the ground overunning the landing area at 20mph rather than be too clever trying fancy S turns at low altitude. Having said that if he had a tail wind component wast a 180 an option? Condolances |
"Mike Muncey" wrote in message
... A 180 can only be safely done above 200 ft with good energy--just like a rope-break. Even then, doing a 180 after over-shooting final is a good way to stall/spin. Why? Provided a well banked turn is used and appropriate speed (and 60knts is on the low side) given the prevailing wind conditions It is perfectly valid manouver even below 200ft. There are plenty of winch sites in the UK where in calm conditions this is a recognised recovery from cable breaks especially where landing straight ahead is not an option. In any sort of wind a 180 is asking for trouble as you will be landing downwind but a 270 to land cross wind may be valid or even a 360. S Turns are no longer taught in the UK on the basis that it will rarely help your position with regard to the remaining landing length and loses more height than a 360. (Each S turn is effectively a min of 180 and normally 360 + increased drag from the 3 changes in direction) In addition a 360 should increase your landing room provided it is not calm as the wind will sweep you back down the runway at the very least you will not be any worse off. The big problem with turns executed near ground is the tendency to haul back due to ground proximity, over ruddering to try and get round quicker and the mistaken psycological belief that a shallow turn is better. It is remarkable how little height a modern glider loses in a 360 provided it is flown acurately. In the UK great emphasis is given to low accurate flying before you go solo at a winch site. My last Aero cable break was 150ft over the end of the runway in calm conditions and in that scenario a 180 was the right thing to do. That said the only time you should be executing these sort of manouvers (Low turns) is off a break or other emergency. However IMHO the biggest cause of landings going wrong is too short a final appoach or low circuit leading to the pilot cramping the final leg giving the pilot a higher workload and less time to realise that things are going to pot. A high longer final approach is inherently safer as the pilot has minutes rather than seconds to recognise an over/undershoot and has more alternatives to correct his/her mistake. Obviously wind sheer, thermals and turbulance can cause difficulties but if the approach starts off right with half brakes then you have a reasonable amount of leeway either way in most gliders. How many of us manage finals on 1/2 brakes as opposed to full every time? Next time you approach flare with full brakes ask yourself what would happen if you had hit extra lift and why you had full brakes. Remember it is rarely the final action that is the real killer but the events that got you in that position to start with. Stay Safe Fly High Stephen |
At 02:48 26 June 2004, Stephen Haley wrote:
Why? Provided a well banked turn is used and appropriate speed (and 60knts is on the low side) given the prevailing wind conditions It is perfectly valid manouver even below 200ft. Rope- and cable breaks occur across a wide variety of conditions at a wide variety of altitudes. Sometimes they come with obvious audible and visual cues. Sometimes you don't know it's happened until you see that you're not keeping up with the towplane. The 200-foot altitude is generally chosen as a turnaround gate because it leaves usually-adequate margin to recognize the situation and effect a 180-degree turn even under less-than-perfect conditions. Sometimes it's not enough. Sometimes, as you point out, it has generous margin. Going off on a tangent, the thing I observe about too many of the recent accidents is that maneuvers intended to protect the aircraft from minor damage are resulting instead in loss of control with attendant major damage, injury, dismemberment, and death. It harkens back to the value trap that Pirsig invokes in _Zen and the art...,_ where the monkey forgets to value its life greater than the handful of grain that restrains its fist in the trap. More later - Thanks, and best regards to all Bob K. http://www.hpaircraft.com |
many of the recent accidents is that maneuvers intended to protect the aircraft from minor damage are resulting instead in loss of control with attendant major damage, injury, dismemberment, and death. Hi Bob, Today we had the service for Joe, it was joyful and tearful......both emotional states keenely balanced and teeter-tottering back and forth within moments of each other. It was obvious by the family and friends that attended, he was loved, repected and cherished.......he WILL be missed. Ironic about your tangent statement; since that is what we observed as well. Suffice to say that there were several small factors that did lead to this accident. The sum total resulted in the fatal stall spin......but taken individually were most likely opportunities for learning, but in total were overwhelming. This is not the post to enunerate that list......perhaps we should start a new thread about lessons learned. Regards, Brad PS.....Bob, your hand-cut fillet file is on the way! |
