Polar Analysis from flight logs?
Old December 29th 04, 01:02 PM
Andy Blackburn
At 07:30 29 December 2004, Eric Greenwell wrote:
I think the pilots trying this are not doing that,
but instead rely on
their airspeed to give them IAS. This does require
calibration of the
ASI for real accuracy.
Actually the first post in this thread (from Mark)
read:
'Has anyone done any work to develop a program that
would look at some flight logs and determine what a
particular glider's actual polar is?'
This original idea has now morphed into a suggestion
essentially to replicate the technique used by Dick
Johnson and others, with the main difference being
using the barometric altitude transducer in a flight
computer instead of the mechanical altimeter(?). This
might offer some improvement in accuracy, but is at
least as complex to execute as the flight test techniques
used for the past 40+ years.
There are two main challenges with using flight logs
only:
1) There is no good source for IAS, so you have to
try to estimate it from GPS ground speed.
2) Typical soaring flights don't involve adequately
calm vertical airmass movement and probably not constant
enough airspeed to trust even long glides of many tens
of miles.
9B
Old December 29th 04, 07:15 PM
Cliff Hilty
The different air masses, the different instruments
ect. ect.
obviously lead to different results. Not being the
physic's expert, I was just wondering if anyone has
tried flight testing Sailplanes in a wind tunnel? Could
you 'hard point' it and measure weights or lack of
weight to get Polar info. Im sure boeing or MD has
done something like that. I suppose that you may not
get a direct glide ratio but could get a common start
point that all gliders then could be compared to. Any
comment from the mathematicians?
only:
of miles.
9B
Old December 29th 04, 07:28 PM
Eric Greenwell
only:
This data is available from various instruments, like the Cambridge 302
that I use. For the 302 it's actually the TAS, which could be combined
with the air temperature and pressure altitude to compute the IAS. The
TAS and temperature are not recorded in the 302 flight log,
unfortunately, but they could be recorded by the Ipaq connected to it
and inserted in the flight log it keeps, and this log used for the analysis.
of miles.
I think this is a show-stopper, even if the IAS is available in a flight
log.
Eric Greenwell
Washington State
USA
Old December 29th 04, 10:59 PM
Andy Blackburn
Hey Cliff,
A wind tunnel would allow you to measure lift and drag
forces directly at various speeds, angles of attack
and flap settings. From this you could generate a polar
for any weight. This would be the most accurate way
to generate a polar I believe because it is under lab
conditions with highly calibrated instrumentation.
Of course you'd need a big wind tunnel like the NASA
Ames 80'x120' low-speed tunnel. You can rent it out,
but I bet it's expensive. To cover all the speeds,
flap settings and weights you'd need several dozen
test points, which would require a few hours in the
tunnel.
http://windtunnels.arc.nasa.gov
9B
Old December 29th 04, 11:09 PM
Andy Blackburn
the Cambridge 302
could be combined
the IAS. The
log,
connected to it
Neat idea - is that a configuration item on the 302
and/or WinPilot, or do you need to write software/firmware
to make it happen? Of course you'd still need to calibrate
the 302 IAS transducer for each sailplane type, but
at least then it would automate the data capture for
the kinds of performance testing Dick Johnson does.
Maybe he already has a rig to do this, but maybe not.
It would also allow collecting data from more than
a single test subject since anyone who could take a
high tow on a calm day and hold a constant airspeed
for more than 5 minutes could contribute a test point.
Of course here I'm assuming that all 302s and sailplanes
of a particular type with the same pneumatic setup
have similar airspeed errors, which may or may not
be true.
9B
Old December 30th 04, 12:57 AM
Eric Greenwell
The
log,
connected to it
to make it happen?
I don't know about Winpilot, but it's not part of SeeYou Mobile. I think
it could easily be added by SeeYou and included in the Ipaq flight log
it can already keep, and I've suggested it to SeeYou. It's just another
data "sentence" that the 302 can send out.
The sensor could be (probably is already) calibrated by Cambridge and
other labs when it is calibrated for flight recorder use.
You wouldn't have to measure your pitot/static system if you were
interested only in your glider, and not in comparing the data with data
from other gliders; for example, if you just wanted to maximize your use
of the flaps and speeds.
but
I'm sure he does use an automated logger of some kind. I don't think
he's used a "vibrating panel" for quite a while!
Eric Greenwell
Washington State
USA
Old December 30th 04, 01:54 AM
Udo Rumpf
"Eric Greenwell"
I'm sure he does use an automated logger of some kind. I don't think he's
I the spring of 2003 Dick Johnson when he tested my glider he still used
the hard ware he has been using for a long time.
A vibrator for the Panel, he calibrates the airspeed indicator and the
altimeter. He uses his own instruments and takes notes of temperature
and as he flies trough 500ft timed intervals. He is able to do 3 to six
speeds
for each flap setting on one flight from 12000ft. In my case he made two
flight. The other aids are a stop watch, a note pad and at least two if
not
three pencils. I would be able to provide you with a copy of the numerical
data sheet.
Regards
Udo
Old December 30th 04, 02:33 AM
Eric Greenwell
speeds
if not
numerical data sheet.
I was sure I'd read/heard he was using an electronic logger, at least at
one time. Did he mention if he'd tried one, or if some of the pilots
assisting him used one?
Eric Greenwell
Washington State
USA
  #29
Old December 30th 04, 02:46 AM
The Zander flight computer performs a constant L/D calculations throughout a
flight. The L/D is presented numerically on the screen. All you need to do
is note the L/D, flap setting and speed at any particular time.
David
"Mark Zivley" wrote in message
m...
We all know what the manufacturer's polars look like, but what about our
individual planes. Has anyone done any work to develop a program that
would look at some flight logs and determine what a particular glider's
actual polar is? At one point Ball was making a vario system that would
determine the aircraft's polar over time just by flying.
For someone who already had some algorithms for computing wind from ground
track drift during thermals could take this info and then be able to back
figure from GPS ground speed what the IAS was during a particular phase of
the flight. By isolating longer sections of cruise flight at varios
airspeeds it should be do-able. Question is, has it been done.
Mark
extra "hot" in the address to delay the spammers...
  #30
Old December 30th 04, 02:47 AM
Udo Rumpf
speeds
two
not
I did ask him if loggers are helpful to him and he said no.
That would indicate he may have tried using it as an aid.
Udo
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 10:20 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 07:13 PM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
