#21
![]() Frank Ch. Eigler wrote: Newps writes: Can you picture the radar screen in Boston/New York/Chicago/LAX when all the planes on the ground are showing up? The radar sweeps by and shows 23 planes lines up for the departure runway, superimposed on whoever is flying overhead. Irrelavant. The radar computer has software that will not show any target within the user specified distance from the radar antenna. [...] Maybe, but it is still a problem for aircraft with TCAS, who receive false alarms due to the ground traffic. Then their TCAS has problems. Properly operating TCAS knows the aircraft is stationary plus below a certain altitude it is advisory in nature. If this were a problem I would hear about it from aircraft with TCAS. Not once in the last 17 years has an aircraft with TCAS so much as mentioned they were receiving an alert from an aircraft holding short of the runway. |
RST Engineering wrote:
Then why doesn't the stall warning horn have one? The stall warning horn in all of my aircraft have two: The CB and the one labeled "master". |
Every electric device needs an on-off switch. Then why doesn't the stall warning horn have one? The stall warning horn more than likely has a circuit breaker. And some stall horns, like on the C-152, are pneumatic. -- Mortimer Schnerd, RN VE |
![]() "RST Engineering" wrote in message ... Then why doesn't the stall warning horn have one? Cause nobody has yet found a way to turn off a butt which is what real airplanes have for stall warning indicators. :-) Jim Every electric device needs an on-off switch. |
![]() "Peter R." wrote in message ... sfb wrote: In military formation flying, only 1 plane has a transponder turned on. Isn't this true with GA formation flying as well? Yes, and ATC will let you know if more that one in the formation has their transponder on. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
In most Cessnas with electric horns, the CB is a hidden "auto-reset" device
that you can't pull. The master doesn't count. Jim "Chris Kennedy" wrote in message ... RST Engineering wrote: Then why doesn't the stall warning horn have one? The stall warning horn in all of my aircraft have two: The CB and the one labeled "master". |
![]() "Mortimer Schnerd, RN" wrote in message ... RST Engineering wrote: Every electric device needs an on-off switch. Then why doesn't the stall warning horn have one? The stall warning horn more than likely has a circuit breaker. See my reply to Chris Kennedy And some stall horns, like on the C-152, are pneumatic. That's rather gratuitous of you. Jim |
#29
![]() "RST Engineering" wrote in message ... Then why doesn't the stall warning horn have one? It does. You'll find it in the wing leading edge. |
#30
In most Cessnas with electric horns, the CB is a hidden "auto-reset" device that you can't pull. The master doesn't count. Fair enough. The fact that most Cessnas don't have a CB that you can pull doesn't change the fact that my aircraft do. Perhaps that's a bit pedantic, but it remains a valid response to the question you posed. |
Stupid Americans! -- Stupid... Stupid... STUPID!!! _____________---_ unakm | Karl Treier | Aviation Marketplace | 3 | December 17th 04 11:37 PM |
Stupid Americans! -- Stupid... Stupid... STUPID!!! _____________ efamf | Keith Willshaw | Naval Aviation | 4 | November 11th 04 01:51 AM |
Stupid hp to thrust question | Mark | Home Built | 52 | December 9th 03 01:41 PM |
Transponder Question | log | Home Built | 2 | December 2nd 03 06:08 PM |
Stupid super cub question | Robert Loer | Home Built | 9 | November 22nd 03 05:28 PM |