Although we can focus on the maneuvers that occurred in the last seconds
before the crash, we shouldn't forget that there were mistakes leading up to that point that should be considered. What was his altitude at the IP, was he checking things along the way (TLAR)? Did he turn in too soon (turn to base). It's rarely one single mistake that leads to accidents, but a compilation. Mark Nyberg wrote: On Sunday afternoon June 19th Joseph Patton died in a glider accident at Bergseth Field near Enumclaw, WA. Joe had been flying for a few hours in his motorglider, came in for landing with too much altitude, stalled and crashed. Joe died instantly. There will be a visitation (opportunity to pay last respects and talk with his family) on Friday June 25th from 4 to 8 PM at the Bonney-Watson Funeral Home. The funeral home is located at 1732 Broadway (between Denny and Pine, across the street from the Seattle Central Community College) in Seattle on Capitol Hill. Parking is available on the north side of the funeral home. Funeral Services will be held in the chapel at that same funeral home on Saturday June 26th at 11:00 AM. |
![]() "Mark Zivley" wrote in message m... Although we can focus on the maneuvers that occurred in the last seconds before the crash, we shouldn't forget that there were mistakes leading up to that point that should be considered. What was his altitude at the IP, was he checking things along the way (TLAR)? Did he turn in too soon (turn to base). It's rarely one single mistake that leads to accidents, but a compilation. Exactly: Speaking about pattern planning in general, rather than this sad incident in particular... One problem with glider flying is that by the time you get in a position to properly read the wind sock, your options may already be starting to narrow. But what if you are so sure about the wind direction that you forget to check the sock at all? Suppose for just a moment that you manage to enter your downwind leg without noticing that there has been a 180-degree wind shift since your launch. On "downwind", you notice excessive altitude loss due to the undiagnosed headwind and (thinking you had hit sink) turn base early. That headwind on your "downwind" leg will now turn into an unexpected tailwind as soon as you turn final from base--a base leg that is suddenly very close to the fence because the wind has blown you towards the runway, rather than away from it as you expected. You now find yourself high, with a high groundspeed, and already over the fence with significant runway quickly disappearing behind you. Now your options have REALLY narrowed! Vaughn |
On Sat, 26 Jun 2004 00:54:36 UTC, "Vaughn"
wrote: : Suppose for just a moment that you manage to enter your downwind leg : without noticing that there has been a 180-degree wind shift since your launch. I confess. I have been there and done that. Those sea breeze fronts can come through damn fast. And I did check the windsock, but only to register the orientation of the wee orange triangle relative to the runway. Realising that the ground was passing roughly 25 kt faster than I expected at round out was a character building moment. Ian -- |
Interesting that there has been no mention of side-slipping and yet that
would be my immediate thought if I believed I was too high to get onto the ground without overshooting? Rich... Mark Nyberg wrote: A credible witness observed that by the time Joe realized he was in trouble, he was too high, etc... |
![]() "Richard Branch" wrote in message ... Interesting that there has been no mention of side-slipping and yet that would be my immediate thought if I believed I was too high to get onto the ground without overshooting? Rich... Ian Johnston did, somewhat earlier in the thread: "I'm a sideslip enthusiast at such times myself. With full brake and a full rudder slip the Pirat comes down like a parachute... Ian " |
Sport Pilot - School Won't Offer | Gary G | Piloting | 38 | February 16th 05 10:41 AM |
Bad publicity | David Starer | Soaring | 18 | March 8th 04 03:57 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
I wish I'd never got into this... | Kevin Neave | Soaring | 32 | September 19th 03 12:18 PM |
Restricting Glider Ops at Public Arpt. | rjciii | Soaring | 36 | August 25th 03 04:50 PM |
