ATC Altimeter Settings
Old April 1st 05, 07:13 PM
O. Sami Saydjari
Default ATC Altimeter Settings
When entering an ATC region, we often get an altimeter setting, usually
at some fix. So for example, when entering the Chicago center ATC
region, they say something like, "Midway altimeter is xx.xx." I have
some questions.
1. So, do they pick some fix for the region and give everyone (those
below FL 180) the altimeter of that fix? Do they break up into
sub-regions and give everyone in that sub-region that same fix altimeter
setting?
2. At what point after departing an airport do you change altimeter
setting to the one supplied by ATC? Similarly, on approaching an
airport to land, at what point do you switch over to the altimeter
setting of the airport (from that given by ATC).
The reason I ask is that sometimes, the altimeter settings can be quite
different. Especially if there is VFR traffic around an airport, it
seems that there is some risk if everyone entering the pattern (or
approaching the pattern) does not share the same altimeter setting.
Just curious.
-Sami
N2057M, Piper Turbo Arrow III
Old April 1st 05, 08:22 PM
Roy Smith
some questions.
setting?
You should get the altimeter setting for the airport nearest your
location which has weather reporting.
I update my altimeter setting whenever ATC gives me a new one.
Similarly, on approaching an airport to land, at what point do you
switch over to the altimeter setting of the airport (from that given
by ATC).
If ATC has given me a setting for my destation, I'll just use that.
If not, then I'll set my altimeter whenever I get the ATIS/AWOS.
different.
What do you consider "quite different"? Unless there's some severe
weather going on, it's unusual to have to change the setting more than
a couple of 1/100's at a time.
Risk of what? If somebody's 50 feet high or low in the pattern, it
doesn't make much difference. As long as it's VFR, see and avoid is
the rule of the day. The real reason for having sensitive altimeters
is for instrument work.
Old April 1st 05, 08:37 PM
O. Sami Saydjari
some questions.
setting?
So, if ATC gives you a setting on initial contact out of the airport you
just took off from, you use the airport's setting, not ATC's? When do
you cut over to ATC's? Or do you just listen to every AWOS/ASOS enroute
and change to the closest one?
See above. What I am asking is when to change over?
by ATC).
So, ATC expects you to change your altimeter whenever you first hear the
ATIS at your destination? That could be 50 miles out. Seems a little odd.
different.
I have seen differences of 0.5 inches....that is alot!
Well, good point, except that if you are descending through a cloud deck
into VFR conditions. Also, if you change your altimeter 50 miles out
and I change mine 5 miles out, it seems like their is some distance from
the airport where we are using different settings, and that seems like a
bad thing to me.
Old April 1st 05, 08:56 PM
Roy Smith
I think I may have confused you with some sloppy wording. What I
meant was, "The altimeter setting ATC gives you will mostly likely be
for the airport nearest your current location".
The bottom line is anytime ATC gives me an altimeter setting, I reset
my altimeter to whatever the controller gives me.
Well, I do that too. Maybe not *every* one, but on a long flight, I
will certainly tune in the occassional ATIS as I go by airports. It's
also a good way to stay aware of weather trends; if the altimeter
settings keep going down, you know you're flying into worsening weather.
0.5 inches is a HUGE altimter setting change. Are you sure about
that?
Old April 1st 05, 09:59 PM
A Lieberman
that?
I have to agree with Roy here.
I just finished coming back from Ohio to Mississippi, and I experienced a
very large altimeter setting adjustments in my journey southbound north of
Bowling Green KY, but I sure did not experience .50 inches adjustments en
route. I did end up .25 inch less over the whole trip though.
If I remember correctly on one ATC hand off, I went from 29.96 to 29.88
which lowered my altitude by 80 feet. This really alarmed me as I sure
don't like deviating more then 20 feet from assigned altitude. Needless to
say, I made a quick climb to my assigned altitude!
There was a rather steep pressure gradient even in my trip I just did this
week, but as Roy says, .5 inch altimeter change in a flight range distance
in planes I fly is probably indicative of weather I wouldn't / shouldn't be
flying in anyway.
Allen
Old April 1st 05, 10:19 PM
O. Sami Saydjari
Well, I thought it was 0.5 inches, but I am not absolutley certain...it
was a while back. But, I do not think this changes my point
substantially. Even a 0.25 inch change is substantial, and if there is
not a standard of when one changes settings, it seems like a risk,
albeit small.
My experience is that ATC does not give me settings of nearby airports.
For example, I recall entering Chicgo Center airspace from the south.
I was just north of Lafayette, Indiana. The controller gave me the
altimeter setting for Chicago Midway. That is a long way away.
Lafayette airport was at least 0.1 inches different. I used ATC's
setting, because I figure they must have some standard reference point
in a region, or sub-region, so that all the planes are at least on the
same relative setting.
-Sami
that?
flying in anyway.
