Glider Towplane Mid-air – TP PowerFLARM Inop
Old February 12th 20, 11:44 AM posted to rec.aviation.soaring
krasw
Default _Glider_Towplane_Mid-air_–_TP_PowerFLARM_Inop
When releasing in a turn and seeing tow plane to continue the turn, it is totally plausible to NOT consider him collision threat anymore. In this case I can see why and how this happened. I'm pretty sure the awful visibility during turn from high wing Cessna was a factor. Accidents are 100% avoidable only for 100% perfect human beings.
Old February 12th 20, 04:05 PM posted to rec.aviation.soaring
Post-release "clearance by rote" is - as this terrible accident strongly
suggests - a seriously flawed methodology.
I agree. I aways turn right after release, to satisfy the rule, but only maybe 30 degrees before halting the turn, and turning back left as necessary to keep the towplane in sight. The towpilot necessarily loses sight of the glider after release, and should fly directly away from the release point until well below the release altitude.
Old February 12th 20, 04:15 PM posted to rec.aviation.soaring
GeneReinecke
On Tuesday, February 11, 2020 at 8:51:26 AM UTC-7, Waveguru wrote:
This seems to happen every few years, where the tow plane makes a left turn and the glider make a right and they come around and collide. I changed the way we do it here so that the glider only makes a slight right turn, and then keeps his eye on the tow plane, so that at least one of the pair of planes can more easily maintain separation. When both planes make a 360° turn, neither of them can see the other. This kind of accident is the result.
Boggs
Agree with your logic. As a tow pilot and glider pilot I have circled around on several different flights over the last 7 years only to be too close to other aircraft. I began to do and teach what I saw at a contest a few years back: Tow plane descends and continues straight before maneuvering back toward airport (efficient.) Glider circles and (re)gains visual contact before continuing flight. Make the student verbally call tow plane out before moving onto soaring or lesson. Creates maximum separation.
Warning: This must be part of (US) preflight briefing or one pilot or other is going to say "What in the heck is that guy doing?"
Cheers
Gene
Old February 12th 20, 04:24 PM posted to rec.aviation.soaring
Tango Eight
On Tuesday, February 11, 2020 at 11:46:52 PM UTC-5, 2G wrote:
You can't hardly blame the glider pilot: they were flying straight ahead and were struck from behind. The tow pilot is clearly the one at fault.
Tom
There's one thing we know for sure about accident reports: they aren't 100% accurate. I think we ought to hesitate to convict someone we've never met based on evidence that can't be verified.
That said...
The day I tow some doofus that
-chooses to release in a right hand turn
-does a soft release
-clears to my left
and doesn't immediately get on the radio to let me know what's going on and make certain he keeps me in sight until we achieve normal vertical separation... we're going to have some words.
In the glider, I teach (following release & right turn): 1) track the towplane, 2) find the airport, 3) get on with normal flight procedures. Our turns at separation are typically 90 deg left for the towplane and 45 or more right for the glider. OK to thermal once you are certain the towplane is out of the area.
Yes, the tow pilot had better options. 2020 hindsight he Given loss of situational awareness, or the vague awareness that the glider is somewhere out of sight, close and below, then a better thing to do is clear the area.. If you realize you've been victim of a soft release, then I think the thing to do is simply proceed straight ahead for at least 30s while beginning your descent.
That tow pilot has my deep sympathy. No one wants a do-over more than he does.
best,
Evan Ludeman / T8
Old February 12th 20, 04:38 PM posted to rec.aviation.soaring
Dan Marotta
Did you release the canopy or go through it?
On 2/11/2020 5:15 PM, waremark wrote:
My glider blunted and I was hanging from my straps and fell out as soon as I released the harness. My mohair was at 3000 ft agl but I would have had no problems from 2000.
Anyway, reading this will make me pay more attention to where the tug goes after release. At our club to avoid shock cooling the tug generally accelerates away level before reducing power, and the glider does a climbing turn to slow down.
Dan, 5J
Old February 12th 20, 04:41 PM posted to rec.aviation.soaring
Dan Marotta
Point taken, but a soft release is never a good thing from the tow
pilot's perspective.Â* When flying my glider I seldom released softly but
I always announced, "5J's off, thanks!"
On 2/11/2020 9:46 PM, 2G wrote:
On Tuesday, February 11, 2020 at 10:53:29 AM UTC-8, Dan Marotta wrote:
When I was towing, I would visually confirm that the glider was off and
then roll steeply and dive.Â* If I hadn't felt the glider get off, I
would fly straight and level for a bit to assure clearance before
beginning a more moderate descent.Â* I also maintained awareness of any
gliders that had not climbed away.
I would blame both of the pilots in this accident but would assign most
of the blame to the tow pilot.Â* Making what amounts to a level turn just
after release is asking for trouble.
Boggs
Dan, 5J
Tom
Dan, 5J
Old February 12th 20, 06:03 PM posted to rec.aviation.soaring
Darryl Ramm
Default Glider Towplane Mid-air – TP PowerFLARM Inop
I think the reverse question is more intersting. How many people would have a PowerFLARM in a towplane and tolerating it repeatedly having problems before getting it fixed.
I expect it would be good to see more PowerFLARM adoption in towplanes in the USA.
Old February 12th 20, 06:22 PM posted to rec.aviation.soaring
Dan Marotta
The ABQ soaring club Pawnee has either a Flarm or a transponder.Â* In any
case, I see it electronically all the time.
Dan, 5J
  #29
Old February 13th 20, 04:14 AM posted to rec.aviation.soaring
2G
Tom
The report had the tracks of the two aircraft.
Tom
  #30
Old February 13th 20, 06:18 AM posted to rec.aviation.soaring
John Foster
Boggs
Dan, 5J
Tom
Dan, 5J
I agree with Dan. Part of my training was to make a radio call every time to let the tug know I was off tow. A simple radio call like this could have allowed the tug to start his descent and get out of the way.
PowerFLARM Core or LXNAV PowerMouse Installation in Towplane Paul Remde Soaring 1 October 2nd 19 04:58 PM
Powerflarm in towplane anecdotal experiences son_of_flubber Soaring 0 July 29th 19 04:30 PM
Cirrus collides with Glider/Towplane Jody Soaring 9 February 7th 10 03:14 AM
towplane collides with glider, prop hits wingtip [email protected] Soaring 21 September 1st 09 07:24 PM
Glider - Towplane Signals Mike the Strike Soaring 24 March 26th 05 09:33 PM
