source for clips or sleaves for Hotelier linkages
Old July 29th 19, 01:09 AM posted to rec.aviation.soaring
Steve Bralla
Default source for clips or sleaves for Hotelier linkages
On Monday, June 15, 1998 at 12:00:00 AM UTC-7, Al wrote:
Anyone got any good suggestions for clips for hotelier linkages.
I also understand that there is a sleave kit out there somewhere.
Thanks
Al
Sleeves? I can't help. Pins? Aircraft Spruce
https://www.aircraftspruce.com/catal...owlingpins.php
Old July 29th 19, 08:17 AM posted to rec.aviation.soaring
John Foster
Thanks
Al
Thanks for all the links, guys, but these are not the spec that is called for in this AD. The glider in question is a Bolkow Phoebus, but I believe this AD also applies to the Standard Cirrus, as well as some others (correct me if I'm wrong). It specifically states the clip must be 1.2mm diameter wire, and gives a picture of the clip going across the push rod. In this particular application, the push rod is only about 1/2" diameter, so a clip that is 1.5" long will stick out the sides too far and hang up on the surrounding structures. Here's a link to the AD:
http://www.ltb-lindner.com/phoebus-ad-sb.html
Look particularly at the PDF link "13 94_001 L`Hotellier Verschluesse.pdf (94,4 kB)".
It gives pictures and dimensions of the clip needed. It specifically mentions a specific L'Hotellier part #140-31, or equivalent Ford part number 1473 931, but neither of these part numbers come up with anything other than copies of the AD when a Google search is done. I can not find a source for these specific parts.
Old July 29th 19, 08:57 AM posted to rec.aviation.soaring
John Foster
Thanks
Al
More specifically, these connections are for aileron and spoiler push rods that come through holes in the wing root rib. If the clips stick out too far, they will snag on the edges of the holes in the wing root rib and cause the control surfaces to hang up and not move properly. Obviously, that would be very bad.
Old July 29th 19, 09:09 AM posted to rec.aviation.soaring
James Thomson[_2_]
=20
Thanks
=20
Al
=20
called=
believe=
(corre=
diamete=
this=
cli=
sur=
=20
=20
Verschluesse.pdf=
(94,4 kB)". =20
=20
men=
number
1=
other
than=
source
fo=
rods
f=
cause=
that
wo=
uld be very bad.
I think that you are getting the various locking devices confused! The
AD is issued by LBA - Google LBA 193-001/3 for the current version.
There are various locking methods to choose from - safety pins, Uerling
sleeves, LS locking sleeves, Schempp-Hirth clips, Wedekind sleeves are
all mentioned in the AD.
The L'Hotellier and Ford safety pins are very small and simply go through
the connector lock plate as shown on the second page of the Lindner
document. They do not go round the push rods or stick out to foul the
holes in the root rib.
Old July 29th 19, 09:39 AM posted to rec.aviation.soaring
John Foster
=20
Thanks
=20
Al
=20
called=
believe=
(corre=
diamete=
this=
cli=
sur=
=20
=20
Verschluesse.pdf=
(94,4 kB)". =20
=20
men=
number
1=
other
than=
source
fo=
rods
f=
cause=
that
wo=
uld be very bad.
Exactly. These are the type of connectors on my glider, and I am looking for a source for these "very small" pins. I realize there are other newer and better connectors, and one of those options may be in my future. But for now, I need to drill holes as mandated by this AD and use these specific small pins. Where can I find them?
Old July 29th 19, 09:47 AM posted to rec.aviation.soaring
Look at a RC car supplier (like, Tower Hobbies) for "body pins" used to hold a RC car body onto the chassis.
IIRC, we used to use dental floss tied onto the pin and pushrod so you didn't lose the pin.
Old July 29th 19, 04:28 PM posted to rec.aviation.soaring
Dan Marotta
THESE
https://www.walmart.com/ip/Unique-Bargains-50pcs-R-Split-Mechanical-Hitch-Hair-Tractor-Cotter-Clip-Pin-1-6mm-x-28mm/546161908
are what I use.Â* Never run out again.
If those seem too cheap, send me $139.95, and I'll send you 6 of them. :-D
=20
Thanks
=20
Al
=20
called=
believe=
(corre=
diamete=
this=
cli=
sur=
=20
=20
Verschluesse.pdf=
(94,4 kB)". =20
=20
men=
number
1=
other
than=
source
fo=
rods
f=
cause=
that
wo=
uld be very bad.
Dan, 5J
source for clips or sleaves for Hotelier linkages John Foster Soaring 41 August 22nd 19 01:48 AM
Source for L'Hotellier Safety Clips George Haeh Soaring 23 January 29th 19 12:20 AM
L'Hotelier Fitting Safety Pins Dan Marotta Soaring 20 October 17th 16 01:40 AM
Hotelier safety sleeves [email protected] Soaring 6 August 31st 07 03:41 PM
Lycoming throttle linkages Evan Carew Home Built 0 September 29th 04 01:58 AM