Allen
Old April 3rd 05, 06:21 AM
Chip Jones
"O. Sami Saydjari" wrote in message
some questions.
setting?
Center ATC is divided into Sectors. Each Sector has a series of altimeters
that they monitor. My Center Airspace has three low altitude sectors and 4
high/ultra high sectors that I work on a daily basis. The three low sectors
lie north of Atlanta, between Atlanta GA (ATL), Chattanooga TN (CHA),
Nashville TN (BNA),Knoxville TN (TYS) Asheville NC (AVL) and back to
Atlanta. Each of these low sectors has a set series of altimeter stations
that by facility SOP (standard operating procedure) the sector must monitor.
These stations have been determined by FAA management to be germain to the
safe operation of the sector.
Two of the sectors stack on top of each other, covering North Georgia from
the ground to FL230. These two sectors must monitor (by SOP) the ATL, CHA
and TYS altimeter settings. The other sector lies to the north in
Tennessee. This sector must monitor CHA, CSV (Crossville TN) and TYS
altimeter settings. When the three sectors are combined (as they often
are), then the combined sector must monitor ATL, CHA, CSV and TYS.
The way we monitor the altimeters is that we have them displayed in an
electronic box on the scope. As the weather updates at whatever station we
are monitoring, the altimeters update automatically. If one or more of the
local altimeters that belong to a sector dips below 29.92, then we are no
longer able to use FL180 for IFR separation. In ATC parlance, we say
"Eighteen is broken."
We are required to issue a local altimeter at least once to you as you
transit the sector. I try to use a little common sense on which one I
issue, but in the enroute environment, you are not always going to be flying
directly between or along altimeter stations that I am monitoring. An
example would be a flight from Chattanooga TN to Charelston SC. You have
departed CHA. You are exactly between TYS and ATL. When you check in with
ARTCC, which altimeter do I issue? CHA (which you just left) or one of the
other two which are not on your route? Many of us avoid these awkward
situations by monitoring additional stations. For example, if you depart
TYS heading up towards Cinncinnatti or points north, I will issue you the
London KY altimeter (LOZ) because I think it is stupid to issue you the TYS
altimeter when TYS is 30 miles behind you and LOZ is coming up. So I
monitor LOZ as well in my electronic list, just because...
Chip, ZTL
Old April 4th 05, 01:31 AM
John R. Copeland
"Chip Jones" wrote in message =
link.net...
=20
When entering an ATC region, we often get an altimeter setting, =
usually
some questions.
sub-regions and give everyone in that sub-region that same fix =
altimeter
setting?
=20
Center ATC is divided into Sectors. Each Sector has a series of =
altimeters
that they monitor. My Center Airspace has three low altitude sectors =
and 4
high/ultra high sectors that I work on a daily basis. The three low =
sectors
Atlanta. Each of these low sectors has a set series of altimeter =
stations
that by facility SOP (standard operating procedure) the sector must =
monitor.
These stations have been determined by FAA management to be germain to =
=20
Two of the sectors stack on top of each other, covering North Georgia =
from
the ground to FL230. These two sectors must monitor (by SOP) the ATL, =
CHA
altimeter settings. When the three sectors are combined (as they =
often
=20
electronic box on the scope. As the weather updates at whatever =
station we
are monitoring, the altimeters update automatically. If one or more =
of the
local altimeters that belong to a sector dips below 29.92, then we are =
no
=20
issue, but in the enroute environment, you are not always going to be =
flying
example would be a flight from Chattanooga TN to Charelston SC. You =
have
departed CHA. You are exactly between TYS and ATL. When you check in =
with
ARTCC, which altimeter do I issue? CHA (which you just left) or one =
of the
situations by monitoring additional stations. For example, if you =
depart
TYS heading up towards Cinncinnatti or points north, I will issue you =
London KY altimeter (LOZ) because I think it is stupid to issue you =
the TYS
=20
Chip, ZTL
=20
Chip, you didn't mention enroute altimeter settings being different from =
surface ones.
I've seen that condition in the Rocky Mountains, but I can't =
specifically recall
if I've ever seen it in the central and eastern U.S.
In the west, lapse rates can be such that an altimeter setting for an =
airport
can be noticeably different from the enroute value many thousands of =
feet higher.
The controller may have good reason to issue area altimeter settings =
which are
different from those reported at nearby airports.
Old April 4th 05, 03:47 AM
Newps
John R. Copeland wrote:
Chip, you didn't mention enroute altimeter settings being different from surface ones.
I've seen that condition in the Rocky Mountains, but I can't specifically recall
Controllers issue altimeter settings from ground stations. Where else
would they come from?
Old April 4th 05, 03:50 AM
Roy Smith
surface ones.
recall
You get them off DUATS like the rest of us?
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 10:14 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 03:01 PM
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 08:58 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 10:28 AM
Altimeter experience HankC Piloting 2 July 25th 03 10:43 PM
